MattP Matt Pullen Senior Moderator Location: Calgary Join Date: 10/22/2013 Age: Possibly Wise Posts: 282 Rally Car: 2002 Ford StRanger |
Not ITO, these are an ultra fine wire embedded in the laminate. Usually a 2 circuit design, one for the each side of the screen, so you can have both on before the car gets warm then turn off the co-driver side during a stage or if you are circuit racing where you don't really need that side demisted, also it saves a bit of power from the battery. Yes, it's a Ranger. Xr4Ti, it is rwd and was made in Germany. |
Well, I was with you up until you suggested Matt has friends Cheers Matt
On second thought, this clearly can't be Matt, cause I actually enjoyed reading that. If only his emails were written so clearly I for one am happy to see the direction this build is going, simple, minimal fab work. I suppose "seeing" is a relative term as there are no fawking pictures, but I digress |
Got to love tax refund time!!!!!
A nice multi-point T45 cage has been ordered, yes a little more money but..... full certification available, little lighter and smaller tube means more space for a fuller figured fella like myself. And given that to have a CDS cage installed here in Alberta is costing approx. $6000 at the moment, a $2500 T45 one is a valid option. The ECU was waiting for me to decide if I should keep the injectors batch firing as per Ford or to move to sequential firing. But seeing that Google is my friend, the cost v benefits of it means that in the continued vein of simplicity I'm going to stay with the batch fire setup. I just have to find a 34 mm restricter for the T3, as purposefully making the car a shade over 2900lbs just to not have one is a little pointless. The same for the suspension having talked with people who have the same suspension have said that the initial set it up from the factory has worked so well that they have not had to alter any settings since putting it on the car. They have the 3 way version but the single way can be set to the same settings, again simple. As for the diff I am waiting for the car to go to the paint-shop to rip out the rear end and install the Eaton slipper. Sorry AEV no pictures just yet, next time you are in Cowtown stop by and have a look.... Yes, it's a Ranger. Xr4Ti, it is rwd and was made in Germany. |
deaner Dane Aura Mega Moderator Location: Caldwell, ID Join Date: 07/07/2013 Age: Settling Down Posts: 346 Rally Car: PS4 controller |
dunhamr1 Ryan Dunham Ultra Moderator Location: Hurst, TX Join Date: 09/17/2015 Age: Settling Down Posts: 158 Rally Car: 1989 Merkur XR4Ti |
Not like he is the RallyWest prez or anything and would sort of know the rules... he did get the size wrong though :p
Matt, XR4Ti curb weight is 2920lbs... honestly, to get around the fuckery that is tuning with a restrictor (I don't know the options available for a XR4Ti that are cheap, but certainly stabbing a restrictor on top of a stock tune would not be very fun), why are you trying to make it lighter? Yes, lighter equals better I get that, but rallying is better than anything else. I know you have the truck, but still... I suppose if you want the XR4Ti to be Dave Clark levels of awesome, it makes sense. Just seems like getting that big ol' girl down to 2500lbs may not be easily achievable when running the restrictor, kind of defeating the point of running one. Edited 2 time(s). Last edit at 07/07/2017 02:14PM by dreamsofjvl. |
Oh Canada...! *sits down quietly* |
TBH I don't really need you to tell me how to build my car, I understand that I got the two sizes of restrictor mixed up. I am human after all. I'm pretty sure you have got your facts wrong on more than one occasion. Who mentioned anything about a stock tune, a Megasquirt 3 is most definitely not containing a stock tune. I am aiming for about 220-250hp which is way plenty for a RWD car. It won't be to Dave Clark anything, it again is my build to my specs and requirements just like the truck. As I have told everyone I am building this because I can and because I want to. There are things in it and on it that the "local wisdom" has deemed unnecessary or unwarranted. So what, not their car or build. Too many have been commenting that they wouldn't do what I am doing, that is fantastic for them, again my build not theirs. Whether it succeeds or fails is down to me and what I am doing with it. This should be called my "ZFTG build" The lightest the works Sierra in racing trim was 1040kgs / 2248# and the 1987 Xr4Ti DTM car was 1340kg /2948# so anywhere close to that is golden. At the min weight of 2900# and 220 hp it will be 760# lighter and 85hp better off than the Ranger, oh and about 15" closer to the ground... Press on..... Yes, it's a Ranger. Xr4Ti, it is rwd and was made in Germany. |
Matt, was bugging Ryan not you about the restrictor. The sizes have changed so much over the years I didn't know either.
Also not telling you how to build your car, just chatting about it. Curious to understand your thinking behind whether to run a restrictor or not. You know, I am able to have a decent conversation sometimes :p |
So I had a bit of a win win day yesterday.
I was told of an ad on Kijiji that had an XR4Ti for sale with spares for the princely sum of $350. Well I met up with the seller, as I only had $20's on me I gave him the option of $340 or $360 the lad opted for $340. Sweet I thought $10 up already. "Hold on" he said "you'll want these bits as well", hands over a Cosworth rad/intercooler combo one of those heavy ones not the cheap Chinese knock offs, SCORE.... "Wait" I heard again and he promptly hands over a Stinger manifold and 38 mm BOV, never been used, never even been fitted to a car.. Trying to hide the inner kid in a candy store I place them in the truck ready to go load the car up. "Do you want to know about the new Turbo?" chirped up the lad.... Wait, new what? "Yeah it has a T3/T4 ball bearing Hybrid I put on it and a new clutch in a box inside the shed if you want that as well. Oh and by the way the XR is a 2 owner 151k km car" Result....... Yes, it's a Ranger. Xr4Ti, it is rwd and was made in Germany. |
DanielSL Daniel Mod Moderator Location: Vero Beach, Florida Join Date: 03/02/2016 Age: Possibly Wise Posts: 338 Rally Car: 2005 VW Mk. 4 Golf GTI 1.8T |
MarkHille Mark Hille Junior Moderator Location: The hills of CT Join Date: 10/04/2011 Age: Midlife Crisis Posts: 135 Rally Car: I have two crap boxes |
