Just getting started
Posted by Utah
Utah
Danny Valenzuela
December 15, 2014 01:09AM
I'm new to rally so I'm sure I will earn some flamage. Any ways did some rally cross and thought like everyone else it would be so cool to actually rally. I found a 93 MX-3 for right about 500 bucks and thought what the heck, if nothing else I'll have a car to keep running rally cross.
Pretty much I'm hear hoping that some one here has run or is running an MX-3. I've heard of one guy so far but I'm not sure if he is still doing it or not. Here's to hoping some one knows the guy/s running the mx-3 and getting on stage eventually.
Re: Just getting started
December 16, 2014 06:46PM
honestly i can't recall anyone running an Mx-3, however, it would work for rallycross since 90% of rallycross is a running car.
bknblk2
Tony Wood
83 Citation "Oskar"
December 17, 2014 05:32PM
I'm pretty sure there's been a MX-3 run at 100 acre wood. 4-5 years ago They backed it into the woods and that big back glass when buh-bye smiling smiley.
Mazda sends out checks, so there's reason enuff to play around with it.
Edited 1 time(s). Last edit at 12/17/2014 05:33PM by bknblk2.
December 18, 2014 12:34AM
Edit: it's dan little that has one. Just ran at show me rally. Pretty sure it's the same one from 100 acre
results from show me
http://showmerally.100aw.org/wp-content/uploads/2014/12/ShowMeResults.pdf
Edited 2 time(s). Last edit at 12/18/2014 12:39AM by aj_johnson.
Towona
Tony P
MK2 Golf
December 18, 2014 11:56AM
Welcome.
James Haas runs/ran an MX-3 in stage rally, and I used to rally-x one. I'm not sure what James' setup was, but for my 93 w/ the 4-cyl engine, I swapped in the 1.8BP engine from a Ford Escort GT. I was planning on eventually turning it into a rally car, but ultimately realized that there would be a lot of problem solving ahead of me that I wasn't prepared to do, so I decided to buy a pre-built rally car.
I think that the car would certainly be capable of being a decent car and that the experiences of those that ran Mazda GTX's and Ford Escort GT's in the past would help in the build process. I found the MX-3 to be pretty solid and competitive in my local rally-x series, plus it was a lot of fun. I say rally-x it for now and take some time to figure out what you want to do and what the best way is to get there.
Runamuck Rally
Utah
Danny Valenzuela
December 19, 2014 11:32PM
Thanks for the welcome guys. I have gotten a hold of Dan and it sounds like its going to be a challenge. But with as cheap as the car was and its already running its worth a go to build it up and learn and such then decide down the line if the cage is going in and the car is going to see a stage.
December 20, 2014 01:24PM
If you are just aiming at rallycross, cheap and light is better.
There's probably nothing special about the car to build into a stage rally car. With your location you will likely be looking at potentially rougher stages than other parts of the country so a flimsier car that nothing is known about isn't totally ideal. I'd say go rallycross it and start thinking about something better suited to stages. smiling smiley
Vorpal_Rally
Stinkfinger Lipschitz
December 23, 2014 05:59AM
Yeah, James Haas' car is done and gone. Good luck rallying.
It is useless for the sheep to pass resolutions in favour of vegetarianism, while the wolf remains of a different opinion.
William Ralph Inge
TANSTAAFL
December 31, 2014 12:03PM
Low roof cars can be a challenge to get proper clearance between your head and the roll cage (factor in the thickness of the required padding). If you're short this may not be a problem at all. I'm about 6' and my experience in 1st gen DSMs sucked. The one I sat in required me to have my head tilted 10-20 degrees or so and was always banging off the cage, and it wasn't for lack of trying. The trans tunnel had been notched, the seat moved inwards about 2" more than stock, and mounted as low as it could go.
December 31, 2014 01:40PM
In udder woids, ANYTHING for grass-o-cross
But think hard before commencing a rally build.
Utah
Danny Valenzuela
January 01, 2015 11:34PM
@dave I'm only 5'6 so hopefully everything fits should I put a cage in. The more I look at it the more I'm leaning towards learning what I can with this car and having fun with it, but when it comes time to really go for rally look for something thats done regularly with plenty of info out there for the build.
January 02, 2015 12:51AM
thats waaaaay too reasonable for rally anarchy.
Brian Johnson
Brian Johnson
Co-Driver - Old School Motorsports WRX
January 02, 2015 04:57AM
Utah
Don't forget that (should you ultimately decide to stage rally the car), just because you may fit fine in there, doesn't mean prospective co-drivers will fit fine.
-Brian
Utah
Danny Valenzuela
January 03, 2015 03:48PM
I was thinking I might be able to do something like the top gear electric car if I need extra head room.
Towona
Tony P
MK2 Golf
January 03, 2015 10:14PM
The mx3 has a ton of room compared to the talon
Runamuck Rally
