Suspension travel, shock towers and maths.
Posted by Paul Buck
Re: Suspension travel, shock towers and maths.
October 01, 2015 08:04PM
Paul Buck
ok. so work has been utterly crazy... but now, with all of you fellows fine words of wisdom, i feel i have enough info and reassurance to go ahead and get this thing done. found some 5" steel tube with 3mm walls and it's $50 for 4ft. Not bad. Going to get on it this weekend while trying to go pick up a 16v motor for Roderick. I told him he'd have to fight me for it when he comes to pick it up. community!
Know any driveshaft shops that do truck stuff? Often they had stub ends for cheap...maybe not .125 but hey I got a bunch for like $5 once.
Robert Culbertson
Out of this dumpster fire
October 01, 2015 08:24PM
I'm with John, that's crazy expensive for what it is. Especially since iron-ore and steel prices are at an all time low. Thank you China!
I just checked a recent order I placed with Tuber Service Co on Swan Island. A 20ft stick of 4in 0.120 wall was $120.
There are 3 driveline shops near I-5/Columbia. I deal with Potter Webster, and they are a relaxed group of dudes.
Eric Ewert
Eric Ewert
volvo 240
October 01, 2015 11:27PM
Are you planning on using the tubes as they are and cutting circular holes in the floor to fit them?
Or are you going to use them as a starting point, cut them in half to make them look like a "D" from a birdseye view then possibly add to them as needed.
I ask because I used 6 inch tubes, and slammed them in as is. Installing them using the method I described in the first sentence of this post. No clearance issues however any smaller and the coilovers would be hitting the sides of the towers/tubes. Mine are stupid close in a few scenarios.
Paul Buck
Paul Buck
Volvo 242 in progress
October 02, 2015 12:55PM
That's a good point Eric. I was told 5" was adequate and my plan was to put them in as tubes. But plans change... did you attach yours to the axle or the trailing arms? Maybe I'll source some cheaper 6" to be safe.
Eric Ewert
Eric Ewert
volvo 240
October 02, 2015 05:12PM
Axle. And even when I had stock trailing arms they were attached to the axle. I would normally think that 5 inch would do but for whatever reason my coilovers move around a bunch. That being said they are roughly 3 inches diameter which would leave less than 1.5 inches either direction for movement with a 6'' OD tube.
Robert Culbertson
October 02, 2015 05:45PM
Paul, if you want to get all fancy we can take some measurements and then make a quick CAD model. We can then run the suspension through it's travel on the computer and look at all the clearances.
Sounds like a fun project.
Paul Buck
Paul Buck
October 02, 2015 11:04PM
Sounds like a very informative project and a potentially amazing resource for many, many people.
October 03, 2015 09:33AM
Paul Buck
Or at least two.
October 03, 2015 10:28AM
What about driveshaft stroke?
Robert Culbertson
October 03, 2015 11:23AM
Paul Buck
Or at least two.
Basically.
October 03, 2015 03:57PM
Robert Culbertson
Paul Buck
Or at least two.
Basically.
Well one really: you.
We've already done this, Kevin Hawkinson and I.
Piccies have been posted before someplace.
Robert Culbertson
October 03, 2015 08:19PM
Pictures are great, but actual numbers are a bit more useful at times.
Robert Culbertson
October 05, 2015 04:25PM
Cooler heads, and laziness, prevailed. No CAD modelling for now.
Removed the springs and shocks and ran the suspension through full droop to full bump. Plenty of clearance if the stock bump stops are used. Probably should lift one wheel up and drop the other to check articulation clearance.
Figured out that the stock upper spring perch has a nice little hole in the center that can be used for locating. Paul took a drill bit and went straight up through that and it went through the trunk floor in the right spot. Makes locating the center of the tower easy. Now the search for a massive hole saw...
October 05, 2015 07:29PM
Robert Culbertson
Piece of wood to steady the hand for the plasma cutter might be easier...
Paul Buck
Paul Buck
October 05, 2015 07:45PM
plasma scares the peasants, they're all used to scythes...
or, we just don't have one.
i am, however, super good at burning holes in cars with a welder.
