NGTD Dave Cotie Infallible Moderator Location: North Bay, ON Canada Join Date: 03/27/2007 Age: Possibly Wise Posts: 125 |
Just picked this up today! Came with a crap load of spares including hood, fenders, front and rear bumper covers, trunk lid and about 16 tires! Running DMS coilovers, a fairly new JDM Si engine and a JDM ECU. First thing I have to do is adjust the suspension up and re-install the underbody protection. PO ran a track day so lowered it way down and pulled off the skidplates. Edited 1 time(s). Last edit at 06/17/2016 10:42PM by NGTD. |
Mad Matt F Matt Follett Infallible Moderator Location: La Belle Province, Montreal Join Date: 03/13/2006 Age: Midlife Crisis Posts: 645 Rally Car: Don't Laugh, the Justy is Fun! |
So does anyone speak DMS?
I know DMS springs are progressive, but I'm just trying to figure out what I have. The fronts are brand new and the springs are stamped - DSP-KST-550M-240FL. No markings on the rear springs. Both front and rear springs are only 9.5" uncompressed. There are no tender springs. When I adjusted them to get additional ground clearance the fronts are in the top 1/4 of the threading on the shock body (sorry I didn't measure - I should have). It seems to me that these shock bodies could easily take a 12" or even 14" spring. |
The normal gravel DMS springs are in the region of 13" long free length..Its late and I hain't going out on the back porch where I have some fronts and rears..Normally they are taper ground wire--a true progressive spring..Nice things for the application, but pricey and lack of a comprehensible rating (Ford used taper ground wire in the Sierras and Escort Cosies and I have several sets of works "909" springs and Ford gave a three part rate: full extension rate, the important mid-stroke and then a final "near the end' rate...) keeps me away.. Did you say what you have for travel in whatever you have? John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Raining here tonight, but I will pull the spring off and measure the travel later this week.
Will likely be similar to what is here though: http://www.rallyanarchy.com/phorum/read.php?5,76139,page=1 Honda apparently didn't change much on the pre-strut platforms. Hard to find information on DMS shocks. All of the stuff on their website is about struts. |
What? Straight struts front and rear..None of the brou ha ha Japonaise copy of some Mercedes or Audi weird ass crap.. I'm being polite about the springs..sumpin is seriously foutu John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Well according to the folks at DMS NA, the front springs are 550 lbs/in, rears are likely 350-400 lbs/in. The 240 is the free length of the springs in mm, which confirms my measurement.
The front shocks have 135mm - 5.3" of travel and the rears have 145mm - 5.7". I took the front springs off on one side today and stroked from full droop and I get about 8" of wheel travel before the tire hits the fender liner and the shock was hitting it's bump stop. The car was being run for track days and has a pretty beefy front anti-roll bar. Any comments from the Honda guys re - front bar? Disconnect or leave it? Edited 1 time(s). Last edit at 07/16/2016 11:08PM by NGTD. |
I'm presumin' you didn't take out the bump stops--or gummi puffer as the Fritzies call them.. DMS tends to not use the longest puffers in the world but they are probably at least 1.5" long so you could extrapolate another 1" travel. But dang, mang that's short travel. You are planning on gravel rally aren't ya? John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
It sounds about right based on that thread I linked for you that Aaron Luptak posted (strut travel and overall wheel travel) for the max you can get out of a civic double wishbone setup. The spring rates seem REALLY high though. I know the SIR coupe is heavier, but the going rate is about 350 front, 200 rear for a civic hatch of various years. |
Looking at the charts I see the wheel in the rear moves 133mm for 100mm shock travel.. Thats 33% more than the shock. Front seems to move 153mm for 100mm shock travel Seems because there is some extrapolations in the calculation.. That SEEMS high Plugging that in for the travel you mentioned and it SEEMS to come out rear 145 x 1.33= 192,85mm or 7.6" and front 135 x 206mm or 8.13" and that seems rather high. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Yes the 550 does seem pretty high, as well as the rear rate that the DMS NA guy indicated that it likely to be. I will have to try to source another spring set, but that is down the road. I also got a set of road racing springs with it. Based on the size of the spring, I would love to know what rate they are!! I might be able to run the rear springs on the front and just get a set for the rear since they are more in the range that people were looking at in the thread you linked. Edited 1 time(s). Last edit at 07/21/2016 10:40PM by NGTD. |
John, you mentioned charts. Is there an online resource to find that information? |
