paperpaper Dan Downey Ultra Moderator Location: Franklin, MA Join Date: 02/24/2014 Age: Settling Down Posts: 28 Rally Car: e30 |
When he called and described the courses and surface I did like most of the time for Grass-o-cross guys who call: I said you don't need my stuff and indeed it would be a disadvantage in function and in cost... John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Your parts are safe. I've got them safely tucked under the computer table in a box, and at this very moment I'm using said box as a footrest. Looks to be two actuators, a bit of cast exhaust manifold, and the other day a piece of what looks like a gearstick arrived. I ain't jealous of poxy little 17" rims. I'm rolling 26" on my mtb and they are doing the business against the young uns that think only 27.5 or 29 wheels work! Plus it gets worse for the magpie consumers when they discover I also manage to get by without a rear shock... Suspension is sooo over-rated y'know. Disappointingly not yet a Jackass |
Mountain bikes! Fawk me that sounds like work...! Where's the old Suzuki? John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
mekilljoydammit Junior Moderator Join Date: 09/22/2010 Age: Midlife Crisis Posts: 336 Rally Car: No rally car yet |
DanielSL Daniel Infallible Moderator Location: Vero Beach, Florida Join Date: 03/02/2016 Age: Possibly Wise Posts: 338 Rally Car: 2005 VW Mk. 4 Golf GTI 1.8T |
The Mk. 4 is definitely much safer than earlier variants. 20+ years of developmental R&D will do that to a chassis. I've dealt a lot with Mk. 1 and Mk. 2 cars. And the 4 is so much different, that only the DNA remains to see the lineage. The Mk.7 which I DD is so much closer to the 4, than the 4 is to the original Rabbit GTi's I first drove and raced. |
I know someone with a Golf with an apparent 250bhp engine. I don't want to sound like I'm speaking for him, but my observation is that if it wasn't overheating, it was shredding transmissions or axles. Lots of axles. I haven't seen it on course for a very long time, too, which tells me something. OTOH, my car also hasn't been on course for over a year now, it is putting out 230-300bhp depending on whose math you believe... and it took a lot of time to get it to the point where it doesn't overheat (much), but transmissions are still short lived and the reason it hasn't been regularly on course since *2014* is axle failures. And it's a solid axle RWD, not something that tries to run power through CV joints. And it's still on par with a mostly stock 1.8 Miata as far as raw times are concerned, on short/tight courses. Which kinda sucks, but what can you do? The compromises made to be able to put power down mean it doesn't like to change direction much. Undo those compromises and it becomes undrivable without far finer mind-throttle linkage than I could ever hope to achieve... Pete Remner Cleveland, Ohio 1984 RX-7 (rallycross thing) 1978 Silence is golden, but duct tape is silver. |
Ascona73 Bob Legere Ultra Moderator Location: Spofford, NH Join Date: 03/07/2007 Age: Possibly Wise Posts: 308 Rally Car: 1971 Opel Ascona |
A friend of mine used to stage rally an MK4 Golf with a 1.8t. Made 230 hp to the wheels at modest boost. Broke axles left and right. Mostly in tighter slow speed corners.
At Maine one year his Stack dash was recording wheel spin in 5th and 6th gear with this relatively modest power. 15" rally tires and AP calipers and rotors were more than enough, and this was one of the fastest group 5 rally cars out there at the time. I can't imagine trying to channel 250-275 hp thru slow 1st and 2nd gear corners. And big brakes are certainly not required for dodging cones. I hope I'm not coming across as too harsh, but as I was the guy swapping the axles more often than not, I'm just trying to save you some grief. Good luck. Opel is a 4-letter word... http://www.flickr.com/photos/10498579@N07/sets/ |
tdrrally edward mucklow Infallible Moderator Location: charleston,wv Join Date: 05/31/2011 Age: Possibly Wise Posts: 763 Rally Car: ford mustang LX 5.0, 1973 VW Beetle |
(rained and rained and rained, finally we said fuck it, make a short course, it's getting late let's make some runs so we can get packed up before dark... NOT the usual long hi-speed 2 minute long powerslide we usually do) Now for extra fun I could have posted videos of me driving a friend's Miata, running 8 pounds of boost on a BP engine... power delivery was either "waiting for boost" and "tire spin" as far as I could ever manage to do. Mad props to the owner for pedaling that car around as hard as he does, at much higher boost. I had turned it down from ludicrous to crazy to compensate for my lack of talent. My driving was comically bad, somehow managed to mostly keep up with the steering but barely. For extra fun, most of the time I drove it, the diff was held in by a chain around the powerplant frame through the subframe, because the aluminum diff support uterus thingy had broken at some point and I found out a day or two before I was to drive it to Michigan. Good times... Pete Remner Cleveland, Ohio 1984 RX-7 (rallycross thing) 1978 Silence is golden, but duct tape is silver. Edited 4 time(s). Last edit at 05/19/2016 08:24PM by Pete. |
The TT finally arrived at the shop. Hopefully within the next week, I can start stripping and inventorying what parts to use. I know I will be using the Audi aluminum subframe, aluminum front lower control arms, Audi 225 AMU code engine, 2.5:1 steering rack, steering knuckles, and rear vented brakes. The "Maybe" list includes the transmission, and various rear suspension pieces. As its a Quattro, I am thinking right now that only the rear brakes will be able to be swapped over.
With this set-up, stock at the crank was 225 set up for Quattro driveline. With FWD, and only FMIC, intake, and exhaust done; I will still have 200+ to the wheels. I may run a full season like that, to see where my weak links will be, and once those are addressed, do the tune to 280+, with around 250 at the wheels. One thing I remember was once your weak links are taken care of in a race car, you only end up finding the next set of weak links. |
wvonkessler Wilson von Kessler Infallible Moderator Location: Lookout Mountain, GA Join Date: 02/28/2006 Age: Possibly Wise Posts: 1,127 Rally Car: Colts are in Finland; now '87 325i, '89 325i |
For sure it takes a bit of effort to get up the hills, but it's really just about tuning the body to be able to do it through simple training. It's good fun coming down my local steep technical trails. The Suzukis are in the shed. Trouble we have here is gaining access to land to be able to ride motorbikes offroad. It's generally all private estates owned by sirs and lords. In Scotland we have the right to roam on foot, horseback, or bicycle, but motorised vehicles are not allowed without permission. That being the case, unless you have friends with land it is really only sanctioned events where you get the opportunity to blast around on a offroad motorbike. Disappointingly not yet a Jackass |
