VALVE SHIMS
Posted by tdrrally
tdrrally
edward mucklow
VALVE SHIMS
September 07, 2014 03:31PM
i'm looking for information on vw and volvo valve shims
diameter is the big point of interest at this point
danster
Haggis Muncher
VWs (for my sins)
Re: VALVE SHIMS
September 07, 2014 03:56PM
VW 8v shims are 31mm OD.
The tappets / cam followers are 35mm OD.
tdrrally
edward mucklow
Re: VALVE SHIMS
September 07, 2014 04:00PM
cool i will measure my suzuki shims to see if they will work
thank you
Robert Culbertson
Out of this dumpster fire
Re: VALVE SHIMS
September 07, 2014 10:07PM
Memory tells me that Volvo uses 33mm diameter shims
tdrrally
edward mucklow
Re: VALVE SHIMS
September 08, 2014 08:20AM
suzuki sx4 valve shims measure at 30.5mm so is the 31mm vw shim a true 31mm or is it a bit smaller?
danster
Haggis Muncher
VWs (for my sins)
Re: VALVE SHIMS
September 08, 2014 08:31AM
The VW shims are a true 31mm OD.
The recess in the top of the tappet / cam follower that locates the shim is 31.1mm ID.
Edited 1 time(s). Last edit at 09/08/2014 08:31AM by danster.
tdrrally
edward mucklow
Re: VALVE SHIMS
September 08, 2014 08:51AM
ok,i wonder if toyota or some other company uses a 30.5mm shim?
Re: VALVE SHIMS
September 08, 2014 02:49PM
I have Toy 3.0 V6 shims and they measure 34mm.
Robert Culbertson
Re: VALVE SHIMS
September 08, 2014 03:25PM
So what exactly are you trying to do...?
tdrrally
edward mucklow
Re: VALVE SHIMS
September 08, 2014 06:54PM
adjust the valves on my daily driver sx4
suzuki wants a painful amount of money for shims, so i'm looking for an affordable alternative
i may try the 29.5mm suzuki bike shim
Re: VALVE SHIMS
September 08, 2014 08:43PM
$1800 for a shim kit...what are you sniveling about ? Jeebus thatsa lotta scheckles.
tdrrally
edward mucklow
Re: VALVE SHIMS
October 18, 2014 06:01PM
i scored a complete set of new shims for the right price today
let the good time not tick!
