Replacing Sheet Metal
Posted by Matt Bobyn
Matt Bobyn
Matt Bobyn
VW GTi
May 30, 2015 12:20PM
So I need to replace some sheet metal - car is a `96 Golf. The rocker panels have separated from the floor plan, and the pans themselves have taken a beating. I've picked up some books on this, and can weld reasonably well, but are there any really good resources on this? Other than the obvious, how do I tell whats structural and what isn't? I have an entire parts car to cut sheet metal from...
MattP
Matt Pullen
2002 Ford StRanger
Re: Replacing Sheet Metal
May 30, 2015 01:03PM
Holy cow, you did beat the snot out of the Golf at the weekend! Best thing is probably call Eric G.
Yes, it's a Ranger.
Xr4Ti, it is rwd and was made in Germany.
May 30, 2015 01:29PM
Matt Bobyn
The SILLS are the bearing members on unibody cars..The floor keeps the dirt out. The rear seat support stamping running east/west is REINFORCING part....
I can't recall whats inside a Golf sill...it may be a completely hollow box section.
But it may have an internal vertical element..
Xratties sill for example is like two D back to back like this and an extra I between
ᗡID
The vertical elements bear the load fir forces up ^ and down V, and thats a big deal...
You can see if the vertical plates have rotted cause the sill bottom has rotted, just covering the holes with a skin ain't returning car to stock strength...
Saab 96 on the other hand has a BOX section with much thicker wall than I've seen on any other unibody.. So have a look..Where floor joins the sill I like to wled in a L shaped strip off .0625/1.5mm /16g doubler just to stiffen it a bit cause the floors on all modern stuff is so thin.
Matt Bobyn
Matt Bobyn
VW GTi
May 30, 2015 01:30PM
Ha yup, she took a beating. smiling smiley The rocker panels I've patched twice already, time to just rip 'em out. I chatted with Eric yesterday about it, we came to the conclusion of just to cut and replace the entire section.
Matt Bobyn
Matt Bobyn
VW GTi
May 31, 2015 09:59PM
Thanks for the reply John. After cutting apart the doner car it looks like the double D configuration, with some other gussets added in. I'll have to wait to tear apart the rally car before I see what it looks like, but I expect it will need some internal reinforcement.
Externally it seems the outer panel's spot welds have been gravel blasted away, but who knows whats underneath.
Cheers.
Edited 1 time(s). Last edit at 05/31/2015 09:59PM by Matt Bobyn.
