fabianp PIERCE FABIAN Junior Moderator Location: Vancouver, BC Join Date: 02/19/2015 Age: Midlife Crisis Posts: 46 Rally Car: '96 Jetta |
Clarification:
I purchased this 4.46 final drive from this list: http://www.mts-motorsport.com/epages/61752271.sf/en_US/?ObjectPath=/Shops/61752271/Categories/Getriebetechnik/Achsantrieb/%22VW%20020%20/%2002K%20Getriebe%22 I am running your typical run-of-the-mill 020 from a 2.0L mk3 Jetta: transmission code CHE. It has been installed, and the rest has been shimmed, but when it came to the final assembly of the gears the splining and width of where 4th sits is substantially smaller. HOW IS THIS SUPPOSED TO BE AN UPGRADE? ...And they say it is for an 8v when if I need a 16v 4th gear it is for a 16v (at this point quite old). See the difference in the image: Edited 1 time(s). Last edit at 03/30/2015 04:43PM by fabianp. |
Sorry, corrected now. I had to drive out to the shop as I was clearly missing something when talking on the phone with a bad connection. It is indeed the fitment of the 4th gear onto the new supposedly better final drive. Pictures posted in thread. |
Erik Christiansen Erik Christiansen Super Moderator Location: Culver City, CA Join Date: 05/16/2008 Age: Possibly Wise Posts: 73 Rally Car: VW GTI |
As with all things 020, Broke has the answer: http://www.brokevw.com/020rebuild8.html
For mk3 '93 through June '97 8v 020's they use the same larger spline for 4th gear as the mk2 16v's. VW switched back to the skinny splines in June '97. It looks like you purchased an 8v R&P when you should have bought a 16v. The good news is you can still use it if you can find a mk2 8v 4th gear. People do this all the time when swapping in OEM 4.25 final drives. The "8v" and "16v" nomenclature for 020 transmissions doesn't apply to mk3's. Your CHE transmission has the same larger input shaft and larger fourth gear spline as the mk2 16v transmissions (2Y and AG, despite being mated to an 8v engine. |
There is a bit more gearbox info in this thread. Including crownwheel bolt sizes.
http://www.rallyanarchy.com/phorum/read.php?7,103092,103135#msg-103135 Disappointingly not yet a Jackass |
mwalters Matt Walters Super Moderator Location: Staunton, Va Join Date: 02/21/2012 Age: Midlife Crisis Posts: 7 Rally Car: Cheveo grass-o-cross beater |
Not sure about this, my mk4 GLI ('03, 24v) has solid rears. |
Not sure where you get that information from. The 020 is a perfectly fine transmission and lots and lots of people run them without problem. They are better than the 02A/02J boxes in a number of ways: 1) they are about 23lbs lighter 2) They use the smaller clutch-flywheel-pressure plate setup which saves even more weight. 3) The cable shifters are a known weak spot. The rod shifters work great if you start with fresh rubber & plastic bits. 020 weaknesses relative to 02A/)2J 1) Can handle less torque 2) Cast aluminum trans-mount arm is weaker due to shift linkage mounting It used to be the case that the 020 was getting hard to get parts for but now there are more options than there were 10 years ago and no reason to abandon the 020. ____________________________________________________________- One. Class -- 2WD www.quantumrallysport.com http://www.facebook.com/home.php?#/pages/Quantum-Rally-Sport/281129179600?ref=nf |
DexterVW David Baker Senior Moderator Location: Rhode my Island Join Date: 11/20/2008 Age: Midlife Crisis Posts: 290 Rally Car: 95 GTI TDI |
Sorry I was mistaken, it was 20th/337's http://www.parts4vws.com/catalog/product_detail.asp?PartNumber=10%2E1ConvKit+%2F+Mintex |
Youe right, it is certainly a matter of priorities just like you have mentioned above. I know many of you guys apreciate the 020 (of various ages and configurations), and others prefer to avoid them. Its great to hear infput from both side. Thanks so much. For this application, I'm not crazy about the idea of running an even older 4th gear on a skinnier counter shaft (22mm) compared to the relatively unused stock 4th gear on the larger diameter counter shaft(24), but beggars can't be choosers in this case, I suppose. If this is what I need to do to make use of the 4.46 final drive R/P work in the 020 that I have got ... then I guess thats what is going to have to happen. |
You could always look at it this way, the smaller 22mm shaft means the actual gear has more meat on it.
I haven't heard of the shaft splines failing before. I also notice from the pic posted above that the MTS output / pinion shaft is shorter than the stock part, and as a result it does not make use of the outer bearing for support in the 5th gear housing. Disappointingly not yet a Jackass |
No need for vented rears, they will just get packed full of dirt & mud anyway.
The rear brakes do virtually nothing. At static ride, the rear wheels each have less than 400lbs over them and as soon as you hit the brakes, it is far far less than that... In addition, we have 'blued' the rear rotors in the past with zero consequences on tarmac. The vented rotors just cost more, weight more, and require unobtainium calipers and carriers.
...some cage-in-progress shots.
Nice toight fit. |
