The aluminum will look like cheap. Make some crescent tabs for the moon roof panel ti sit in. Full the gap with Bondi, silicone, whatever.
Lexan fitting is not hard. Not having working Windows sucks at rallies. Lexan attracts dust and scratches easy and doesn't last that long. It is very race car, but not really worth the effort our trade offs. Coilovers clearance needs vary by brand. There are considerations to make before ditching the stock upper. I was tired and thinking you were saying more than you said regarding the upper arm. There are many options, keep in mind tire clearance with whatever you do. Kern runs a 20 mm spacer to clear his Jvabs. Tire might still rub under full compression. My Compact is a caged project. I might finish it and race it. I might sell it and buy more biotech stocks. Grant Hughes |
Da_Elderly Garrett Griffith Mega Moderator Location: Dallas, Tx Join Date: 01/20/2016 Age: Settling Down Posts: 48 Rally Car: BMW E36 318i |
well, the actual moon room doesnt exist anymore... sooo yeah
unfortunately, yes the lexan will not last long, but mind you this is my first car. Was lexan the smartest choice? nope. easiest? yup. ah, good point about tire clearance with regards to the coilover. never crossed my mind! hopefully i dont run into any issues. How do I test 'full compression'? Take your compact and race me at 100aw! Be excellent to each other |
Take the spring off. Shock stays Jack the wheel up till it stops. Ascertain reason wheel stops. Measure everything imaginable. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
You should see my Lexan job. I had like two hours to make it work. Only one got mechanical restriant, rest had to stick with silicone as I had no time to devise a method. Hence why they ended the season held in by duct tape... I believe Brooks kept the stock rail in his car and exactly replicated the window in Lexan and put it in the stock rail. A gutted door is easy to mechanically attach, a non-gutted door is not so much. Also, my lexan was slightly thicker than the glass and is kinda a royal pain in the ass to get into the grooves along the top and sides of the frames. I think it's 1/8". I don't think Dave's rubbing is enough to be of a concern under full compression. Tire slightly rubs on spring maybe. I don't recall exactly what he said. His has turrets and is a Compact to so perhaps the upper part of the turret is too far outboard to avoid notching the frame rail. Okay, I won't wait for the DMS... Let's see what Derik did on his M3. (See attached) Okay, obviously aftermarket upper and lower arms there. Let's see what Hintz did... Nope, no luck finding photos and pretty sure Dave Clark has been effectively chased off by John already. Probably similar since he's also on Reiger I believe. Found a pic in Dave's mobile uploads. Looks similar so yeah, probably need new upper arms. Easy stuff. Grant Hughes |
Makes sense, I will just have to remember to check clearance once I mount the gravels.
Those upper arms really depend if John wants to do it, ha. I game either way. 1 door is gutted, the other is not...yet. I just hope I don't have to duct tape everything, I prefer electrical tape. It makes everything nice and gooey. But for real, some sealant might be needed. I'll have to test it out later. I am hesitant installing them as they will just be scratched during the remaining construction Be excellent to each other Edited 1 time(s). Last edit at 10/20/2016 04:14PM by Da_Elderly. |
Sealant would be better than duct tape for sure.
Find a moonroof panel. Seriously. So much easier. Are you a two door or four door. I might be able to find one for you. There's plenty of upper arms out there. We will start making them also if there is not. Guessing Hintz and Nelson didn't just make theirs, maybe they did though. Grant Hughes |
Little update. I got to the shop today and got to work cranking out little tasks. First order of business was to finished removing the sound deadening tar. After that was complete, I sprayed goo-gone basically everywhere inside the car to get the sticky junk out. A few hours and about 40 sheets of paper towels later, it all cleaned up. kinda (still some junk left). Next was to adjust the front coilovers and check the ride height. This is with the bottom flang 3.75inch above the top ear piece.
A few months ago I started cutting wires that went to the rear of the car and had no idea if I cut something vital. So I also started the car successfully today with no problems. Now in preperation for moving my car build from a pest control shop to my parents farm, I started re-assembling the car so I can make the 90 mile drive to its new home next weekend. This is where the car will remain until completion. So yeah, just a small update. chow Be excellent to each other |
BMW tar is horrible but I found something worse. Chevy Sonic. It's so bad I haven't seen one that the person didn't give up and actually finished it on.
Heat gun with a thin scraper and then goo gone or similar and time. Definitely kills some brain cells. I weighed it all on one E36, 30-40 lbs I think... Grant Hughes Edited 1 time(s). Last edit at 10/22/2016 10:10PM by NoCoast. |
Hintz has gone to these with a spacer to raise ride height.
https://m.summitracing.com/parts/eib-08755750300/overview/ This could be a non spacer option. https://m.summitracing.com/parts/eib-09505000300/overview/ They broke bottom mount twice with coils. Bradenvurg did at least once. Roger Matthews did his Saturday. Grant Hughes |
Cast iron Grant. Learn. Think John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
tdrrally edward mucklow Mod Moderator Location: charleston,wv Join Date: 05/31/2011 Age: Possibly Wise Posts: 763 Rally Car: ford mustang LX 5.0, 1973 VW Beetle |
