Scott Manley Wrote:
> Well I imagine, as I haven't gotten to the point
> of install, but on the XR I was thinking that the
> stock moulding would hold the top in and have some
> kind of release pin holding the bottom. Should be
> able to push the lexan out of the moulding in
> hurry. Or just have it drop into the door when
> you pull the pin. But maybe that won't stay in on
> the road? It holds the glass in fine, but glass
> doesn't flex as much.
You've got the right idea, it will work just fine. When I've done Lexan in rally cars I've made the front windows quick release. With a framed window just use the stock channel and moulding. I make a couple of brackets at the bottom and attatch the bottom of the Lexan with a couple of Dzus fasteners. A washer attatched to the door somwhere with a string or wire so it doesn't get away provides you with a tool to undo the Dzus fasteners. Then you should be able to just slide the Lexan down and out of the way. That way if you roll over and the door gets jammed or something you won't be trapped. Plus it's safer than glass because it won't break in a roll and allow your head or arm outside the car.
