AN -4 or AN -3 for brake lines?
Posted by NoCoast
March 01, 2006 02:21PM
AN -4 or AN -3 for ss braided brake lines to caliper/drum? I can do either. Just curious as to if there's a benefit to smaller or larger.
Skye
Skye Nott
Xratty
Re: AN -4 or AN -3 for brake lines?
March 01, 2006 02:33PM
I used -3
www.rallyrace.net
March 01, 2006 02:54PM
Grant what I understand is if you are moving LOTS of fluid the you go for the bigger size.
BIG heavy cars with 4 x 1.88 and big masters like 3500 lbs Nascar maybe but all real rally cars (as in "over there"winking smiley I have seen used -3.
Hey spiiik-ing of prakes, are you poys going to pe joining in on the front pells and galipers?
March 01, 2006 04:12PM
You should already have my $85 deposit from back in August, so yes. As usual, you just have to keep me updated. A week or two's notice before you need money is always good too. Then I can stop spending and start saving for a short while. I only get a good paycheck on the first of each month too.
And it's just me building a Merkur. Aaron's running around down in South America and I have no clue what his plan is when he gets back in a few months. His car may just end up being a spare shell for me. It's sitting in my garage now.
cbombara
Colin Bombara
00 Impreza RSTI
March 07, 2006 08:28AM
BTW- If you are doing the entire -3AN conversion with hardline Summit sells a 37deg flaring tool for ~$40 that makes a nice flare. Pegasus Auto Racing also sells almost any adapter fitting that you would need to change a standard MC over to 37deg.
-C
March 07, 2006 12:37PM
Of course if we read deep enough we would find that below -6 a SAE 45* flare is OK and vice versa.
But we have to dig a while to read that.
(The point of contact between cone and seat is moved so infintissimally as to be unimportant.)
Scott Manley
Scott Manley
XR4Ti
March 07, 2006 12:54PM
> versa.
> John Vanlandingham
> Sleezattle, WA, USA
> Vive le Prole-le-ralliat
> www.jvab.f4.ca
Good to know!
Scott Manley
Spokane, WA
86' XR4Ti
37
