Morison Banned Senior Moderator Location: Calgary, AB Join Date: 03/27/2009 Age: Ancient Posts: 1,798 Rally Car: (ex)86 RX-7(built), (ex)2.5RS (bought) |
You know a lot of valuable things... like everything in this post. Very good points. Seems to me the Impreza I rallied, which was build by Dave Clark, had washers for the skid plate that were also protection for the bolts. They actually were the same depth as the bolt heads but tapered down to being virtually flush with the skid plate. Same as having holes in the right places on your skid plate. One local just added some holes so he can change the LCAs on his focus without dropping the skidplate. Thinking ahead is good. First Rally: 2001 Driver (7), Co-Driver (44) Drivers (16) Clerk (10), Official (7), Volunteer (4) Cars Built (1), Engines Built (0) Cages Built (0) Last Updated, January 4, 2015
wildert Brian Klausen Ultra Moderator Location: Denmark Join Date: 03/21/2006 Age: Midlife Crisis Posts: 388 Rally Car: VW Golf GTi 16V |
I have carriage bolts on my sump guard, since it is a "plate to frame"-type-o-thing.
I selected the carriage bolts specifically for low profile as well as being able to ignore damage to the heads. ... good thing I did. The front ones are about ready to be replaced due to being "flush mounted" now... Also, I had pretty long eyelets for the crotch straps of my belts. Long enough that something like a full inch or so poked through the welded nut on the backside of the strengthening plate on the floor. Let's just say that they are no longer poking a full inch or so through... but they are a right pain in the rear to get out, since the threads are messed up. Obviously that doesn't add to user friendliness when it comes to getting them back in either. I vote for either moving, or adding some protection - you will like it . Brgrds Brian Edited 1 time(s). Last edit at 11/22/2014 02:39PM by wildert. |
Fixed that for you... First Rally: 2001 Driver (7), Co-Driver (44) Drivers (16) Clerk (10), Official (7), Volunteer (4) Cars Built (1), Engines Built (0) Cages Built (0) Last Updated, January 4, 2015
Kyle Kyle Heacock Professional Moderator Location: Portland, OR Join Date: 03/04/2013 Age: Midlife Crisis Posts: 21 Rally Car: 81 volvo 242 |
Got the pedal box mounted today.
I bolted the third member into the rearend so I can measure for a driveshaft. Looks like I am going to have to make more room farther back in the tunnel for driveshaft clearance, since the pinion flange is offset to the passenger side quite a bit. Going to get a driveline started tomorrow, and will hopefully have it by the end of the week so I can work on making it fit this weekend.
I also hope to get the rear shocks relocated on the axle, I need to move them inboard for tire clearance, and I will likely have to move them higher up on the axle tube. Right now, when the shocks are bottomed out, the pinion flange is contacting the floor and the watts link is bottomed out as well. I'd like to have a little bit of space so the bumpstops can do their job. This should also help with driveshaft clearance in the impossibly tiny volvo tunnel. |
There is officially nothing left of the factory driveshaft tunnel. I picked up the driveline on Friday, installed it, and jacked the axle up (without the springs in place), and the driveshaft contacted the tunnel with 2" of travel left on the shocks. Many hours later, the new tunnel is mostly done. This would have been a really easy project if I had done it before the seat mounts, oops.
I also got a motor, bellhousing, and some miscellaneous parts off of a car that was destined for the scrapper, and scored an extra Supra LSD and 2 RX7 oil coolers from the junkyard. It's about time to start mapping out the engine build and figure out the throwout bearing. I think I'm going to use a tilton made for the T5: |
Tilton, Howe, and Ford both make hydraulic TO bearings. The ford one will usually over travel if used with the wrong master cylinder. Howe and tilton have more stroke in the throw out bearing.
You can also go cable, or push pull slave cylinder. There are kits that use the stock Volvo clutch release arm with stock Volvo TO bearing, and a kit that uses a mustang TO bearing. Too many options out there, I tell ya! |
I'm planning on using a JVL flywheel setup.
That last post was supposed to have a link to the tilton bearing I had in mind: it mounts on a threaded tube that goes over the TOB sleeve on the input bearing retainer. I'm going to have to open up the volvo bellhousing so the T5 bearing retainer can still be used. |
Fly-Half Roderick Thomas Godlike Moderator Location: Houston, Texas Join Date: 02/02/2014 Age: Settling Down Posts: 42 Rally Car: I have one now |
Think about the annular type---how much fun bleeding and replacement/service and how much fun it would be pulling the gearbox to cure a little leak vs external slave..
Sorta like the genii who have external fuel pumps who go to a lot of trouble to make the submerged---and oh so quick and easy to dig into the tank to service/replace...compared with external---repositioned somewhere easy and safe. |
This! I replaced the clutch and slave cylinder on my old f150, get it all back together aaaaaaannnnnd the slave cylinder leaked right out of the box. I would highly recommend an external slave mounted to a bracket. Volvo actually did this. Turbobricksawesomeness of ghetto Ghetto version of 740 slave + 240 release arm: |
