Is this calculation correct? Wheel spacing.
Posted by NoCoast
February 02, 2006 09:37AM
So this is theoretical based on the specs of the wheel. The wheel is 15X7 et 35. So, the wheel should be 177.8 mm wide, which gives the center line at 88.9 mm. Therefore, the 35 mm offset should make the mounting face at 123.9 mm from the back of the rim.
Justin Pritchard had asked me about my Compomotives and was trying to figure out if they would fit on his Escort. He needed the distance from the inside mounting fact to the inside of the wheel to make sure it wouldn't rub on his 'spenders. I'm going to try to measure by hand tonight to make sure, but thought I'd see if my theory is correct there?
Re: Is this calculation correct? Wheel spacing.
February 02, 2006 10:25AM
> back of the rim.
Theories???
Send him one wheel to find out.
Read the "ET"
And compare what an Escort wants at about ET ZERO and I think you can see there will be problems.
> Grant Hughes
> Denver, CO
> 25 years old
> No car yet, between a Merkur and a Volvo 240
February 02, 2006 12:23PM
> Theories???
> Read the "ET"
Theories in the calculation I suppose. He's in the Great Lakes region. I'm in the Beer and Mountain region. Back and forth shipping on a wheel would cost money. I'm bringing one to 100 Acre Woods to test fit possibly.
ET 0. Sweet. That simplifies stuff.
Pssstt. May have found another Merkur. Calling on it tonight. Also found five 2 door 240s.
