RSF2000 Rally Sport Focus! RWD Revolution
Re: RSF2000 Rally Sport Focus! RWD Revolution
June 14, 2011 10:03AM
2008
Engine
Mercury Sable 3.5,FLR,4AT,COMP 180 ACROSS 3,000 A GXF915 $798.98
car-part not bad thats 3 years old at 3000 miles! hah
I left the 3.0 off for no reason its a mondeo and looks to be completely different
They probably just wash up on the beach theirs so many,
just thinking out loud there guys out there that want more and a 3.5 already making 265 hp Im sure could be made in to something wild.
June 16, 2011 05:50PM
hear is the rear hubs im going to use they are Intrepid front hubs they are really cheap 5x4.5, and
33 spline new custom shafts are going to be under $200. I am using them on another project aswell
a 1200 hp subaru with a ford 9" irs.
Greg Donovan
Greg Donovan
95 Impreza Sedan
June 16, 2011 10:03PM
i think it could be cool to use a coupe like this:
sort of reminds me a bit of the MKII escort.
throw some box flares on it and you could have a pretty cool car. of course that would be more $$$ since the coupe is pretty new.
Edited 1 time(s). Last edit at 06/16/2011 10:04PM by Greg Donovan.
June 16, 2011 10:27PM
um ya I have thought that since I started!!!!
if you hunt you can get a 08 2 door for 6000.
That's why I call it rsf2000 would be sweet parked next to a rs2000!!
when the st turbo comes I'm going to buy one and do the kit to it, that's
the goal.
Greg Donovan
Greg Donovan
95 Impreza Sedan
June 16, 2011 10:38PM
the goal.
thank goodness i am not the only crazy one who thought of a MkII the first time i saw one of those.
by the time they drop down to the $1000 range maybe i will be able to do this swap.
Ted Andkilde
Ted Andkilde
1968 Mini
June 18, 2011 06:00PM
Hey William
Quick Q
Does the 4 liter tranny have the same bellhousing bolt pattern as the 2.3/3.0l tranny?
Thanks, Ted
June 18, 2011 06:42PM
no I still wonder about the new v6 mustang because the 4.0 and
newer mustang have much better gears would work fine with a turbo.
June 22, 2011 01:37AM
Another Focus! it has 1200 miles on a wreck the front work
will be one off like motor mounts but the front frame and rear frame will
be spot on and give us a good idea of that the production frames will
look like. Shops full of cars so it gets to live with my Subaru parts tester.
first we get to see how far back we can realistically stick the motor back the
goal is to get cylinder 2 in line with the front hubs.
June 22, 2011 09:45AM
Awesome! Big step.
June 22, 2011 09:37PM
Hear is the ranger block set in there looks a little forward
Might be able to get another inch but that would be pushing
It. The air box is really close to the tunnel but the tunnel
Is not bad size but the room needs to be made for the
Bell housing.
Greg Donovan
Greg Donovan
95 Impreza Sedan
June 22, 2011 10:15PM
saw a clever way to modify a trans tunnel in a hotrad magazine. they used a heavy gauge steel wheelbarrow and then cut it up and rewelded it to fit. got a nice curve to it without having to fiddle around with shaping metal.
now the question remains as to how sturdy it would be for rally...
Edited 1 time(s). Last edit at 06/22/2011 10:16PM by Greg Donovan.
June 23, 2011 12:04AM
Greg Donovan
Um I don't think thats the question at all there are lots of focus's rally and rally x
and street 4x4 focus's that do quite well as north south motors. The hardest part
in this is not any one thing its making a package that work and dose not take
a 6 year degree to pull off. I am most mad about the air box that is something
thats not just metal work if it needs to be modified. Tunnels mounts and bars
I can make and reproduce redly and effectively.
The focus will need tower reinforcement no matter what motor sport its going to
be used for they move and pull a lot its probably the worst down fall of this chassis.
Edited 1 time(s). Last edit at 06/23/2011 12:06AM by SteelSolutions.
Greg Donovan
Greg Donovan
95 Impreza Sedan
June 23, 2011 12:10AM
i meant using a wheelbarrow as a a source for tunnel modification to save some labor.
i am sure your work will be just fine for rally.
June 23, 2011 12:32AM
Ahh I see ya I have a cnc table I can make a cardboard tunnel and copy it perfect.
Greg Donovan
Greg Donovan
95 Impreza Sedan
June 23, 2011 02:46AM
well i guess that could be made to work...
