Well pretty much done now. Not a lot to show as I had been working fairly heavy hours and trying to get through a online course on the side. That course finished 3 weeks ago though so now got some progress.
Forgot to grab a pic but the diff is complete... 4.88 with a supra diff + a max grip kit + a crush sleeve eliminator. Did the install myself; hopefully it doesn't blow up cause it was an absolute pain to set up the gears. hydro ebrake installed with limiting valve and all new rear lines. bled it yesterday and its working with no leaks! t5 is good to go. don't have a speed sensor yet but hoping I can make the electronic one off the diff work. If not may just use a bike computer or a gps if I really need to. MAF crapped for some reason while the car had been sitting. Replaced it today and car is running well. Also built the exhaust... 3 inch which was unnecessary but finding 2.5 inch straight tube and mandrel bends locally wasn't happening so 3 inch is what went on. Not perfect and needs another hanger added to reduce movement but no clearance issues so far! Also finally finished the brake adapters for the volvo calipers to toyota axle. If anyone is interested in how I did it I can post a few pics... its a two piece arrangement welded/ bolted together. So just a few little brackets to support a few things like brake lines, etc. Buy some proper bolts for the 4 link, tighten everything down, fill the gearbox and diff with fluid and go for a drive to see what falls off first! Should happen in the next few days. Anyone got a gear oil suggestion for the supra/ weir kit diff? Same for the non world class t5? I read somewhere 50w gear oil for the nwc t5 but can't find it. Would 75-90w be a terrible choice to try? |
Yepp thought so too Dextron..or whatever... John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Non-world class T5 uses standard gear oil. GL4/5 75w-90 or so. Basically the same as what you'd use in the diff.
I remember Weir recommending non-LSD oil in the Supra diff. So you should be able to use the exact same oil for the diff and trans. Or you could step up to a heavier diff lube, like Redline Shock Proof or something. |
Eric. Believe what you want but interesting note:
jus saying John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Paul Buck Paul Buck Professional Moderator Location: Portland, OR Join Date: 03/23/2015 Age: Midlife Crisis Posts: 156 Rally Car: Volvo 242 in progress |
dalspaugh David Alspaugh Godlike Moderator Location: Boston, MA Join Date: 04/30/2015 Age: Settling Down Posts: 66 Rally Car: '91 Audi Coupe Quattro |
Not trying to beat a dead horse or start an oil war, the people over on Bobistheoilguy do a good enough job on that.
In the linky-poo that John posted, they recommended either synchromesh or 5w-30 engine oil over ATF. I've found that 10w-40 motor oil in the craptastic Volvo m46 is about the best thing out there for that trans. I ran ATF in my Moostang with a WC T5, and it shifted great for about a month before it started getting slow. Switched over to Pennzoil Synchromesh and it has been infinitely better. No crunchy shifts while changing gears when it's bouncing off the rev limiter. These guys also think that synchromesh is the bees-knees as well: http://www.pro-forceperformance.com/t-5_history.htm
Carry on, the car looks great mang! |
MattP Matt Pullen Elite Moderator Location: Calgary Join Date: 10/22/2013 Age: Possibly Wise Posts: 282 Rally Car: 2002 Ford StRanger |
If he has any brain cells left, he will go and drive the car for a couple of thousand km since its pretty stupid to build a car unlike anything he's owned, with tons of things to shake down and settle into it, without any experience learning the car's capability a little, before wasting money on entries just so he can satisy some immature whim and then shout on some forum... And so far in some lengthy talks during the whole course of this build, he certainly seemed to have 'some brain cells left". John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
