Audi UR Quattro Rally Build
Posted by BRAIDusa
BRAIDusa
Paul Eddleston
Subaru Outback Wagon EG33, 911 Carrera
Re: Audi UR Quattro Rally Build
April 06, 2017 10:01AM
I wish I could tell you that Daniel but I can't, sorry. Well, we could probably make a forged monoblock replica of the Speedlines but it would be thousands of Dollars for just four.
The nearest we have are the 15" versions I have on our 85. Those can be ordered with hidden screws just like these 16".
image by Team Illuminata Motorsport, on Flickr
would these work for you?
Paul Eddleston
BRAID Wheels USA www.BRAIDUSA.com
Team Illuminata Motorsport www.teamilluminata.com
DanielSL
Daniel
2005 VW Mk. 4 Golf GTI 1.8T
April 06, 2017 10:19AM
Will be sending you a PM, sir.
BRAIDusa
Paul Eddleston
May 02, 2017 12:45PM
Scattered progress since our last update but progress non-the-less.
We started to attack the drive shaft last week. The CV joints seem a bit stiff so we are going to clean them out and see if we can save them. If not we think we can replace them. The universal joint in the center seems fine but we might have to destroy it removing the center support bearing which is also fine but whose rubber bushing is decidedly squishy.
We also started refurbishing the fuel tanks. Initial inspection revealed only surface rust so we cleaned it out with some dish washer detergent.
We had a visit from the guys who run DIYAUTO.com https://www.diyauto.com/ last week, Nick and Steve Balistreri. DIYAUTO.com’s goal is to collate all the cool information in the various forum build threads on the web so the information is easy to search and the knowledge is not lost to us auto enthusiasts. We are proud they have both our quattro builds and our 911 build on their site.
We continued to dismantle parts that are being sent out for refinishing. This week it was the turn of the suspension components. These did not want to come apart and the students learnt a great deal about persistence and the use of heat wrenches.
We’re not even sure we can get replacement ball joints and bushings for this stuff and may have to fabricate our own.
We optimistically mocked up the rear calipers again to see if we can make them work. Both the handbrake cable and the brake fluid line want to go through the rear axles but as we intend using a hydraulic handbrake we wanted to see if we could make a banjo fitting attach. Think not:
Next update we hope to share some news about the shell. Stay tuned.
Paul Eddleston
BRAIDusa
Paul Eddleston
May 27, 2017 06:33PM
Been working on a few things but nothing too exciting. we finally found some proper UR quattro rear brake calipers
You can see how the handbrake cable and brake line come in from the back instead of the side therefor avoiding the axle.
Amanda made some more incremental progress on the model. She says she's going to paint the stripes next.
Then we started on resealing the rear differential.
No wear groove on the input flange smiling smiley
Paul Eddleston
BRAIDusa
Paul Eddleston
June 29, 2017 10:29AM
Rear diff is back together with new seals. Now we need to decide what color to paint it.
Amanda has started painting stripes on the model.
We borrowed an OE refinished rear caliper and decided this is the way to go with ours.
In anticipation of panels showing up Thompson Racing Fabrication took the car out of storage and delivered it to Cherry Classic Cars. We must admit it's nice to get re-acquainted.
Now we just need our wide body kit.
Paul Eddleston
BRAIDusa
Paul Eddleston
July 16, 2017 07:52AM
Panels did indeed show up from Europe from Cool Wheels in Latvia. Cherry Classic Cars wasted no time in offering them up to the body. As expected with composite reproduction panels it's going to take quite a bit if fettling to get a good fit.
[/url]
[/url]IMG_7257
[/url]IMG_7252
They also set about fixing the rust on the shell and other minor repairs.
[/url]image
[/url]image
[/url]image
Before applying primer.
Paul Eddleston
BRAIDusa
Paul Eddleston
August 18, 2017 09:39AM
The shell is still at the body shop: Cherry Classic Cars in Michigan but we recently went to visit it and to make some decisions about how to put it together.
We also found a kevlar composite trunk lid in Canada
and received some vintage gauges and switches from another quattro aficionado.
Paul Eddleston
BRAIDusa
Paul Eddleston
September 05, 2017 02:21PM
More wide body progress on the rally build. Front and rear fenders are being wrestled into place by the guys at Cherry Classic Cars:
[[img]https://farm5.staticflickr.com/4413/36936817495_2d782665ce_c.jpg[/img]
Starting to look like a car again.
Paul Eddleston
BRAIDusa
Paul Eddleston
October 06, 2017 12:07PM
Quick photo update of progress on the wide body build by Cherry Classic Cars.
Paul Eddleston
BRAIDusa
Paul Eddleston
January 07, 2018 01:07PM
The rally Quattro is still up north at Cherry Classic Cars but it's coming along nicely. We might get it back as early as this month! Meanwhile here are some more updates.
A few weeks ago we were summoned up to CCC to help figure out how to deal with this poor bumper fitment issue:
Should the bumper go behind the quarter panel or should it butt up and why is the quarter panel so far out or the bumper so not wide enough? We feel we have a solution. More later.
While we were up there we discovered that our car has manual, wind up windows! These must have been changed by a previous owner as no Quattros had these from the factory. Gues we don't have to find a spot for the window switches now but, because of the cage, we may only be able to wind down the windows with the doors open!
While we away in the frozen north our fab guy got a little creative with our engine. As a result we now have the world's only five cyclinder, turbo charged shopping cart!
The catalyst for this creativity was the Quattro Squad separating the transmission and giving it a good clean in preparation for either a rebuild or, hopefully, just a reseal.
We also pulled the seats down from the parts shelf and cleaned them up in preparation for selling them. Not so much to generate funds but to create some space. They cleaned up very nicely and are in excellent shape. No tears at all; just a little wear on the driver's seat. I think they would restore quite well but we want to sell them as they are rather than cover things up. We think we could reasonably ask $1000 for them.
Subscribe for more updates soon and to see if the car makes it back here this month.
Paul Eddleston
Mad Matt F
Matt Follett
January 08, 2018 08:53AM
Duh...
Everybody knows Audi's only had sliding Lexan windows... winking smiley
DanielSL
Daniel
January 08, 2018 05:48PM
Kind of what I was thinking. With this build going for the extreme, I would have thought that from the very beginning a full set of Lexan except windshield would have been on the books for this tribute.
BRAIDusa
Paul Eddleston
January 08, 2018 09:21PM
It may well go that route.
Paul Eddleston
tdrrally
edward mucklow
January 19, 2018 06:51AM
it's looking good, keep up the good work
