Rallyho Wrote:
> john vanlandingham Wrote:
> > Get INSIDE the boxy "wheelhouse" and look
> where
> > the upper bolts go thru into the little
> square
> > nuts which are stuck in with dried snus on
> 96s and
> > 900s.
> > Then go look at the hefty 3/8th inch bar
> spanning
> > the 2 holes on the 99.
> > Do something similar. It'll look like a 3/8th
> inch
> > thick alignment shim drilled and tapped to
> M10 x
> > 1.5 or if you want to be classic 99, 3/8th
> UNC
> Yup...know what you're talking about. That area
> is wimpy on the 900.
OK, fix it. I just did that on PauL Westwicks 96:
> > > travel limiters on the rack...as in
> steering
> > > rack?
> > Yeah, the 900 is 2 inches longwer (if you use
> the
> > 99 upper link on the rear) and yet has same
> > turning radiius, I think they let the wheels
> crank
> > over more and 900s certainly blow more outer
> CVs
> > on street cars than 99s.
> > Ola concurred way back when.
> No kidding...interesting. So the 99 rear end
> links are shorter than the 900?
79&90 900 wheelbase was 99.4," later cars 99.1".
> > > Gp2 for now...cause I've got that motor
> with
> > the
> > > rebushed rods/veedub plugs/etc.
> > Didya ever get a Volvo 240 turbo fuel
> > distributor?
> uhhhhh, shit...did I? I cunt remember actually.
> Don't think so.
Goddam kids what happens? You give em books, send them to school and whaddya they do?
Can't Understand Normal Thinking, eh?
> > > Rallyho
> > > Mike White
> > John Vanlandingham
> > Sleezattle, WA, USA
> > Vive le Prole-le-ralliat
> > www.jvab.f4.ca
> Rallyho
> Mike White
Edited 2 time(s). Last edit at 02/24/2006 12:56AM by john vanlandingham.
open |
download -
(65.8 KB)
open |
download -
(54.6 KB)
