Yet another Xr4Ti
Posted by MattP
MattP
Matt Pullen
2002 Ford StRanger
Re: Yet another Xr4Ti
January 08, 2018 08:45PM
So been a bit busy lately sorry for the lack of progress updates, and I've also been waiting for some cage pieces to turn up. But since these have arrived it's a green light for the rest of the way.
Car is at KRR in Kamloops having the FIA T45 cage welded in, all the Wilwood 4 pot brake setups and Tilton floor mounted peddle box are in the shop. I decided to ditch the calble clutch and crappy quadrant thing and go with the hydraulic T9 clutch setup.
ATL Welcel 12 Gal fuel cell and single lift and single main pump Radium FCST surge tank is ready to go. The Evo Corse wheels were dropped off.
I have gone with the PimpX and full loom that will tie in using Canbus to the Aim MXL dash and GPS driven speedo. All the old loom has been ditched in anticipation of a self made Milspec wiring setup with just the wires I need not all the silly extras.
The goal is to get the car to be right on 2900# as this is the lowest weight before I have to install a 32mm turbo restrictor to meet CARS O2wd rules.
I did have another good result with buying spares! I bought an engine and gearbox combo from a failed project in Edmonton for $100, when I got it home I thought it looked like someone had removed the intake and head so I investigated.... Lo and behold I found a gutted upper and knife edged lower, looked a little closer and found the head has had the intake runners opened up and valve stems cleaned up, I will be taking the head off to check the rest of it in the next few days.
Yes, it's a Ranger.
Xr4Ti, it is rwd and was made in Germany.
open | download - Rear Cage.jpg (50.6 KB)
open | download - Brakes.jpg (30.8 KB)
open | download - Wheels.jpg (25.6 KB)
ElectroTech
Steve Wheeler
1992 Golf
January 27, 2018 03:20PM
Looks awesome!
tdrrally
edward mucklow
January 28, 2018 09:33AM
it's coming along nicely
MattP
Matt Pullen
2002 Ford StRanger
8 days ago
I have picked up a new motor for the car, the sum of all the parts is far in excess of the amount I paid for it.
From what the previous owners of it have confirmed is that at 15 psi on 91 octane it is putting a conservative 220hp at the wheels, even the dyno owner has said in the past that his machine reads 10-15% lower than others in the province so a true heart-breaker dyno.....
Yes, it's a Ranger.
open | download - New Motor.jpg (60.6 KB)
