NEED CELICA ALLTRAC SUSPENSION st165 st185
Posted by notmach1
notmach1
December 17, 2014 12:55PM
We are in need of all the the rear control arms for a celica alltrac st165. We would like all of them but Specifically need the tow adjuster bar for both sides. That particular bar is the same for the later st185 model.
If anyone has anything let me know asap. email: notmach1 at yahoo.com
Peak City Rally Crew Chief
www.facebook.com/peakcityrally
Re: NEED CELICA ALLTRAC SUSPENSION st165 st185
December 17, 2014 07:31PM
I'd give William a shout http://tssfab.us/wp/ He can make nearly anything along those lines.
czwalga
steve czwalga
95 awd celica
December 17, 2014 08:36PM
Build your own similar to tssfab but buy stock parts. I had a ST205 GT4 rear; those control arms like tooth picks. I'd bend them without even hitting anything.
notmach1
December 18, 2014 06:42AM
We are going to plate and gusset the factory arms. The biggest issue is cost right now. We have some fully adjustable tubular ones on the drawing table but its just not going to happen before Sandblast in March.
tdrrally
edward mucklow
December 18, 2014 06:53AM
did the alltrac camry use the same suspension ?
notmach1
December 18, 2014 08:49AM
Only the toe bar and only for 2 years so they are just as hard to find.
czwalga
steve czwalga
95 awd celica
December 18, 2014 09:45AM
You could build a set for probably $120-150 bucks with half decent heim joints. May have to get properly sized washers or something to use spacers.
notmach1
December 18, 2014 09:59AM
The biggest issue is the upper bushing it has the adjusting cam in it. Thats why an adjustable set would be easiest. Just eliminate the cam on top.
czwalga
steve czwalga
95 awd celica
December 18, 2014 10:51AM
notmach1
Swedged steel tubing and heim joints are more than adjustable. So adjustable that I adjusted my rear wheel out too far and pull the axle out of the diff housing at full droop haha.
