KTurner Kevin Turner Elite Moderator Location: Newark, DE Join Date: 01/27/2006 Age: Settling Down Posts: 256 Rally Car: 2wd Impreza... dude you should do an sti swap |
You know those things that cover the shock to keep the dirt off everything and maybe means that the shocks need cleaning and rebuilding less often. Aftermarket ones come in wicked cool colors, with flames or lightning bolts.
Is anybody using these? Or should I just move along and focus on something important? -KTurner Stomp down on the exhilerator and hold on to the wheel. |
john vanlandingham John Vanlandingham Elite Moderator Location: Ford Asylum, Sleezattle, WA Join Date: 12/19/2005 Age: Ancient Posts: 9,747 Rally Car: Saab 96 V4 |
KTurner Wrote:
------------------------------------------------------- > You know those things that cover the shock to keep > the dirt off everything and maybe means that the > shocks need cleaning and rebuilding less often. > Aftermarket ones come in wicked cool colors, with > flames or lightning bolts. > > Is anybody using these? Or should I just move > along and focus on something important? Flames and lightning bolts are important! Are you saying you think they aren't? Wanna fight? Oh YEAH!!! > > > > -KTurner > Stomp down on the exhilerator and hold on to the > wheel. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Tom B Tom B Professional Moderator Location: Seattle Join Date: 02/27/2006 Age: Settling Down Posts: 746 Rally Car: VW Golf |
probably wouldn't be a horrible idea, I tried to fit some on my coils, but the ones I had were designed for factory springs....gotta get something lower profile for the coilovers
-Tom DemonRallyTeam | Fine Tuning | CTS Turbo & RP Turbos | RalleyTuned | JRM | Meister Autowerks Spitfire EFI | Product Apparel | JVAB Imports | NLS | AP Tuning | USRT Add us on Facebook | Next Event: 2012 Olympus Rally Sept. 22-23 Olympia, WA |
NoCoast Grant Hughes Senior Moderator Location: Denver, CO Join Date: 01/11/2006 Age: Settling Down Posts: 4,924 Rally Car: Merkur |
If I did shock covers, I'd want them to extend almost entire length to also protect the threads on the coilover body. Mike Rose had a set on his All Wheels Driven suspension that looked pretty cool. Then again, I also don't believe in (or at least bother to) adjusting ride height so it's not that big of a deal.
Grant Hughes www.nocoastmotorsports.net Denver, CO Edited 1 time(s). Last edit at 07/13/2009 02:37PM by NoCoast. |
cblakely Chris Blakely Elite Moderator Location: Renton, WA Join Date: 11/20/2007 Age: Settling Down Posts: 97 Rally Car: '92 VW GTI 16v on MSnS-E |
i cut up some old rubber inner tubes and zip tied them over my coilover threads. I definately buggered up the DMS set I had with a few years of not covering them. generally its not that the threads get damaged but that a bunch of dirt gets packed in there so tight it doesn't break loose easily. After some serious elbow grease with a wire brush the darn thing will turn again, so I figured this time around I'd try and protect them a little.
------------------------------------ http://www.ckrally.com |
jameseshepherd Jim Shepherd Elite Moderator Location: A few hours north of Seattle in the state of confusion Join Date: 10/20/2008 Age: Possibly Wise Posts: 27 Rally Car: 2001 Toyota Celica GT-S |
http://www.dirtbagz.com/db_main_pages/db_main.htm
These are the ones that All Wheels Driven installs on their shocks |
jameseshepherd Wrote:
------------------------------------------------------- > > [www.dirtbagz.com] > These are the ones that All Wheels Driven installs > on their shocks How ironic. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. Edited 1 time(s). Last edit at 07/14/2009 08:04AM by john vanlandingham. |
Cosworth Paulinho Senior Moderator Location: Banbury - England Join Date: 03/15/2007 Age: Settling Down Posts: 487 Rally Car: Honda Civic |
Doivi Clarkinen Infallible Moderator Location: the end of the universe Join Date: 02/12/2006 Age: Midlife Crisis Posts: 1,254 Rally Car: 1980 Opel Ascona B |
Cosworth Wrote:
------------------------------------------------------- > Old trick from back home... racer's tape wrapped > around the coils. Works perfect, keeps all the > junk out and protects the seals, inserts, etc. > > > > Might not go well with JVL as it means less > rebuilds for him > Actually, I would say it means more... All that does is keep the dirt and muck that will inevitably get in there packed around the insert or shock shaft. It's all going to settle around the seal and be held there accelerating wear. I can see tears in the duct tape already. Plus tape is even worse than boots because the dirt will stick to it! If you have inverted Bilstein style inserts the boots will hold in dirt and scrape them up. After the event when you (I'm speaking generally to people who use shock boots) park your car the muck and moisture caught in there will cause things to rust prematurely, because I bet you a nickel that you are not taking apart and cleaning your shocks after every event, even though you should. Plus, for inverted inserts at least, boots can interfere with cooling. You're better off with no boots and do a little maintenance once in a while! Wash those suckers off! You can do it during and event (if you have no boots). Just keep things clean and they will be fine without boots. |
Doivi Clarkinen Wrote:
------------------------------------------------------- > Actually, I would say it means more... All that > does is keep the dirt and muck that will > inevitably get in there packed around the insert > or shock shaft. It's all going to settle around > the seal and be held there accelerating wear. I > can see tears in the duct tape already. Plus tape > is even worse than boots because the dirt will > stick to it! If you have inverted Bilstein style > inserts the boots will hold in dirt and scrape > them up. After the event when you (I'm speaking > generally to people who use shock boots) park your > car the muck and moisture caught in there will > cause things to rust prematurely, because I bet > you a nickel that you are not taking apart and > cleaning your shocks after every event, even > though you should. Plus, for inverted inserts at > least, boots can interfere with cooling. You're > better off with no boots and do a little > maintenance once in a while! Wash those suckers > off! You can do it during and event (if you have > no boots). Just keep things clean and they will > be fine without boots. > No, actually not. I normally replace the tape after every event and the damper and is almost always spotless inside. How can that be more harmful for the damper. |
modernbeat Jason McDaniel Junior Moderator Location: Dallas, TX Join Date: 12/14/2007 Age: Midlife Crisis Posts: 294 Rally Car: 1963 SAAB Historic, 1995 Impreza Open Light totaled at WRC Mexico, 2005 STi Pikes Peak winner |
I put wax in my shock threads. Hard wax, not the sticky beeswax. Not much of it sticks around, but it keeps the crud from staying put.
cblakely Wrote: ------------------------------------------------------- > generally its not that the > threads get damaged but that a bunch of dirt gets > packed in there so tight it doesn't break loose > easily. After some serious elbow grease with a > wire brush the darn thing will turn again, so I > figured this time around I'd try and protect them > a little. > > ------------------------------------ > > Jason McDaniel |
tmachnik Tom Machnik Godlike Moderator Location: Edmonton, Alberta, Canada Join Date: 01/31/2008 Age: Settling Down Posts: 69 Rally Car: 1985 VW GTI |
Cosworth Wrote:
------------------------------------------------------- > Doivi Clarkinen Wrote: > -------------------------------------------------- > ----- > > > Actually, I would say it means more... All > that > > does is keep the dirt and muck that will > > inevitably get in there packed around the > insert > > or shock shaft. It's all going to settle > around > > the seal and be held there accelerating wear. > I > > can see tears in the duct tape already. Plus > tape > > is even worse than boots because the dirt > will > > stick to it! If you have inverted Bilstein > style > > inserts the boots will hold in dirt and > scrape > > them up. After the event when you (I'm > speaking > > generally to people who use shock boots) park > your > > car the muck and moisture caught in there > will > > cause things to rust prematurely, because I > bet > > you a nickel that you are not taking apart > and > > cleaning your shocks after every event, even > > though you should. Plus, for inverted > inserts at > > least, boots can interfere with cooling. > You're > > better off with no boots and do a little > > maintenance once in a while! Wash those > suckers > > off! You can do it during and event (if you > have > > no boots). Just keep things clean and they > will > > be fine without boots. > > > > No, actually not. I normally replace the tape > after every event and the damper and is almost > always spotless inside. How can that be more > harmful for the damper. > Well there you go, you are doing actual regular maintenance after each event unlike most people. |
Do It Sidewayz Chris Martin Mod Moderator Location: Toronto, Ontario Join Date: 01/15/2006 Age: Party Animal Posts: 529 Rally Car: E-85 powered Impreza |
I've run like 10 rallies on JVAB 50mm stuff, with no boots with not much problem.
I do after every rally jack the thing up and powerwash all the junk out of it....often the car poops 100 lbs of mud all over the driveway and down the road to the sewer. Usually a pull the things apart after every 2nd rally and throw in some fresh grease. Only time i've toasted a seal is when we had issues with bushings, and the seal was actually the bushing for a bit! Chris |
Haztoys David Rodgers Senior Moderator Location: Prescott Valley AZ Join Date: 03/16/2007 Posts: 165 Rally Car: 90 Mitsu truck ..And needing something new just not sure what..??? |
EricW Eric Wages Infallible Moderator Location: Goose Creek, SC Join Date: 12/09/2008 Age: Settling Down Posts: 177 Rally Car: 2002 WRX |
Bringing it back from the dead.
I had a rebuild on my struts. 200mi later on just street driving and a SMIDGE of offroad testing, I blew a seal and puked fluid out of one of the struts when jacking the car up. Sent back for another teardown and the result is everything looked okay, just some dirt past the dust seal :/ It dumped about 1 oz of fluid. Anyone have any reasonable shock covers out there? I've seen a few DIYs but don't really have a lot of time with a week to go before loading the car when I still have yet to get the suspension back from rebuild
heymagic Gene McCullough Junior Moderator Location: Elma, WA Join Date: 01/25/2006 Age: Ancient Posts: 2,911 |
A1337STI Alex Rademacher Junior Moderator Location: Reno,nv Join Date: 09/10/2007 Age: Settling Down Posts: 460 Rally Car: 93 GC with an 01 RS swap! |
I used those dirt bags that are linked to. If you secure them to your upper spring perch they do a good job of keeping dirt and water out of the area, and out of your threads. though yes i did still get some dirt/gunk in there... seems to be less than before and far less thread damage/
I also use duct tape for the threads below the lower spring perch. sticky side Out for a few goes around, and then sticky side in. now that i have a garage (and will have 2 sets of JVABS) I'll be doing maintenance after every rally. |
Towona Tony P Senior Moderator Location: Red Deer, AB Join Date: 08/21/2010 Age: Settling Down Posts: 19 Rally Car: MK2 Golf |
OK but we have to figure out this Burmeister top mount thing and if you have springs right for the car...I may make this stuff but I have no idea what people do once its gone... John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
My 2012 plan is to :
1) install coil overs and adjust ride height to where i want it set. 2) taking Teflon tape I will tape the top edge of the lower spring perch along with some of the threads. 3) Below lock ring I will duct tape the threads (Sticky side out once, sticky side in twice) 4) I will install a custom made Coilover Cover a)secure the velcrow b) tighten the top and bottom with bailing wire. ---- In between rally events I will self service my suspension 1) remove coil-over covers and clean out everything with compressed air, and a tooth brush 2) dissemble strut a) check insert with a straight edge to confirm its not bent. b) inspect bump stop c) inspect upper seal d)re-grease What am i missing? How long will the inner seals (bearings?) last if i service my suspension like this. I don't think we have the right tools to change an inner seal(bearing) if any are used.
fliz Chad Eixenberger Super Moderator Location: Grafton, WI Join Date: 02/01/2007 Age: Settling Down Posts: 345 Rally Car: 1988 VW Golf #687 |
