Garage method of enlarging hole in brake rotor?
Posted by Gravity Fed
1978 Mazda Rx7
June 21, 2016 04:51PM
so the rotor i want to use has a smaller center diameter than the axle has. Aside from the obvious lathe or mill, neither i have, is there a good method to do this, or should I what and try to pay a machinist sometime in like Winter when I'll have the funding.
Respecognize!
Http://www.facebook.com/2WDriveRally
Driver (0), Co-Driver (5)
Cars Built (1.5), Engines Blown (2) Cages Built (0) # of rotations (3.5)
Last Updated, Oct 30, 2013
Robert Culbertson
Out of this dumpster fire
Re: Garage method of enlarging hole in brake rotor?
June 21, 2016 05:33PM
How much bigger does it need to go? Is the rotor a tighter fit onto the studs, or is there a lot of slop?
1978 Mazda Rx7
June 21, 2016 07:16PM
Need to drill the pattern too.
Respecognize!
