He is speaking of the stock 240 pre pump... ALFA ROMEO SPIDER 1982-1994 MAZDA B2200 1987-1993 MAZDA B2600 1987-1988 BUICK SKYHAWK 1975-1980 CHEVROLET MONZA 1975-1980 OLDSMOBILE STARFIRE 1975-1980 PONTIAC SUNBIRD 1976-1980 SAAB 9000 1986 VOLVO 240 1990-1993 VOLVO 242 1984 VOLVO 740 1985-1992 VOLVO 745 1985 VOLVO 760 1983-1985 And no he's not so stupid top put the main 2 pumps in the tank just because a lot of not-too-far-thinking-herd-animals say its good...he's smarter than to make access to a vital part intentionally difficult to simply get to..for no good reason. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
But I'm talking about the not-as-crappy 740 Turbo pump, that just so happens to fit in the same location.
Spectre SP1248 Maximum Free Flow Rate (gph) 60 Maximum Pressure Rate (psi) 18 Minimum Free Flow Rate (gph) 60 Minimum Pressure Rate (psi) 13 Outlet Count 1 Outlet Size 3/8 Outlet Type Hose Connect |
I want to say "Good for you, talk all you want" but this has gone so off topic that I don't have any idea what you are suggesting.. Shirley you are not realistically suggesting to doing away with an easy to reach vital part and mount it into the tank so that access is always a monster major pain in the ass are you.? What imagine advantage would you imagine have a single silly pump inside the tank where access is a big pain versus 2 in the trunk area somewhere where acess is quick and easy And clean up also easy??. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
John, there are 2..TWO... fuel pumps on a stock Volvo 240. Last time I checked, that's what Eric had. Once again, TWO fuel pumps on a Volvo 240.
There's an in-tank lift pump that feeds the high-pressure fuel pump, and you can read about how the in-tank pump is no longer working in Eric's car. I suggested using a slightly upgraded pump in place of the standard in-tank pump. Only on the first few years of 240s do they have a gravity fed high-pressure pump. |
Look Morison, when you mommy was wiping you shitty bottom I knew there were 2 fuel pumps, so Morison you don't need to lecture. You know what I am asking and I have told you that Eric is not stupid.. And to make YOUR badly need task of learning easier I gave you all the information HE needed to make to correct decision..... So it turns out you actually are suggesting that he place a single main pump in a place where access is extremely annoying, and you are suggesting some sketchy pump as well.. IF you were as smart as your snarky and sarcastic attitude presents, you would have read that the idea has already been discarded as patently, and mind mindbogglingly DUMB....So shut up about it... He knows the lift pump is a pain as well but they are far less stressed and tolerate a lot more crap..so it can stay. When he has TIME then he can make a mounting set up and plumb the 2 good Bosch pumps all wired and fused separately.. That is not his goal now... Please. Learn to read, learn what words imply and think of context... Maybe go re-read Ecclesiastes a few times till you incorporate its lessons. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
John, I'm getting so confused as to what you are actually talking about. Be more specific when you have an issue with something, the verbal diarrhea that spews forth from your mouth is starting to stink up the place. I agree that in-tank pumps suck, I agree that 2 in the trunk is a great idea.
Look, I even mention it here:
Yes, I mention that a high-pressure in-tank pump will work with very little effort. It will even help by getting the stock pump out from under the car. It seems to me that removing the pump under the car (is it still there on Erics car?) by upgrading to a better in-tank pump is not a step backwards, but forwards. I have had more stock Volvo pumps fail than any upgraded in-tank, Walbro, or mustang pump. My current tally is 3 high-pressure volvo pump failures, 3 stock-replacement in-tank pump failures, zero 740 turbo in-tank pump failures (of 3 installed), and zero walbro in-tank high-pressure pump failures (2 installed, one not on a Volvo). But whatever. You don't really care what others can bring to the table. |
Anyway...
One last thing, if you jump the intank pump with the car off would you be able to hear it run if it actually worked? I know the external one is very apparent not so sure about the one in the tank. Im not reading through all of the last section so to clarify... nothing is getting changed or upgraded right now. With 5 days before an event that would be stupid. Im slamming a new stock pump in there and down the road will do something better. |
Yeah... Sorry about the mess...
You should be able to hear it. Another way to check the pump is to pull the big rubber hose out of the back of the high-pressure pump under the car and check for fuel flow from the in-tank pump. It shouldn't be a garden hose of fuel but a decent stream. If you're not flowing, and you are sure that it's jumped properly, the issue is the pump, or the short section of rubber hose in the tank. Grab a new in tank filter while you're in there. They can fall apart and clog the inlet to the pump as well. Edited 1 time(s). Last edit at 03/01/2016 05:16PM by Robert Culbertson. |
You don't need to replace it, but you should. If it's cracked, you really need to replace it. I've reused them with a thin coating of grease to help them seal back up, and to make the nut easier to tighten. Ymmv though. |
I wouldn't, but that's because I haven't had luck doing that in the past. There are some that are fuel resistant RTVs, but you would need a fair bit to fill the o-ring detent. But still might not seal switch the tank and the nut being stamped sheet metal.
Are there any hydraulic or bearing shops in your area? They usually stock o-rings and seal. Edited 1 time(s). Last edit at 03/01/2016 05:56PM by Robert Culbertson. |
Not Trolling Keith Morison Super Moderator Location: Calgary, AB Join Date: 09/15/2015 Age: Ancient Posts: 340 |
That made me snicker. I think we can all agee that ALL pumps suck. :-) First Rally attended (2000), First Rally competed in (2001) Cars Built (1), Engines Built (0) Cages Built (0) Driver (8), Co-Driver (47), Drivers (19) Clerk (29), Steward (1), Official (17), Volunteer (5) WRC Spectator (1), WRC Photographer (6), WRC Observer (4) Rallies attended (120) Countries attended rallies in (11) Last Updated, May30, 2022 |
