SteelSolutions William Timmins Junior Moderator Location: Redmond WA Join Date: 02/26/2008 Age: Party Animal Posts: 612 Rally Car: 3 xr4ti/74 capri/02 bug eye |
RWD Focus:
Why; 1 They are very plentiful there are over 2,000,000 in the us alone! From 2000 to now they have not changed suspension framing, With a few minor changes like in 05 they moved to ears for there front brakes. 2000 to 2004 are showing up in our local inexpensive junk yards, where spare rack and pinions and components are cheap and in huge numbers. 2 The cars are only falling more in price I have seen running 2000 focus's for under 1000 and almost free if they have motor issues. Also now on CL there is two 2005 with 2.0 duratecs for 3500 obo. 3 The Duratec! a very versatile and good power plant that picking up a huge after market fallowing thanks to open wheel and custom swaps in the UK and states. The ford harness is flashable and easy to adapt and swap. In the states any mazda turbo 2.3 steel crank will fit the 2.3, and they go for $300. 4 The swap parts are easy to find, such as ford explorer rear diff and t5 transmission. The explorer diff has a limited slip factory but can be upgraded with a carbon Kevlar clutch pack and forged housing for under $300 and can have custom preload for little extra, along with about any gear choice needed for street or rally. 5 The front and rear frame will have to be replaced and thats what I will be building and selling The goal for the frame's cost will be $1200 for front and rear frame. There are quite a bit more parts that it will require but this to get to a point where the focus can be the best RWD for the buck. 6 Cost. I want to set people up with the options to have a rwd car that with have a near perfect formula, Close ratio gear box good limited slip and with plenty of power NA or turbo. If the budget is tight there are several stock ford transmissions like ranger or miata 6 speed. and stock gear ratios and limited slips are not that far off from pretty damn good. 7 Repairs and spares. With the cost of diffs and t5s and duratecs people can afford to have spares. Going home with blown motors or a dead box's would be a thing of the past for the entry level racer. 8 Other cars This swap kit will not be just for focus it will cross in too the mazda 3, volvo s40 60 80 and c30. It will also work with for the UK focus market. The build I am using the ford explorer rear IRS from 2002 to present, there spline count is 31 and 29 outer. They are rather large but made of aluminum and can withstand huge hp numbers. I will retain the stock explorer cv and outer flange and bearing, the cv is overkill but cheap and plentiful. The diff will be mounted with similar geometry as the stock focus, the was the diff is made allows for mounts that will make the diff pull out from the bottom making changing them in to 8 bolts, 4 for the drive line and 4 for the diff on a 06 plus and 3 for a 2002 to 05. I will be making a fabricated rear knuckle and use the focus trailing mount its tucked up and in which is great for protection. The knuckle with be shaped with a void at the bottom so when you unbolt the hub you can pull the hub brake and cv at once. With this you can change a cv in 3 or 4 minutes. The back of the car has quite a bit of room but will require a small tower to be installed for a coil over shock, My goal is 12" of travel with the set up. The rest will be bolt on. in the front I will retain the stock power steering and build a new direct bolt on frame and move the rack forward and bolt in from the bottom. with this there will be the second peace of fabricating, of installing a small preformed tranny tunnel that would be best welded in. motor mount will have to be fabricated but should require little to no welding on the car, due to the existing mounts on the passengers side and fabricated ones on the drivers side. front suspension will not be changed unless wanted I do plan on making long travel parts, with fabricated arms but this would be icing on the cake. The bolt pattern will be changed to 5 on 4.5 and the mazda 3 knuckles already have this in the front and swap over. for brakes I will make a large brake kit but again thats more parts that are outside of the RWD swap. Thanks for reading This is what I hope to make my niche for years to come. |
So today I go a full back half of a 2006 explorer frame for $150
that limited slip and cvs an all the other junk it comes with very interesting that the focus looks like explorer's little brother. The links are all the same positioning and seem to have the same off set of the short front link. I would say the shorter front lower link provides more toe in on drupe to keep the car stable when lifting off the ground. this is the hub the flange is a re drilled stock explorer and stock bearing. allen head bolts will stick right in there and allow a farther off set for more material around the bearing. Now that I have the diff in hand i can draw up an compleet idea of the frame and rear diff with arms.
phlat65 Sean Medcroft Mod Moderator Location: Edmonds, Washington Join Date: 02/12/2009 Age: Midlife Crisis Posts: 1,669 Rally Car: Building a Merkur |
Rallymech Robert Gobright Junior Moderator Location: White Center Seattle Join Date: 04/27/2008 Age: Midlife Crisis Posts: 1,090 Rally Car: 91 VW GTI 8V |
Andrew_Frick Andrew Frick Mod Moderator Location: Greenville, SC Join Date: 05/18/2007 Age: Settling Down Posts: 484 Rally Car: Rally Spec Ford Focus |
Have you seen the Kugel Komponents swap kit that already exists for making a Focus RWD? It is a well engineered kit that I believe was designed with Ford's help since it came out just weeks after the focus came to the US.
http://www.kugelkomponents.com/focus/focus.html Looks like an interesting project. The biggest issue I see is getting the steering to work right since the knuckles that are on the car and the ones that are you looking to use are both designed for the rack to be behind the wheels. Are you going to swap the knuckles side to side? If you are going that far why not use a RWD knuckle like the one off a miata or mustang so you do not have to deal with the FWD wheel bearings. Good luck. |
I have, not to be rude but WTF! solid 8.8 and the rear, shocks hang way below the axle and bolt on to a little bar under the car. This kit was not meant for more than 5 inches of travel. We know how to make a very affective solid axle car, and its with 24" plus 4 link. But due to this car is just the now no v8 no solid axle looks to me they just wanted a nascar that could parallel park Then to have to buy custom steering rack, have you seen how much they gouge you? they say 20000 to put a car together! with my parts 20000 would be fire breathing top level group 2 car like the rest of the world. I have stared endlessly at there parts I have not seen one interesting or useful part that looks applicable to a real world multi purpose car. the focus is a light car by todays standards but a v8 and a beam axle Its just old tech hefty and not needed. the other little thing is the stock focus and mazda 3 have a sump on the wrong side well turns out that will be to an advantage due to the cross member mounted back. that means we can run stock sump and just shift the new frame around till the fit and maybe make some sort of new connection for the steering. the front wheel drive wheel bearing is great. just put a bolt threw with the right washers and tighten it up. The other reason the more i keep the same the less people I will scare away, with the price and work. I want to make it a point that I have the cheapest parts as well like a re-drilled ford hub well I can get them for 20 bucks. and toss in some new holes and a little fat trimming and ill sell hub and bearing for about 70 dollars. the best thing about there v8 kit is they can make money on them! It's my turn. Edited 1 time(s). Last edit at 01/26/2011 10:19AM by SteelSolutions. |
fiasco Andrew Steere Mega Moderator Location: South Central Nude Hamster Join Date: 12/29/2005 Age: Midlife Crisis Posts: 1,501 Rally Car: too rich for my blood, share a LeMons car |
What about refining what's already been done with these Foci and Fiesters (think O'Neil's Focus and Block's Fiesta). Mock up the tail end of a Escort Cosworth WRC (or Group A...not as nice, but the square beam already exists) and Supra-izing the rear end?
That Exploder stuff is big, ugly, and heavy, and the only real troubles my friend has had with his 2003 Exploder are with the rear wheel bearings (done twice in 150k miles) and the rear diff howling (think it's been replaced three times, maybe just twice). Just thinking out loud...not gonna be insulted if you think I'm a moe-ron. |
Well OK fiestas rear suspension looks like a golf and has no similarities.
I love the supra diff but they will run out and there older, explorers are still coming out they howl because they leek if never taken care of and the bearing style they use is just not beefy enough for a 6000 lbs truck they might be ok in a 2500 car. the beam swing arms are not and option at all the car dose no have the room its needs to be just like the explorer and focus they are the same style it must work really well if theres millions of cars with this varying of geometry. the beam is a cool idea but the way the floor is set up it would take some serous cutting and welding to get the beam up in to the car. The bmw diff is nice too but thats more parts to make for the cvs and other stuff like that and they are out of production and change quite a bit. and a big part of it is its ford sounds corny and im not a person that cares how Frankenstein my car is but I think in the long run of sales ford on ford would prevail. not to mention theres no hunting needed for these parts. big and ugly no they are smart! the diff threads from the back and pins form the bottom it can come out of the car in seconds its large but its aluminum and saving a few lbs o dear. |
tmachnik Tom Machnik Super Moderator Location: Edmonton, Alberta, Canada Join Date: 01/31/2008 Age: Settling Down Posts: 69 Rally Car: 1985 VW GTI |
True if it dose get pumped up maybe the rules can be bent or revised. Rally will be the smallest buying community, street cars will be the main target. UM ya chevy truck t5 with dog kit and a milled transfer case would make a bitchin AWD just like a bunch of hill climb cars and hmm the car is already has front drive wheels. I will make awd for it latter. theres lots of nice little truck front axles that can be adapted would be funny though to have this in open class for a lot less that a subaru with dog box and 3 diffs and full suspension. Edited 1 time(s). Last edit at 01/26/2011 02:48PM by SteelSolutions. |
wvonkessler Wilson von Kessler Elite Moderator Location: Lookout Mountain, GA Join Date: 02/28/2006 Age: Midlife Crisis Posts: 786 Rally Car: Colts are in Finland; now '87 325i, '89 325i |
fliz Chad Eixenberger Infallible Moderator Location: Grafton, WI Join Date: 02/01/2007 Age: Settling Down Posts: 344 Rally Car: 1988 VW Golf #687 |
Cosworth Paulinho Super Moderator Location: Banbury - England Join Date: 03/15/2007 Age: Settling Down Posts: 487 Rally Car: Honda Civic |
john vanlandingham John Vanlandingham Professional Moderator Location: Ford Asylum, Sleezattle, WA Join Date: 12/19/2005 Age: Ancient Posts: 9,720 Rally Car: Saab 96 V4 |
Well we just loaded into his truck the Duratec motor i had in the van waiting to be victim. Last night i was saying its time to clamber into the engine compartment with a bare block and the tape measure. There's is no point in making some morpho-junk thing like that junk V8 shit with the entire motor in front of the spindle---they're already making vile junk, how much of a market is there for shit? Way I was thinking is we have to look at the rwd pick up derived sump and see where that would end up in relationship to the OEM Fucus crossmember and rack. If we must do sheetmetal work for the bellhousing anyway, what's a bit more sheetmetal to get the motor back to at least say centered between cylinders 2 and 3? Seems a worthwhile target. |
yes theres no reason we cant get to 50 50 with two people in the car
Honda kicks ass I know! and I thought of it the only reason I did not want to use a honda is they already have the workings to be the best front wheel drive rally cars. They have all the awesome parts in transverse box that we are trying to get in the focus with rear wheel drive. and theres millions theres about 5.000,000 cars in the us alone that can be a victim to this rwd kit I want the biggest market out there that I can control. |
This is what I picked up for $150 It's a 2006 exploder the 02 to 05 have only one front
mount, but should work with out any issue and the mounts are close enough if someone wants a supra diff just ask. What I see strange was theres not a lot of adjustment but it looks like the frame has some other settings for the trailing arm. Must be just for other trim packages, but makes me think for the first frames put a lot of holes for adjustment theres seems to enough room.
This is the focus, if you look for a wile all the arms correlate with the explorers arms
NoCoast Grant Hughes Mod Moderator Location: Denver, CO Join Date: 01/11/2006 Age: Settling Down Posts: 4,921 Rally Car: Merkur |
almost nothing but yes I will be drawing an frame idea and links they will all be adjustable the focus uses a link thats about a 90 and gos around the frame rail so that will be something I will need to think about I want the two front links the same length and reach as far in as they can but still miss the frame rail. That upper link will be hard bushing mount to the frame do the bend at the end and then a trailing adjuster on one end. |
mellow65 Matt Weaver Ultra Moderator Location: Oregon City, OR Join Date: 09/10/2008 Age: Settling Down Posts: 373 Rally Car: Mazdaru BR-7, rally truck, the taxi |
derek Derek Bottles Infallible Moderator Location: Lopez Island/ Seattle WA Join Date: 12/20/2005 Age: Midlife Crisis Posts: 813 Rally Car: Past: 323, RX2, GTI. Next up M3 ? |
The best reason not to use a Honda; Honda's are good cars and thus hold their value too well. Besides are we on the 3rd body style since 2000 vs the Focus that is on the same body style? A cheap Honda will look old.
It is always best to start with the cheapest box that will do the job, $1000's saved for other bits. |
heymagic Gene McCullough Junior Moderator Location: Elma, WA Join Date: 01/25/2006 Age: Ancient Posts: 2,907 |
US maybe had around 2 million sold in all the years combined. Best year for sales was 2000. In 2009 Ford lost about 1 billion on the Focus..somehow..so they say.
One body change in '05 and a platform change around 07. Supposedly set for death in 2012 or so. The other kit is around $5500 with out the drivetrain, including suspension bits, not badly priced in the scheme of things. So from a business standpoint I don't see this making you rich William. Many reasons from the actual popuarity of the car amoung the tuner crowd (or lack of) to insurance issues and even the availability of used Mustangs. However we all have dreams that sometimes actually get pursued so you get an attaboy for that and I hope it pans out. |
gpbullock Mark Bullock Professional Moderator Location: Ridgecrest, CA. Join Date: 03/13/2008 Age: Midlife Crisis Posts: 108 |
New Ford Focus set to be released in 2012, fashioned after the UK Ford Focus.
http://www.ford.com/cars/focus/2012/?searchid=444987|32151951|210469273 |
thats one side of it We are going to be doing the mazda 3 at the same time. not to mention making a frame for for car guy that want cheap irs, and I want to make brake and other suspension options for the other cars as well as the focus. theres 3 car companies on the same suspension. Edited 1 time(s). Last edit at 01/28/2011 09:04AM by SteelSolutions. |
hear is a look at the explorer diff with the supra diff
both of these are open diffs and the supra weighs 79lbs and the explorer is 69lbs not a big deal to me just interesting. With out the ears in the back of the explorer diff it would barley have a larger foot print than the supra or most anything that is as big and nasty as these two.
