Garrett Griffith Garrett Griffith Mod Moderator Location: Dallas, Tx Join Date: 04/14/2016 Age: Settling Down Posts: 20 Rally Car: BMW E36 318i |
Its been a quick minute since I've posted on here. The semester finally ended so this has allowed me to work a bit more on the car. With the 50mph shaking being a problem, I did some research and decided to check out my tie rods, control arms and bushings. Needless to say, everything was due for a refresh.
This took a bit of work as there are VERY tight joints to break loose. Being new to the auto industry, I don't have a plethora of tools at me disposal and spent a few hours trying to break loose the control arms. A trip to Harbor Freight and one large pickle fork later, I was able to bash loose everything with a 10lb sledge hammer. Next was to fit the new bushing in their respective holders.... That was very difficult and ended up involving dry ice, cutting torch, and a 16 ton hydraulic press. The next step was to then firmly press the rubber bushing bastards on the control arms. not so simple as it would seem. For the first was the worst and yielded me being drenched in sweat from tormenting the two pieces together. Just. keep. twisting. Since I had one left, I just lubricated it all with soap and it slipped right in. I don't really care at this point if it isn't the best thing to use, I just never want to touch these things again. I got a new jack as well! previously I have been using just like a $40 8" jack I borrowed from my father. It was really sketchy stacking wooden blocks on it to reach a workable height. So for my birthday I got this bad boy! 24" max lift. I was also tired of looking at nasty yellow headlights, so with a little bug spray and clear coat I did this. (only one side has been done mind you) Not perfect by any means but a hell of a lot better than they were. So I suppose next step is to finalize the cage order and prepare the car for that stage of its life. "Cut the don'ts" - Garrett |
formyhealth Danny Maxwell Mega Moderator Location: Oregon Join Date: 05/24/2016 Age: Settling Down Posts: 60 Rally Car: 1991 BMW 318is |
Just a quick update. I took the car for a long distance (210 miles) stress test and it passed my expectations. I don't know if that is saying much, but I am happy my front suspension refresh and -2mm self alignment is on point! There is still a >50mph grumble when letting of the accelerator. Not sure where exactly its coming from but is defiantly in the rear. Diff? rear bushings? unfortunate rattle? who knows? Two things became very clear during this trip... Need to fix windows ASAP and get suspension because both front struts are defiantly blown. Might be a while until the next update (cage prep).
Nate.Vincent Nate Vincent Super Moderator Location: Pomfret, Ct Join Date: 07/29/2014 Age: Settling Down Posts: 29 Rally Car: BMW 318ti |
Check your guibo and your center bearing on the drive shaft. That decceleration sound sounds like it could be those two items. You should replace them anyways. Also, often on the e36 the heat shields come loose and rub the drive shaft. Also I parted a e36 328i with full bilsteins HD (well 3 out of four). I could let them go cheap if you need a suspension set up to get you by for a little. They aren't perfect but they hold oil and dampen appropriately. I have both fronts and only one rear. I also have reinforced rear top mounts. I can PM you some pictures if your interested. Edited 1 time(s). Last edit at 06/01/2016 08:14AM by Nate.Vincent. |
Dooooood. fuck this "I can Peee Em piccies" Post them.. Post 'em with tape measures next to them---HERE. Think of the Lurkers! Lotta guysd read these forums... One guy reads a fucking PeeeEM Same effort to inform one guy or potentially dozens. We don't fly the Red Banner for no good reasons round here, we fly the Red Banner because we know more is accomplished with conscious collective action.. Share with US. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Yeah shoot a PM or just post them on this thread! I am interested in something that will suffice until I order JVABs from the specialty chef.
Also the transmission guibo has been replaced, and the heat shield has been attached securely once over. I was begining to think the drive shaft bearing as well! Ill get another ear to listen and try to pin point this sound. "Cut the don'ts" - Garrett Edited 1 time(s). Last edit at 06/01/2016 09:40PM by Garrett Griffith. |
DanielSL Daniel Mod Moderator Location: Vero Beach, Florida Join Date: 03/02/2016 Age: Possibly Wise Posts: 338 Rally Car: 2005 VW Mk. 4 Golf GTI 1.8T |
Were all of the engine mounts / transmission mounts verified to be in good shape? That type of vibration could very well be from mounts. I had a few E34 chassis 5 series, and went through this in two of them. Build is coming along nicely. Looking forward to seeing the progress.
Time for some tape measures and notes like wat dem sprangs? John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Sure..But its way easier when you gimme a phone numbah, bra. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Andrew_Frick Andrew Frick Godlike Moderator Location: Greenville, SC Join Date: 05/18/2007 Age: Midlife Crisis Posts: 684 Rally Car: Rally Spec Ford Focus |
Looks good, Garrett.
Those HDs would be a good suspension before you step up to a real rally suspension. And will make good spares if you have an issue with your rally stuff and just need to get to the end of a rally. Or need to move the car if you have to service the rally stuff. Keep driving it and fixing all of the annoying little stuff. This will make the car so much nicer to race when you get to there. |
I think i've just about fixed everything so far. There is a very very minor oil leak (1 drop per 3 weeks) and I figured out the rear diff has a loose pre-load pinon gear (makes the growl on decel). Those are the only things I can think of that might be a future problem but are very hard to deal with. SOOO I'll address them after the first rally.
