floor mounting seats, need ideas
Posted by Snidewhips
Snidewhips
Jeremy Livingston
1990 acura integra, 2010 Hyundai Genesis Coupe
April 20, 2015 02:27AM
hey guys just finished my floor pans to keep my seat low enough i don't die when my swoopy knuckles spontaneously combust. need some idea's on how to weld completely to the floor the perimeter of the fabbed floor pans, the fit is good on tunnel side and sill side but the droop of the floor plus stamped pleats make it difficult to ties it down as a single entity while keeping a level pan (i could heat it and force it but mounting a seat to a bowed surface seems dumb)
ideas ive had
-make a template of the floor pattern outta cardboard for the front and rear cut the intricate thing out with a torch and hope all goes well
- weld tunnel and sill, try to bash the floor level as possible 1/4 inch almost in a couple places and weld front and rear as well as plug weld through drilled out spot welds and hope this doesn't bow
- run flat bar in grooves, weld to floor then weld plate to flat bar ala plug welds as well as front and rear surfaces filling gaps with tedious welding, this method also ups the weight factor and i feel is a structural patch.
some explanation of pics before i get my throat cut.
has to zip tunnels to narrow tunnel to fit fat seats, structure will be welded from underneath to pans as well as tunnel reinforced from underneath with custom fabbed braces
square or round tubing is not an option as i onlt have 5 1/2 inches to roof with helmet and hans on. (i'm 6'4)
All bridges burnt, island life is beauty
open | download - image.jpg (39.6 KB)
open | download - image.jpg (27.4 KB)
open | download - image.jpg (37.1 KB)
Re: floor mounting seats, need ideas
April 20, 2015 09:06AM
put your name up someplace. There's no thing "heroic" or "ironic' or "making a point.
You have corregartions, its gonna be resting on the high spots.
Zap them down---I assume there is substantial overlapping of the parts----like an inch or so----
Once its tacked on all the high spots, start welding and pound down the thin stuff as you go.
No fun.
April 20, 2015 12:08PM
You absolutely need to consult with your local scrutineer to determine if your design is legal.
Overlap the metal and then squish it together before you weld. AFTER YOU ARE SURE ITS LEGAL!
tdrrally
edward mucklow
April 20, 2015 12:21PM
i have the same issue, i'm 6'2" and building a fox mustang
so reworking the floor is where a good amount of my time is going
here is what someone did to their car to get race seats to fit and sit a bit lower
very nice
john correct me if i'm wrong but is this an xratty?
April 20, 2015 01:04PM
tdrrally
very nice
Yep.
Snidewhips
Jeremy Livingston
April 20, 2015 01:47PM
cant do it takes away vital clearance as mentioned in my can't dos and i have tried when wrestling over complicated fia cross mounts. this works just wanna keep the trays level, working on as i type a talent ive developed since changiing my legal name to jermama
Snidewhips
Jeremy Livingston
April 20, 2015 01:50PM
its legal as well sandwich plates will be used to connect to floor tray. and i did mention ill be overlap welding to trays
April 20, 2015 07:31PM
This is what I found from my Lemons car build...definitely took a little work to make it work, but passes Lemons tech easy-peasy.
April 20, 2015 10:44PM
It seems to me that a 6'5" dude should stop trying to rally Hondas and get something with room to spare like an E36 BMW like an adult. smiling smiley
Snidewhips
Jeremy Livingston
April 21, 2015 01:27AM
thatll be next grant, this aint a whole buncha work plus i just wanna have a season to run and decide if its something financially affable, a bucketlist if you will. on the bmw front cars aint as cheap here as you yanks get em for so bmw aint so cheap to do, subaru on the other hand...
don't get me wrong i think 2wd is where its at but at the rate frs s and brz s are depreciating...
oh oh i gotta winter beater
it isnt blue
open | download - image.jpg (56.1 KB)
open | download - image.jpg (41.8 KB)
April 21, 2015 01:48AM
I will not logbook or accept at an event a car with the seats bolted to the floorpan. It is too flimsy.
If you were to make some crossmembers welded in securely to the center hump and outer sill and/or cage, and then made some sort of drop mount so that the seat was securely mounted to them but sat down below their height, I might be ok with that depending on how it was done.
FWIW, I am not a CARS scrutineer. I am, however, a Rally-America and NRS one.
Snidewhips
Jeremy Livingston
April 21, 2015 02:05AM
fia documents clearly recognize sandwich plating as acceptable practice when mounting plate is welded to chassis, the plate is protection in case of floor contact. when the tunnel is reinforced from top and undercarriage flimsy won't be the issue..
Towona
Tony P
MK2 Golf
April 21, 2015 05:27PM
PREPARE YOUR ANUS
Runamuck Rally
April 21, 2015 06:41PM
Towona
PREPARE YOUR ANUS
smileys with beer
Snidewhips
Jeremy Livingston
April 22, 2015 02:39AM
For??
