Oil Cooler Hoses
Posted by Carl S
Oil Cooler Hoses
April 15, 2007 06:51PM
So I scored some gigantic 34 row oil cooler off ebay for $35. Its got -8 fittings on it already and I need some lines for it. I think the fittings on the sandwhich plate are pipe thread.
So I was thinking of using some of this hose: http://www.stockcarproducts.com/aqp14.htm
and using -8 fittings on one side and npt (or whatever is on the sandwhich plate) on the other end. Then I wouldnt need any adapters or anything.
So does anyone have anything to say about using the hose with fittings that have nipple ends held on by hose clamps? They shouldnt really see much over 90psi ever and be much cheaper than all the blingin AN fittings and stainless braided fancy pants lines.
Yay, nay?
Re: Oil Cooler Hoses
April 15, 2007 09:00PM
DOOOOOoooooooooOOOOOODD. That's huge.
Have you thunk that the poooooooor ol' oil pump will have to work hard to push oil thru the lines amd the big cooler, and that that will cost you oil pressure (pumping losses) to do so?????
Suggest this: Sell it on Ebay for $1,000,000. Then get something more correctly sized like say Volvo oil cooler or maybe max Jag 6 oil cooler.
I think the
> anything.
Normally we want to make things easier for the pump so we go to LARGER lines.
Think of when you've drunk A LOT of BEER.
Eventually you're done renting it and ya gotta get rid of it, so you whip it out and you get ready to write CARL in the snow.
How much easier is it on your system if you just let loose like a firehose and think of the strain if you try squeeezing it hard.
Oil system is the same.
-10 is mo better.
> pants lines.
> Yay, nay?
Look you can get STEEL Push on that function the same as those you linked to and they cost 1/3. Check "Weatherhead"'s catalog, or PARKER.
Make sure the hose you get is rated for continuous 300F
> www.DFLrally.com
PS Checks arrived, but only 3. Was ist der los mit der vierte?
Edited 1 time(s). Last edit at 04/17/2007 07:08PM by john vanlandingham.
April 17, 2007 05:00PM
How much would you guestimate that you could make 2 36" hoses for using your method?
There are more nascar take-off lines on ebay and I could get 2 with the fancy pants aeroquip AN fittings and nomex sleeves for $50.
I may have accidentally just bought a volvo oil cooler on ebay for $55.
Edited 2 time(s). Last edit at 04/17/2007 05:25PM by Carl S.
Haztoys
David Rodgers
90 Mitsu truck ..And needing something new just not sure what..???
April 18, 2007 06:34PM
I run A/C hose ... I go to a auto parts in town that can make A/C hose ...Made to what I need and the ends are crimped on ...I'm sure I'll get flamed on this ...But it has worked for me for years and 100s of hoses...
"Redneck Aeroquip".... This is rally ..why go fancy ...Your going to hit a tree with this car remember...winking smiley
Have a good day
David
Hazardous Toys inc
Edited 1 time(s). Last edit at 04/18/2007 06:35PM by Haztoys.
April 21, 2007 09:41AM
I like the hose that you can get at NAPA that has 2 stainless braided layers under an outer fabric layer. You can get brass push-on AN/ ends for a few $$ each, and you REALLY have to work to push them on and they don't come off. You can pull a battlship with this hose.
If you have aromte oil filter inline with any cooler, then I tend to agree with JOhn; for a typical 2L 4 cylinder, you don't need a huge cooler.
Regards,
Mark B.
April 24, 2007 09:34PM
I found some hose thats not too much, and its designed for high temp oil lines.
I got my volvo oil cooler in the mail too. Now I just gotta figure out what kind of fitings are on it and my sandwhich plate so I can get the appropriate ends for the hoses. Thats item #742,374 on my list of 1 million things to do on the car.
April 28, 2007 06:34PM
Ok so I found some ends in a box of parts that happen to fit the cooler and sandwhich plate. Go figure. So I just need hose and to mount the cooler. Then my oil will be cool, just like me.
