fliz Chad Eixenberger Mod Moderator Location: Grafton, WI Join Date: 02/01/2007 Age: Midlife Crisis Posts: 484 Rally Car: 1988 VW Golf #687 |
wvonkessler Wilson von Kessler Mod Moderator Location: Lookout Mountain, GA Join Date: 02/28/2006 Age: Possibly Wise Posts: 1,127 Rally Car: Colts are in Finland; now '87 325i, '89 325i |
Talk to Wimpeys, also USRT.
At least three companies do itb rigs: Jenvey, Weber Alpha and TWM, oh and also Dbilas. But 220 without internal mods will be hard.
Hey Kurt, you know if the intake manifold bolt up is the same on your head as the old 1800 16v?
Or can it be made to work? Cause I just happen to have an intake manifold for Weber DCOE or ITB with that bolt pattern. And I would make sure you talk to somebody with at least some experience building 2 liter n.a. rally motors in that HP range..... Who could we find? WHO??? WHO!!!!??? WHO!!!!!!!!!!!!!!!!!!!!!!!!!! Just check and he said "sheeeut 200-220 and I shore as hell would be worried about how peaky or cammy or whatever the motor would be and how hard the motor's gonna fall down on gearchanges---unless the guy has a honest to god close ratio box" You have a real close ratio box? John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
All the internal engine work has been done less the cams. I am going to upgrade the injection before swapping in the cams. I may need to notch the pistons with the new cams. This is why I have not swapped them in yet and the fact that peeky cams are not the best for winter Canadian rallys. I have a Mikuni setup with manifolds already but I have been told that they tend to ice up in cold weather by people that have used them in winter rally.
Save millions! Sling those fawkers on. Chop up some ol buckets and make a warm air intake for winter.. (I had nice icing on my set up but according to the ex-spurts, I never did anything so if I didn't open the throttles no air would flow so no evaporation of fuel, no icing...Good planning on my part!) Remember the carbs on my car are over 17-18" from the motor... John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
BobOfTheFuture Rob Professional Moderator Location: LI, NY Join Date: 09/25/2010 Age: Settling Down Posts: 629 Rally Car: None, anymore. |
Paulinho Ferreria? Kris Dahl? I'm having a hard time thinking of any other Honda guys that might have built their engines. Pretty sure a VW never gets to that kinda power level NA and actually have it last more than a drive around the block. Oh wait, I guess I should think about rotary powered cars also. Grant Hughes |
No, Grant I was think more the guy who built the 2.0 16v that beat both Kurt and I way back in the 90s and who built this one, 2.0 16v YB: So guess again John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
This Lehmann motor in a Golf IV Kit Car is alleged to be making 298 horses. I know that the the Lehman motors in the Golf III Kit Car made at least 260.
https://www.facebook.com/media/set/?set=a.161917520497330.30325.161484717207277&type=1 "Talk about drugs. Driving a car like that, going that fast, it’s like all the drugs at once." - Tommy Byrne "Now, Pinky, if by any chance you are captured during this mission, remember you are Gunther Heindriksen from Appenzell. You moved to Grindelwald to drive the cog train to Murren. Can you repeat that?" - The Brain Edited 1 time(s). Last edit at 12/04/2014 02:36PM by wvonkessler. |
tdrrally edward mucklow Mod Moderator Location: charleston,wv Join Date: 05/31/2011 Age: Possibly Wise Posts: 763 Rally Car: ford mustang LX 5.0, 1973 VW Beetle |
Chris Eyre Chris Eyre Mod Moderator Location: London, UK Join Date: 09/07/2014 Age: Possibly Wise Posts: 39 |
Realistic power levels on the tallblock 16v / ABA 16v clones are:
- 170bhp for a standard engine with management - 180 for a standard engine with management and ITBs - 190 for a standard engine with management, ITBs and mild cams Onwards and $-upwards from there, 250 is your ceiling. Most wallet bump stops kick in long before that. Big cams, compression, 210 to 230. 260 to 280 quoted on Lehmann's 16v finest, on the finest fuel available, with the most finite service intervals, with some fine Pankl long rods (>159mm), fine titanium narrow stem valves, and short skirt 84mm Mahles, pumping up and down on a 90mm bespoke crank grind, and mapped to the hilt on a Bosch Motorsport ECU. Nice to think about, thousands to fund. ECU-wise, Megasquirt, DTA, Haltech. Under-graph torque benefits over carbs all day long. Fuel and spark tables to hand over control to to you! Maybe, just maybe, it’s down to the driver. VWMotorsport.info | SeatSport.info | 4 VW Golf Mk3 A59s exclusively revealed > here < Edited 2 time(s). Last edit at 12/04/2014 05:52PM by Chris Eyre. |
Realistic? Reliable? Rallyable? Makes the 240 bhp stock on an S50 swap into a BMW seem pretty nice. Or the 190 or whatever a Merkur is rated at. I'm aiming for 300-350 range on my Merkur but I gotta try to keep up with Kern's S54 330 bhp swapped BMW. I think we are almost out of VWs down here. One really nice one that the guy will probably keep forever and he just does occasional hill climbs with it. Grant Hughes |
