1991 BMW 318is rally cross build
Posted by formyhealth
formyhealth
Danny Maxwell
1991 BMW 318is
Re: 1991 BMW 318is rally cross build
July 17, 2016 11:57PM
Oh yeah, and I also bought a couple of these for the time being so I can drive the thing around comfortably. (The stock seat brackets were broken so there was some thing like 4 or 5 inches of play forward and aft on the seat back, yikes.
DanielSL
Daniel
2005 VW Mk. 4 Golf GTI 1.8T
July 18, 2016 07:19AM
As weak as those LCA's look, while its out of the car it would be easy and cheap to have steel plate reinforcements welded in. You could swiss cheese and dimple die the plates for less weight and increased strength while you're at it.
formyhealth
Danny Maxwell
1991 BMW 318is
July 23, 2016 12:13AM
DanielSL
I'll do that! some thing like this?
Taken from Garagistic as reference
DanielSL
Daniel
July 23, 2016 11:38AM
Exactly. I would go as far back as possible, without interfering with travel. Don't for get to hole-saw, and dimple die them for increased strength. It will also make it easier to clean out, so you don't have dirt. mud, etc... sticking up there causing corrosion issues over time.
formyhealth
Danny Maxwell
1991 BMW 318is
July 23, 2016 09:55PM
DanielSL
Sweet will do, Thank you for the tip!
paperpaper
Dan Downey
e30
July 25, 2016 10:16AM
Garagistic makes a secondary weld in diff bushing/cover mount. Makes it more like e36/46 covers.
I really need to get some trailing arms to add reinforcement to as I think I have unwanted added camber since NEFR.
formyhealth
Danny Maxwell
1991 BMW 318is
July 25, 2016 10:53AM
paperpaper
I'm going to have to look into that, I didn't know they sold that.
What is NEFR?
July 25, 2016 01:57PM
formyhealth
paperpaper
What is NEFR?
Nice...
But it looks like a guy could "be inspired by" that design and make something in steel for a whole lot less dough.. Maybe buy the bush but fab the rest.. Maybe.
Oh edit: NEFR is Snooze England Furry Rally
Edited 1 time(s). Last edit at 07/25/2016 01:57PM by john vanlandingham.
formyhealth
Danny Maxwell
1991 BMW 318is
July 25, 2016 02:00PM
Ah thanks!
I could do dat probably, those bushes are cheap(ish) and steel from the local scrap yard is too. Oh and I do have a lathe so I can turn a bushing holder and then weld on a bracket to attach it to the diff.
Hmm..
July 25, 2016 02:24PM
formyhealth
Ah thanks!
Hmm..
Hell you could go all medieval on the cover and hack off the YUUUUUUUUUUUUUUGGE bush on the udder side and make 2 bush holders and use a smaller bush---- maybe something like 1.5" OD x 1-1.25" long.. In life more bush is good, but in cars less bush is more. More better-er.
formyhealth
Danny Maxwell
1991 BMW 318is
July 25, 2016 02:30PM
What's the theory behind two smaller bushes rather than two larger ones?
July 25, 2016 02:39PM
formyhealth
The larger the bush, the more the movement..
And the worse it is when the bush begins to deteriorate.
2 for balance..Friggin diffs are heavy (dropped an Xratty 7.5 diff on my toes when packing one for UPS once. Broke the fawk outta my big toe---didn't even wat to look till I got back from UPS..Walking it was like squish squish squish cause my shoe was soaked in blood...Toe nail fell off but a couple of years later grew back all gross deformed---chopped the whole toenail off and "killed" the nail bed so it would grow back---but it came back even more deformed--I'm a fawkin mutant!!!!) Spread load to two places on the cover and two places stress into body shell.
formyhealth
Danny Maxwell
1991 BMW 318is
July 25, 2016 02:42PM
Damn dude, that's awful, those shits are like 70 lbs...
OK, that makes sense definitely. Time will tell on this large bush. If I start to get premature clunks then I'll look into some smaller bushes. At the time, my pride and my wallet are telling me not to replace a brand new bush.
However, I'll keep your advice in mind. thumbs up
