> So this is theoretical based on the specs of the
> wheel. The wheel is 15X7 et 35. So, the wheel
> should be 177.8 mm wide, which gives the center
> line at 88.9 mm. Therefore, the 35 mm offset
> should make the mounting face at 123.9 mm from the
> back of the rim.
> Justin Pritchard had asked me about my
> Compomotives and was trying to figure out if they
> would fit on his Escort. He needed the distance
> from the inside mounting fact to the inside of the
> wheel to make sure it wouldn't rub on his
> 'spenders. I'm going to try to measure by hand
> tonight to make sure, but thought I'd see if my
> theory is correct there?
Theories???
Send him one wheel to find out.
Read the "ET"
And compare what an Escort wants at about ET ZERO and I think you can see there will be problems.
> Grant Hughes
> Denver, CO
> 25 years old
> No car yet, between a Merkur and a Volvo 240
