Axles
Posted by 1fastben
1fastben
Ben Hetland
Age: Party Animal
Focus ZX3
Axles
March 25, 2009 05:09PM
So I broke an axle this weekend at a RallyX. Stupid me, I think the ones I replaced before IR08 last year were OEM, and I replaced 'em w/ cheap aftermarket ones. I still have one of the OEM ones, (the place I had switch them out "couldn't find" the other one). Anyway, I the one OEM one that I do have is, luckily, for the side I broke.
But when this happens again in the future, is there a good aftermarket brand of cv axles I can buy for the Foci? Or do I have to go salvaging for used OEM? I'm not gonna spend my entire annual racing budget on two new OEM axles from Ford at $300 a piece. I know I'll get poo-poo'd by some of you for saying that, but please.
"No. Rally Racing is a back alley sport filled with jackals, headhunters and thugs!"
-Pops Racer (Speed Racer movie)
[www.worldrallysport.com]
www.utahrallygroup.com
Tom Burress
Re: Axles
March 25, 2009 06:03PM
buy new factory joints for your remans?
___________________________________________________________
Demon Rally Team :: Fine Tuning
CTS Turbo | RalleyTuned | Meister Autowerks | Spitfire EFI | Product Apparel
JRM | JVAB Imports | Techtonics Tuning | 034 Motorsport | Les Schwab | NLS
Myspace or Facebook
Next Event: Oregon Trail Rally May 14-16th 2010
[Nobody under 18 admitted. Void where prohibited by law.]
1fastben
Ben Hetland
Age: Party Animal
Focus ZX3
Re: Axles
March 25, 2009 08:20PM
Can you even do that? Mine broke not at the CV by the wheel, but at the middle cv section where it connects to the longer shaft that runs over to the trans. Is that part ever replaceable?
Merkur
Re: Axles
March 26, 2009 09:22AM
You might try getting in touch with CVJ Axles here in Denver. They rebuild the Merk ones for me for $100 per halfshaft, that's basically to stock, but they can do all kinds of fancy shit too.
www.nocoastmotorsports.net
Denver, CO
Andrew_Frick
Andrew Frick
Rally Spec Ford Focus
Re: Axles
March 26, 2009 10:21AM
Have you made sure you don't have anything else wrong in the front end? The stock inner CV on the Focus is pretty well designed unit unless it is over stretched or compressed. I would make sure that the axle is completely seated in the transmission and that thin metal bracket that holds the axle to the back of the motor is torqued to spec.
My cheap axles have held up fairly well. I check them for excessive play after every rally. For $50 a piece I replace them when they start to seem a little sloppy.
Re: Axles
March 26, 2009 10:43AM
> to spec.
> a little sloppy.
And Andrew beats on his Spec Focus as hard as anyone, IMO.
SgtRauksauff
Jorden
Re: Axles
April 07, 2009 02:54PM
autozone lifetime warrantee axles FTW. at least, in my case. It's really nice when it's the passenger side one goes. 15 minutes (or less) later, you're driving again, if you've got the right tools with you. again, in my case. 95 eScrotum wagon, not a Focus.
--sarge
Jorden R. Kleier
Baraboo, Wisconsin, USA
1990 Mazdog Protege 4WD
1973
1fastben
Ben Hetland
Age: Party Animal
Focus ZX3
Re: Axles
April 07, 2009 06:05PM
Yeah, its the opposite with the Foci, the passenger side axle is the long one. Would you guys recommend Autozone axles over, say, Napa axles? The Napa ones cost twice as much, but are they worth the extra fistful of dollars? (Napa has a lifetime warranty as well, I think).
Merkur
Re: Axles
April 07, 2009 06:13PM
Lifetime warranties and quick service time don't help a whole lot when you just paid a $750 entry fee and are 5 miles into the first leg and still have 20 stage miles and 40 transit to the first service, Hope that other one doesn't break.
Figure out what the best ones that won't fail are and pay the money. It's a small price to pay.
Denver, CO
SgtRauksauff
Jorden
Re: Axles
April 08, 2009 11:47AM
I completely agree with that. But what happens when your axles are now the strongest part of your drivetrain? Then you start breaking differentials and transmission parts, which is a hell of a lot more expensive in the long run.
So, your axle is like this:
Driver Hub|==[CV1]=====[CV2]==|Trans|==[CV3]============[CV4]==|Passenger Hub
And the CV3 joint is the one that broke?
I guess I was under the impression that the Focus had a jackshaft/intermediate shaft from the passenger side of the trans, supported by a bracket bolted to the block, and more-or-less equal length CV axles. That's how my eScrotum is (with the 1.8 DOHC transmission, the original 1.9 had the super-long pass. side also) and I'd figured that a newer car would have kept that bit of better technology.
I've got a driver-side hybrid axle from Raxles.com that seems to be VERY stout, a mazdaspeed protege LSD, and a custom Jackshaft made by Corksport, but I run a stock axle on the passenger side. Before I got the Raxles axle and the jackshaft, I'd been blowing the driver axle, which required re-filling the transmission each time I replaced it. After the raxles.com/corksport changeover, I've only popped the driver side once. The car's got a Mazdog 323GTX engine, 173.3hp/172.5ft-lb. The Raxles.com axle wasn't cheap, but it didn't break the bank either, I think it was about 180 or so. Also a lifetime warrantee, with overnight shipping in case of failure.
So, Raxles.com might be a place to check also.
I wonder if the size of the axle shaft itself were increased, if that would decrease the likelihood of the CV3 joint breaking, since there might be less twisty-springy action happening over the length of the thicker shaft,to shock and break the joint?
um,'twisty-springy action over the length of the thicker shaft'.... lol!
--sarge
Jorden R. Kleier
1973
Andrew_Frick
Andrew Frick
Re: Axles
April 09, 2009 07:28AM
Sarge on the Focus it is more like:
Driver Hub|==[CV1]====[CV2][Trans]========[Bracket][CV3]====[CV4]==|Pass Hub
So the actually half shafts are basically the same length. Changing either axle requires you to top off the transmission or make the car look like it is doing a stopie to get all of the fluid to the front of the case.
CV2 and CV3 use a tripod design similar to this:
I would be interesting to see what failed on the Ben's inner CV. If that joint gets bent beyond it recommended range or over extended it can become damaged. It is pretty easy to over extend that joint while changing struts since there is almost nothing other than the boot that is holding the tripod into the cup.
CV1 and CV4 are a traditional design.
SgtRauksauff
Jorden
Re: Axles
April 09, 2009 09:52AM
ahh, gotcha, it's a whole 1-piece deal, but still has a bracket. I like the 2-piece deal on my eScrotum just because of the non-drainage aspect, since filling is a royal PITA, you've got to yank the speedo gear out of the top to refill.
Back to Ben's issue, I wonder if a 'better'outer housing would fix the problem, or if it's the inner tripod that needs strengthening, or if it was the shaft itself that broke.
Good luck on finding something that works better.. would something from an SVT work, or are those parts even compatible and/or stronger?
Jorden R. Kleier
1973
Andrew_Frick
Andrew Frick
Re: Axles
April 09, 2009 10:27AM
SVT axles are compatible but I am pretty sure they are same part number from Ford so I don't think they were upgraded. grinning smiley
Edited 1 time(s). Last edit at 04/09/2009 10:27AM by Andrew_Frick.
Re: Axles
April 09, 2009 10:33AM
What's blowing up? Specifically?
1fastben
Ben Hetland
Age: Party Animal
Focus ZX3
Re: Axles
April 09, 2009 10:59AM
What broke was the CV3 joint itself, not any of the shafts. It just popped out of the tripod thing, and I lost a bunch of the ball bearings inside that part as well. The braket seems to be fine, but I dunno. It was during a rally cross, and I wasn't quite turning lock to lock, but I was getting close.
One thing that I've considered might have some kinda' negative effect on the CVs is the Kaaz LSD. I didn't know it could be adjusted before it went in, and so my guess is that its at 100% lock, if thats how it comes from the factory.
Re: Axles
April 09, 2009 11:41AM
> getting close.
If the tri brearing housing fucxored up?
did it spread out?
It's not 100% lock, jack one side, whip off the wheel and place a bar accross 2 studs and lean on the bar, it'll slip.
Lurch
Eric Burmeister
Mazdaspeed3 and Mazda Protege
Re: Axles
April 09, 2009 06:00PM
Please take pics of all the parts and post so we can figure out what happened. What manouver were you doing when it broke? What side was it on?
It sounds to me like you have too long of shock at full rebound and you pulled the thing out of the cup.
Lurch
Eric Burmeister
The west coast...of Michigan
brianallmotor
Brian Barton
Age: Party Animal
Mazda 323 BP-T
Re: Axles
April 09, 2009 08:11PM
suggested by Lurch at Rally WV is that our axles were flexing out of the outer CV cup. the retaining ring/crown/carriage/thingy that holds the balls -- was out of the cup, and one or more of the balls dropped into the rubber boot. this then caused shatering of the retainting ring/crown/carriage/thingy that holds the balls....
solution: put some washers behing the knuckle.
if ya cannot figure it out from there let me know.
btw- when we jack up our Mazda 323 with the front wheels off the ground, if i rotate the front wheels i can feel a CLUNK CLUNK in the front drive train. this is the balls in the CVJ carriage not being fully in place where they normally want to be. it is likely a factor why we have broken a front drive shaft in the past....we are working on this issue!
last time we broke down in transit to a regroup, at a right hand turn at a stoplight in the middle of town... no stress on the CVJ, the ring/crown/carriage had broken in a previous stage but the CVJ at that point in time was fully flexed, balls dropped out!
co-drivers: work out your legs
crew: pack an extra FWD shaft in the car
-Brian
1fastben
Ben Hetland
Age: Party Animal
Focus ZX3
Re: Axles
April 09, 2009 08:12PM
Alright, lemme take the axle wreckage to work tomorrow and clean it up a bit, then I'll try to post some pictures tomorrow night.
As far as the ride height threads go, I set it pretty low in on the tube, about half and inch from the lowest I can go.
Well ya see, what happened was I was going around the final tight turn in a rallyx on really soft, dry marshy dirt when it broke about 2/3 of the way through the turn, but I was able to finish the run (yay!). It was a sharp left turn with plenty of rutting already built up on the outside lines, so the strut would have been on the compression stroke, but I may have hit part of the rut a little hard, I can't say for sure.
And I'm a little confused now. Andrew, do you mean that CV-1 and CV-4, being traditional, are the tripod type or the regular "other" type? The tripod is the inner CV isn't it? Because that's what seems to have failed, then about 100' later of clanking as I was towed to my "service area", the other outer section came out.
Thanks for all the help and inquisition fellas, I really appreciate it; just so ya know! smiling smiley
Andrew_Frick
Andrew Frick
Re: Axles
April 10, 2009 05:33AM
My statement was that the inner CV joints or CV2 and CV3 are the tripod design where the outer ones CV1 & CV4 use a traditional CV design like the one below where you have ball bearings and a crown. See the image below.
Merkur
Re: Axles
April 10, 2009 09:55AM
If it is pulling out, it may be possible to get a bigger joint that will allow more articulation. I've talked with CVJ about this possibility with my car using a joint that will allow 22 degrees of articulation vs. the stock 18 degrees. But I've not yet had a problem with it. All the joints I've broken have been due to driving it with the welded diff too hard on tarmac. Then I drove it 100 miles to the event with one wheel drive so couldn't really tell exactly what cause the failure.
Denver, CO
Lurch
Eric Burmeister
Re: Axles
April 10, 2009 04:47PM
Alright.
There are 3 kinds of joints (at least). The one pictured above by Andrew is only going to be found on the outer ends of the axles. It allows movement in more directions (for steering's sake) but does not allow plunge.
The inner joints will have tracks that will allow plunge. That is, as the suspension moves thru it's travel, the distance between the trans and the hub gets shorter or longer, and the inner CV needs to take up the difference.
There are tripod joints like the ones above (3 "balls" are actually rollers and are fastened to the "race" on the inside and plunge in the "cups" on the outside), and there are other designs. Typical is the Lobro design like VWs and Porsches and most anything motorsport uses. Usually 6 balls with an inner and outer race and a cage to hold them in place. The races have angle cut slots for the balls to travel in. Porsche 930 joints are the typical pattern for most motorsport joints as they allow lots of angularity, plunge, and torque. (What we use on the Mazdaspeed3.)
If the failure happened when suspension was in compression, it is NOT likely that you pulled the race out of the cup due to shorting it...that usually happens when you have too much rebound travel.
If I read you correctly, it happened under full lock at full or near full compression. That's just a failure. Not a design flaw (unless you consider shitty axles a design flaw). It likely happened due to FULL WEIGHT of car on that corner + HARD ACCELERATION + SHOCK LOAD of car slamming into ruts. Now you know one of your FWD car's limitations.
For me it was 4L/kick on Burma. Snapped the 1.12" solid bar shaft right in half, but managed to finish thanks to LSD.
Go here and you'll probably learn something about axles: [www.rcvperformance.com]
Lurch
Eric Burmeister
Edited 3 time(s). Last edit at 04/10/2009 04:56PM by Lurch.
Lurch
Eric Burmeister
Re: Axles
April 10, 2009 09:24PM
I'd still like to see the photos of the parts. It would help us understand what failed under what forces.
The most durable setup we've found is not one that would be very roadworthy for the long run. RCV makes the front axles for bazillion horsepower CORR Pro4 trucks and they helped me make my system very dependable up to 450hp and 400ft/lbs. as long as we keep the shock loads under control. (Full sideways slide from gravel to tarmac under throttle with weight transferred to one side will twist the output spline thru the hub...Mexico Rec. Area-MFR)
The trick is often in the hardness of the metals used. The inner races and cups need to be softer than the balls and cages. How much softer is the question. Too hard and they shatter under shock load. Too soft and you'll burr up the ball tracks to the point where the joint hangs up.
If you're serious about finding the best axles, once you have something that works well, find a college with a metallurgical testing lab, get Rockwell hardness numbers for each of the parts, and you'll have something for a litmus test in the future if your favorite axles are no longer available.
Lurch
Eric Burmeister
