Thursday Sept 17. Find worn left front wheel bearing during loading process and frantically try to find replacement. Rally community comes through and delivers two spares to the event Friday afternoon.
Friday Sept 18. Arrive just south of Ontario Canada for rally and install new upright/hub/wheel bearing assembly and re-align car. Test drive reveals that replacement parts also fixed the darting steering and soft initial brake pedal as the wobbling bearing was kicking the brake pads back into the caliper. Bonus! Saturday Sept 19. Attempt to drive car in a swift but (mostly) controlled manner. Learn that you are actually going really fast. Eventually go a bit too fast in the dark & rain and end up cleaning a ditch. This leads to a broken axle at the stub. The stub holds the wheel bearing together. Yes, the same wheel bearing you just replaced. But this time it really comes apart and car is undriveable… Stand in the cold rain and the very dark woods with dedicated spectators for 2 hours waiting for the trailer to come. We even managed to get it onto the trailer somehow without a come-along. Sunday Sept 20. Decide to head home rather than thrash all night and morning with no service crew as we had to drive home immediately after the rally anyway and planned to drive shifts through the night. This was a good plan as about 7 hours into my drive, the trailer had a braked-axle bearing failure that quickly turned into a brake fire. Even with a Good Samaritan’s assistance, it took nearly 3 hours to get back going. Spent a lot of time with a small hammer, a cold-chisel, and a hacksaw blade wrapped in tape getting the axle stub ready to accept the replacement bearings…. In the dark. By myself. Again… Besides the curse of 3 damaged wheel bearings we learned a few other important things: 1) The TDI is competitive. We set the fastest stage time (tied with Gary Donoghue in his Evo9) on the very first stage and set a bunch of fast times on the remaining stages as well. 2) The TDI is easy to drive. We had worried that the torque would cause issues with putting down power in a controlled manner on gravel. The car makes approximately 160hp and 300 lb-ft with the torque available from 1800rpm to 4500rpm. Wheel-spin could prove a challenge but was not an issue. I am sure it would be awful on snow and ice but on hard packed dirt, gravel and sand, each with and without heavy rain, it proved to be no problem at all. 3) It is hard to tell how fast you are going in the TDI. Unlike the 7300rpm gas motor, the TDI does not give you the visceral experience of screaming speed. It makes nearly the same chugging noises and pulling feelings at 2500rpm as it does at 5000rpm but you are going twice as fast. And the car feels about the same too. So, in 4th gear, you can be running anywhere between about 52mph (at 2500 rpm) and 104mph (5000 rpm) and not feel much difference. I have been calibrated to the gas motor so I never have to think about this but found myself approaching corners quite a lot faster than I had expected in the TDI. I will probably acclimate quickly and sub-consciously to this. 4) There is still a mystery source of water intrusion (beyond the water coming in the roof vent seen in the video). Multiple garden-hose and pressure washer tests of the firewall and outside of the car have failed to turn up a substantial leak. Water still fills the floors during even modest rain events… 5) Don’t clean ditches. You will break stuff. 6) Charge camera battery & adjust settings before event... Only got one stage of footage. Park expose interview www.youtube.com/watch?v=pHsSj24x5X4&feature=youtu.be Stage 1 (the stage referenced in point #1 above) www.youtube.com/watch?v=k4GB_YuYvRA ____________________________________________________________- One. Class -- 2WD www.quantumrallysport.com http://www.facebook.com/home.php?#/pages/Quantum-Rally-Sport/281129179600?ref=nf Edited 3 time(s). Last edit at 09/21/2015 04:52PM by Josh Wimpey. |
BobOfTheFuture Rob Mega Moderator Location: LI, NY Join Date: 09/25/2010 Age: Settling Down Posts: 629 Rally Car: None, anymore. |
Dante Allan Dantes Junior Moderator Location: Herman, MI Join Date: 01/27/2006 Age: Midlife Crisis Posts: 176 Rally Car: 87 Mazda LSRX-7 |
Any estimates on fuel mileage with the diesel?
And awesome job on the return! Y'all were flying! Owner, Driver, Head Mechanic, and Janitor at Tower City Race Team, headquartered near L'Anse. Michigan. Driver / CoDriver in Rally America, NASARallySport, ARA, AMS, UPMDA, Champ Off Road https://www.facebook.com/TowerCityRaceTeam/ https://www.instagram.com/towercityraceteam/ |
I clocked 50.5 mpg on the highway a couple weeks ago (steady 75-80mph) We averaged about 38mpg in combined mountainous back roads and gravel testing Not sure of mileage on stage but I would guess it is around 20mpg stage only... Thanks, ____________________________________________________________- One. Class -- 2WD www.quantumrallysport.com http://www.facebook.com/home.php?#/pages/Quantum-Rally-Sport/281129179600?ref=nf |
KTurner Kevin Turner Junior Moderator Location: Newark, DE Join Date: 01/27/2006 Age: Midlife Crisis Posts: 364 Rally Car: 2wd Impreza... dude you should do an sti swap |
too bad that bearing didn't last long. we were hoping for a good run but our ring and pinion ate itself (after 16 stage events): not sure why, might have hit a rock, can't imagine the 2.2 is making too much power for it. Went home early as well.
-KTurner Stomp down on the exhilarator and hold on to the wheel. |
Eric Langbein lost the R&P at BRS last year in our other VW after about 40 events....
Rocks & jumps can generate quite the driveline shock... ____________________________________________________________- One. Class -- 2WD www.quantumrallysport.com http://www.facebook.com/home.php?#/pages/Quantum-Rally-Sport/281129179600?ref=nf |
si John Farnsworth Infallible Moderator Location: Chicago, IL / St. Louis, MO Join Date: 03/01/2013 Age: Midlife Crisis Posts: 54 |
Couldn't say it better - was great to meet & talk to you. Was surprising how many cars out at BRS had come from a long distance like we had, and had run in the midwest before (100AW). I'm not as social as a lot of the other rally folk, so it's rare I meet and talk to people who run at the top. You, Greg, and Gary were all absolutely flying out there. |
It was interesting to watch you grab the shifter a couple of times and then decide not to shift. I know I sort of use the gear/rpm to figure what the approach speed should be - a 3+ is generally low third, a 3- is second, and so on. Since the notes vary from event to event depending on who's making them, it usually takes me about a mile or so of the first stage to calibrate myself but it happens pretty quickly.
Jimmy bitches at me if I ditchhook too much. Maybe Jeremy should bitch at you more. I was wondering if those axles would hold up under that kind of torque. Sounds like they did, but don't have much room for extracurricular activities. Self-righteous douche canoe |
wvonkessler Wilson von Kessler Senior Moderator Location: Lookout Mountain, GA Join Date: 02/28/2006 Age: Possibly Wise Posts: 1,127 Rally Car: Colts are in Finland; now '87 325i, '89 325i |
How are your emissions tests on the diesel?
Yeah! Noticed any black helicopters hovering over the garage? John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
RALLYRS Mike Ball Super Moderator Location: Simi Valley,Ca. Join Date: 07/15/2011 Age: Ancient Posts: 466 Rally Car: Nope...I wish...RWD 2 Door Jeep XJ 4.0 5-spd Dirt-o-cross car(we have no grass!)2.3 ZX3 rallyx car(sold) |
Yes Herr Winterkorn let the cat out of the bag.
Now we know why you're so fast Josh. Handy hint-when that letter comes in the mail that says you need to bring your car into your local VW stealership for them to "upgrade" your ECU... just throw that letter away! ................................................. ..................... Support your Local North American Rally Forum!! While they are still around-and get the hell off Farsebook!! We still have Specialstage & RallyAnarchy. Post up Here: https://rallyanarchy.com/phorum/posting.php and here: https://www.specialstage.com/forums/forum.php |
I give it 6 months before craigslist ads tout "recall not performed" in an effort to gouge more money out of the buyer. |
Our TDI is from a 2001 Golf so it is unaffected anyway.
Plus, it is registered as antique so no yearly inspections ____________________________________________________________- One. Class -- 2WD www.quantumrallysport.com http://www.facebook.com/home.php?#/pages/Quantum-Rally-Sport/281129179600?ref=nf |
But post-76 cars are still required to meet their applicable emissions standards under U.S. Law. "Talk about drugs. Driving a car like that, going that fast, it’s like all the drugs at once." - Tommy Byrne "Now, Pinky, if by any chance you are captured during this mission, remember you are Gunther Heindriksen from Appenzell. You moved to Grindelwald to drive the cog train to Murren. Can you repeat that?" - The Brain |
I am sure it meets the 1986 standard just fine :-)
