MRWmotorsports Wrote:
> How thin? If you mean .095 that's not thin! I've
> bent .095 in that style of bender no problem. I
> don't know if it was an actual Hossfeld, or a
> clone. I also don't know if it ws using 180 degree
> dies, but I think they were for a tight radius...
> I presume you aren't going to be doing 180 degree
> bends?
> I don't think there will be any issues, but if you
> are concerned to a test piece.
> -Martin.
Gut tells me that it'll work fine and AFAIK the tightest bends I'm looking at are in the 90º range, BUT...
The bender has a range of large bend radius pipe dies at the moment and I'm looking at having to buy the tube dies, at $300 apiece, for it which Hossfeld says only work with .120" wall or heavier.
I was hoping to find someone with actual experience bending DOM on a Hossfeld before I decided to shell out against the advice of the manufacturer (because I am a huge idiot
I've wasted some time on Google, and for the most part, folks really love their Hossfeld benders but don't give them a ringing endorsement for working with thinwall tube.
So, since it's only money...
I'm leaning towards:
http://www.pro-tools.com/105.htm
which appears to retail for about $800 with two diesets.
or this:
http://www.jd2.com/
which looks to be about $950 with two diesets.
FWIW, attached below is a pic of a Hossfeld, it's a big unit, roughly 3 times the size of a JD² bender and a fair bit more agricultural looking.
Edited 1 time(s). Last edit at 01/15/2007 10:44PM by Ted Andkilde.
