Volvo 1030 axles
Posted by Eric Ewert
tdrrally
edward mucklow
Re: Volvo 1030 axles
October 12, 2014 11:05AM
if i were working on this project i would redrill the front to match the toyota rear rather than redrill the rear to match the volvo front
mellow65
Oliver Klozoff
Nada
October 12, 2014 11:26AM
Ascona73
mellow65
You are correct, yet no one seems to believed me when I tell them you can get a 8" and a 5 lug. Some 2wd V6 trucks came with a 2wd width, 8" 3rd members and 5 lugs. I owned one.
2wd trucks with 4-speeds were 8" rears. 5-speed trucks were 7.5". I'm talking about '84-'88 with 22r engines.
I do know that I got mine from a late 80s/early 90s 2wd v6 automatic, but came with a 4 cyl 3rd. The 2wd widths are 56", which is right in that volvo range right?
Eric Ewert
Eric Ewert
volvo 240
October 12, 2014 05:43PM
What am I doing with my life? You are all horrible people. drinking smiley
open | download - P1040346.JPG (47.1 KB)
tdrrally
edward mucklow
October 12, 2014 05:51PM
cheaper than drugs or therapy
how much less i'm not sure sometimes
Eric Ewert
Eric Ewert
volvo 240
October 12, 2014 06:00PM
You know I think one day I did the math, drugs might be cheaper.
October 12, 2014 06:03PM
Eric Ewert
Never do the math.
Eric Ewert
Eric Ewert
volvo 240
October 12, 2014 06:38PM
Eric Ewert
Never do the math.
I hit my head when pulling the axle out and forgot it. So I may as well of not done it.
tdrrally
edward mucklow
October 12, 2014 07:30PM
it sounds like money better spent with the toyota axle
even the 7.5" toyota axle is hard to kill
but for quick turn around the stock axle is a way to go
toyota axle with new aftermarket brackets
toyota vans with an auto trans had a 7.5" with a 4.30 gear
October 12, 2014 10:07PM
Never do the meth.
Fixed that for you
Edited 1 time(s). Last edit at 10/12/2014 10:08PM by Morison.
Eric Ewert
Eric Ewert
volvo 240
October 12, 2014 10:54PM
Well... now what. How many cups of tea do we recon are needed to jam this thing in there?
October 12, 2014 11:00PM
Eric Ewert
Time for a few quick episodes of Project Binky...
Tea seemed to solve most of their problems.. always worked for me too..
If I could have a cup, then life wasn't tooo bad..
Robert Culbertson
Out of this dumpster fire
October 13, 2014 12:12PM
I have yet to switch over to tea, I'm WAY into coffee.
Some info on the 2wd Toyota 8in: The axles are near impossible to find if you ever bend one. A good friend bent a flange from sliding his truck into a curb on a slick, icy morning. 2 years later he finally found some decent used axles.
The 7.5 rear end would probably be okay, but I couldn't find too many LSD options for them. Gears are available though.
October 13, 2014 01:57PM
A local kid with the monster tire Toy hit a pipe protecting the gas island at a filling station, snapped that axle right off at the backing plate. Low speed but solid hit. I couldn't believe it. Housing was bent so we replaced it all.
A1337STI
Alex Rademacher
93 GC with an 01 RS swap!
October 13, 2014 02:18PM
I'll have to dig up the part number (again) , but the front R&P ends up being ~ 230 on subaru-parts.com and most local dealerships will price match if you print out price sheet.
and you can pick up a used 4.44 R&P from a pick and pull. for about $80-90, or $40-45 on a half off day (there are several every year)
and bingo $300 for your 4.44 parts. labor is the sticky wicket, i've got free labor if i wait . which is how i ended up with all the right parts, sitting in a box for my last 5 rallies .. sad smiley doh
A1337STI
Man .. this thread makes a final drive / LSD upgrade on a subaru look Cheap and Easy... (well it is easy) $300 for the finals. $45 extra for a rear plated lsd. $400 or $40 for a front ... winking smiley
but man. that sucks.. i hope you find an easier / cheaper short cut some how
That sounds cheaper than I've ever seen.
October 13, 2014 03:55PM
Robert Culbertson
Yeah. Not too many diff options for the 7.5. And they have a shit-load of tiny springs..
And really the difference is only a little bit from Dana 30's 7.2" size to 7.5" ...and, how big are the half shafts?
First you suggest overkill, then you bring up Pfffft little difference...
You know there ARE solid reasons why I suggest things ....I don't make anything by this ---except for the little tabs for links and shock mounts but thats pennies
You just like that said "oh 4.1 works fine"..
Maybe for your rally car.....but this kid is bright enough to do that math and understands that pissing away 14% is going to have a direct effect on how quick the car accelerates...
Do you understand gearing?
14% is a lot, especially if it costs nothing..
