aj_johnson A.J. Johnson Godlike Moderator Location: Pendleton OR Join Date: 01/07/2011 Age: Settling Down Posts: 1,381 Rally Car: 88 Audi 80 |
deaner Dane Aura Super Moderator Location: Caldwell, ID Join Date: 07/07/2013 Age: Settling Down Posts: 346 Rally Car: PS4 controller |
Americas financial system...good luck!I just got home from a 9 year old girls birthday party at a pool where I chased my toddler and 9 year old around for 4 hours. My literary comprehension is shit right now lol. I'll have to reread your post a handful of times after the ringing in my ears subsides. Hotel pools and their acoustics... Ha! At the moment I'm not picking up what you're laying down exactly. For top mounts, the only two worth a damn anymore are Compbrakes and AK Motorsport mounts. The Compbrakes have been around awhile and I've never heard of a failure, even rallying. The solid AK mounts are new to the U.S. market, but according to a bunch of euro rally guys, they're also indestructible. As they are in the "catalog," 17mm is the largest standard pin size they offer. Thoughts on turning the bilstein Motorsport upright pins to accept mounts such as these? http://www.compbrake.com/product/audi-coupe-cabriolet-top-mount-each/ https://www.akmotorsport.net/product-category/top-mounts/ |
The bushings last for years...years of 4-5 events/yr with service.. OK? Better to change bushings occasionally than have them get crap jammed into the surface and rip the inserts up. I use this because i was told by a fellow named Janne Sellholm to use it.. and I'm going to guess but I betcha he's been making hundreds of struts since a few decades before you were born, there is a small but not insignificant chance that Sellholm MIGHT know just a tad more about this subject than you..so I will trust him and observed experience in practice. There is also a cost consideration between one off playing around and production of series of this, the thing you do again and again and again: no consideration of cost vs benefit... John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Really? There was play in the bushings on Arnaud's car during the 1st event... Then we added more bushings (That we got from you), and that only lasted 2 events before they got all klunky again. That's 2 sets of bushings in a year. Maybe Derek just drives the Volvo that hard. |
dalspaugh David Alspaugh Super Moderator Location: Boston, MA Join Date: 04/30/2015 Age: Settling Down Posts: 66 Rally Car: '91 Audi Coupe Quattro |
Spoiler alert over here... jeeze Anyway, thanks for the... advice everyone (asks for $0.02 - get's 87 deutschmarks) Blog about my history with the rally car written for non-automotive folk: davescq.wordpress.com |
Did I finish that statement with, you'll have a ton of fun doing it! Grant Hughes |
But I thought all there was to fun was winning! Blog about my history with the rally car written for non-automotive folk: davescq.wordpress.com |
Any? Always gotta be careful asking me about any thoughts. Instant first thought: hack off the top of the towers, weld on a plate with three holes drilled to Subarus bolt circle...plate could cust under $10, and nSubie top mounts in better wrecking yards could be about $10/pair. Simple. Easy Cheap Works good None of which could be said for the Audi junk. Only drawback is it requires a horrible thing: thinking and even worse (gasp!) work. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Yank the front shafts. Stick an axle stub in the hub to keep the bearing together, and either weld the center diff of your 01A or swap in an 016 from a 4k (locking center diff) and shorter gears. B3 coupe quattro- 20v 90-91 trann case 01A- torsen center differential 1st-3.545 2nd-2.105 3rd- 1.429 4th-1.029 5th- .838 final 4.11:1 B2-4kquattro -1984-tranny style 016-locker center differential 1st-3.600 2nd-2.125 3rd-1.458 4th-1.071 5th-.829 final- 4.11:1 John, the subaru tops are on this winters project list. Gonna try to get some more caster out of the deal at the same time. |
But, but.. I never asked "any...." I've thought about the possibility of using Subaru stuff, but at this point in what I have going on with two builds, that type of project on top, isn't in the cards. So say for theorizings sake, turning down a bilstein 50 pin to run a mount(17mm) I posted wouldn't be an issue? AJ, have you measured to see if a subaru mount will even fit up in the tower? It's been a few months since I've had my face up there but I remember it being tight. |
If I hadn't seen it in person, I'd never believe you were married with all that perversion going on. Grant Hughes |
