Stock Volvo pilot bearing with sooper bitchin flywheel?
Posted by slidewayswrx
October 05, 2016 12:33AM
Just as the topic says. Chipping away at pieces of the puzzle. Seem to remember that is what I want but it can't hurt to ask right. JV, what say yee? Ford T-5, kep 228 pressure plate, clutch net clutch
Zap zap my ass...
Eric Ewert
Eric Ewert
Age: Party Animal
volvo 240
Re: Stock Volvo pilot bearing with sooper bitchin flywheel?
October 05, 2016 12:55AM
I am pretty sure I got the exact same set up as you do. If memory serves correct you use a mustang pilot bearing because the ID of it fits the input shaft for the t5. The OD of the mustang pilot bearing is the same as the OD of the volvo pilot so it pops right in.
Get someone to confirm this, i'm 95% sure of this but its been a while since I installed everything.
Robert Culbertson
Out of this dumpster fire
October 05, 2016 07:57AM
Use the mustang pilot bearing, not the bushing.
Alternatively, you can machine down the input shaft.... If that's your thing.
Edited 1 time(s). Last edit at 10/05/2016 07:57AM by Robert Culbertson.
October 05, 2016 09:41AM
Briefly:
Volvo pilot bearing ID is .....................15mm
GM V8 T5 pilot bearing ID is................15mm
Ferd V8 T5 pilot bearing ID is .............17mm.
Since it is incredibly easy to turn the snout down 2mm that's what I've down for a number of guys..
I'm sure there are other brilliant ideas which take more time and are reputed to be better...but I haven't exactly paid them much attention.
Robert Culbertson
October 05, 2016 10:37AM
Volvo bearing OD 1.378in/35mm
1990 Ferd mustang NEEDLE bearing pilot with adapter OD 1.378in/35mm
http://www.rockauto.com/en/moreinfo.php?pk=628349&cc=1133929&jnid=709&jpid=4
Robert Culbertson
October 05, 2016 10:40AM
Derp...
Why not just use a nice sealed ball bearing that fits.... 6003-2RS.
VXB.com
17mm x 35mm x 10mm. The 1mm narrower width will not matter in a Volvo crank, just set the depth so the snap ring will go on. You can actually set the stock bearings too deep if you're a major hack.... so don't do that.
Edited 3 time(s). Last edit at 10/05/2016 10:48AM by Robert Culbertson.
October 05, 2016 08:53PM
Thank you to both the yin and yang of my Volvo existence.
I'll leave to you guys to fight over which is which. 😜
Zap zap my ass...
