VW 020 4.25 Ring & Pinion source??
Posted by ElectroTech
ElectroTech
Steve Wheeler
1992 Golf
June 15, 2015 12:53AM
Anyone here purchase from these guys before?
Price point seems a lot more reasonable.
I emailed to see if they can supply lower ratios as well.
Ebay
Re: VW 020 4.25 Ring & Pinion source??
June 15, 2015 01:10AM
ElectroTech
Ebay
May be the same guys as I got a bunch---6-7---for guys some years ago..
Everybody opted for 4.47 except one guy who got 4.2 and immediately regretted in..
4.2 barely corrects for the taller gravel tire versus the dumpy street tires.
Doesn't seem the best way to spend money and the R&R time to end up in the same place as a stock road car...
Watch them on the VAT..No VAT on export.
Go 4.47 minimum . Maybe get some bearings and seals at same time---good prices on that.
ElectroTech
Steve Wheeler
1992 Golf
June 15, 2015 04:35AM
Yeah for sure, 4.25 is on the high side with the stock ranges, but if this is good quality stuff it may alow for a more affordable swap to some of the MTS or other VWMS 1-5 gears and not have a pinion that winds up having such a tiny tooth count. It amazes me that some of these super low final drives stay together with the shock loading they get exposed to.
Josh Wimpey
Josh Wimpey
Sneak the Golf
June 15, 2015 10:23AM
ElectroTech
The MTS gear options for 3-4-5 seem to only need a 3.89 or 3.94 final drive to make good ratios. In fact, the taller gearing makes 1st gear more useful than a 4.xx would. The 3.89 gies you a near 40mph first gear with only a baddish drop to second with 3-4-5 nicely spaced up to 115mph top speed.
And, YES, the super low ratio FDs are more prone to failure. If you search this site, you might find some evidence of this from 6+ years ago with the 4.64, 4.8x, and 5.xx FD exploding for a few people.
One. Class -- 2WD
www.quantumrallysport.com
tdrrally
edward mucklow
June 15, 2015 12:17PM
is that for an a4 style trans?
ElectroTech
Steve Wheeler
1992 Golf
June 15, 2015 01:14PM
They have trans parts for all kinds of euro stuff likely have for your A4 as well.
June 15, 2015 05:49PM
Just been looking at this VW gear and final drive thing...I know there's lots of opinions BUT
Usually the first thing I do to clarify schtuff is to think:
what is the coolest car in human history?
Well we all know it its the Escort, either MkI or MkII in proper Group 4 spec..
Ya know the thing Haydon Paddon used just a few weeks ago to win a round of New Zealand rally Chamionship overall---beating every turbo 4WD car including Ben Klock---arguably the fastest guy active in North America---
So what do we see in their gear and final drive numbers?
A variety to be sure but heres some typical numbers
Gear.......................final drive..................overall ratio
I) .....2.29......................5.1..........................11.68
II) ....1.55......................5.1.............................7.9
III)....1.16......................5.1.............................5.9
IV)....1,0........................5.1.............................5.1
V).....0.86......................5.1.............................4.37
Ok that's cool, works fine, decades of proof, not opinion
Old VW so called "8v Gearset" matched that except the fastest guys used 5.08 final drive
Then in 1988 same time as Opel came out with their SOOOOPER BITCHIN GM/Xtrac 6 speed and jiggered everything to use around 4.2 final, VW jiggered their stuff and called it "16V gearset" and 4.2 or 4.25 was the thing
So can one replicate affordably something kinda similar?
Well lookie dis:
Stock--on some year marked*
I)....3.45.*................4.2...........................14.5
II)...1.9*...................4.2...........................7.98
III)...1.44*................4.2...........................6.04
IV)...1.17................4.2.............................4.9
V)....1.03..................4.2............................4.32
Now comparing it to know very good, looks like with a cheaper 4,2 and just 2 gears from Germany you have a complete box/final drive that will allow a hotter engine with higher peak torque and not fall on the face on gearchanges even in the uper range where n.a. cars suffer so much
7000 in 4th w 60cm tall tire = 97mph
7000 in 5th w 60cm tall tire= 111mph
That would be typical 14" tire
With the greatest tire in recorded history for clubbie guys under 200hp, the famous 14-62 x 15 Michelin
7000 in gears would be
I)............35...........aka 56 km/hr
II)...........64...........aka 102 km/hr
III)..........84...........aka 132 km/hr
IV)..........103..........aka 165 km/hr
V)...........117..........aka 188 km/hr
Pretty gawddam good..
Oh and "Tran-x" gears makes a good clutch plate LSD cheaper than Gripper by a coupla hundred bucks..
ElectroTech
Steve Wheeler
1992 Golf
June 15, 2015 06:36PM
This is getting somewhere now, no reason a good LSD and sensibly spread gears need to cost $2500 in a 200hp car.
Right now I have this trans:2Y* 2Y(16v)
3.67 FD
1-3.45
2-2.12
3-1.44
4-1.13
5-0.91
And this trans:
ACH
3.94 FD
1-3.45
2-1.94
3-1.37
4-1.03
5-0.75
June 15, 2015 06:52PM
ElectroTech
3.67 FD
1-3.45
2-2.12
3-1.44
4-1.13
5-0.91
And this trans:
ACH
3.94 FD
1-3.45
2-1.94
3-1.37
4-1.03
5-0.75
Looks like you just need 4th, 5th and final...and a diff.
ElectroTech
Steve Wheeler
1992 Golf
June 15, 2015 09:18PM
If this is
June 15, 2015 09:19PM
ElectroTech
If this is
If dis iz wot?
ElectroTech
Steve Wheeler
1992 Golf
June 15, 2015 09:31PM
Ok lets try this.
If I read the wording correctly on the Tran-X Diff price here it says €675 including 21% tax, now if its €533 plus shipping its a screaming deal around $750 CDN plus shipping.
Tran-X Netherlands
Edited 1 time(s). Last edit at 06/15/2015 09:43PM by ElectroTech.
June 16, 2015 12:48AM
ElectroTech
Ok lets try this.
Tran-X Netherlands
Can't imagine it would be cheaper at a place in Holland---go direct..
And no VAT on export.
Buy direct :
https://shop.quaife.co.uk/vag-020-109mm-cw
GBP575
Gotta choose pre-load and ramp angles.
ElectroTech
Steve Wheeler
1992 Golf
June 16, 2015 08:00AM
It appears to be just that. Euro at 1.4 and GBP at 1.93 ish.
June 16, 2015 09:31AM
ElectroTech
Strange as it seems so sumpin up like the Dutch got too stoned to update the prices or something.
Check and see.
