Magical regulator?
Posted by EricW
EricW
Eric Wages
2002 WRX
Magical regulator?
October 13, 2013 06:37PM
Does anyone know of a magical regulator (or combination of bits) that allows one to haul a nitrogen tank to events rather than a compressor+generator combination? I'm basically looking to find a (cheaper) way of using a standard air-tool setup with a nitrogen tank.
Robert Culbertson
Out of this dumpster fire
Re: Magical regulator?
October 13, 2013 07:04PM
I'm not sure about the volume that can flow through a standard regulator. We use one for tires, and adapting one to work with air tools would be easy. It just might no have enough oomph.
Why not just buy an air compressor?
deaner
Dane Aura
PS4 controller
October 13, 2013 09:12PM
Air.compressor + power inverter?
October 13, 2013 09:18PM
I crewed for a guy that used a tank of nitrogen for air tools. It had enough umph to zip the wheels on and off anyways. That was 12 years ago, so I don't know the details about the regulator set up. But it can be done, anyways.
October 13, 2013 10:29PM
Come on Eric, how much major overhaul type woik you joikin with at an event?
Big Idea N0275: Woik like a joik in da garage in advance of "The Big Rally race"
At the big Rally race: DRIVE. Use steering wheel occasionally and avoid hitting big scary things that bend and destroy things.
Result!
In service nudge at things with toe, make a face, say fuckit it'll do and go schmooze with friends.
Get some speed wrenches just to have.
Easy, fast relaible..$11
Are you like weak and frail and can't twirl wrenches?
Or what?
Get one in 3/8" drive and one in 1/2" drive and no miracles needed and works anywhere, anytime.
October 14, 2013 02:57AM
Just get a regular regulator. Way back when I used to haul an air compressor around but a nitrogen tank takes up less space and is quieter than a generator and compressor. Of course, a nitrogen tank has a finite amount of air but a big one will give you everything you need for a weekend, even using air tools. Seems like I mostly use mine for filling up the potato gun though...
alosix
Jason Powers
October 14, 2013 09:34AM
What's your service rig? Do you have room for another AC compressor under the hood? My Jeep will do 4-5 cfm @ idle, and plenty more with a sufficiently sized tank installed. I have another such setup that's going on the tow rig.
My concern with using nitrogen for tires/tools would be just not having enough of it. If you're looking for an impact replacement an electric one will do and would probably be cheaper than the nitrogen regulator bits. If you're looking to run something like a cutoff tool or die grinder you're going to burn through your supply right quick.
This isn't floor mat anarchy
October 14, 2013 06:24PM
Erci, do you have a way to transport this safely and per regulations? I recall that you have an open trailer, and how to transport it upright and properly secured as it legally is supposed to be done is a possible issue for you. Having it flat on your open trailer is an invitation to be stopped. Transporting it inside your main tow vehicle is not too smart, in fact it is quite dumb; that is not just an opinion, BTW.
October 14, 2013 06:57PM
I can't fathom why you would need air tools at a rally unless your name rhymes with Roswell or if you rally a VW. Build a car well and you probably won't have much to do. What's wrong with a compressor and tank? We used one to push a bearing off a stub shaft with an air hammer once. It was tiny and provided enough air for the job. Cut off wheel or impact wrench never, occasional tire refill or air hammer use, maybe.
Creech
Scott Creech
Audi 90 Quattro (WIP)
October 14, 2013 08:02PM
How many "BraAAps" equals the correct torque for a head-bolt?
I am:
I know:
I am from:
Nobody.
Nothing.
Nowhere.
Reamer
Jeff Reamer
Subaru
October 14, 2013 08:55PM
Oxygen regulator off your torches with the argon end off your welding regulator will move plenty of air. way nice.
First rally 2013
Rally car type AWD subaru
Total rallies as driver 6
Total rally cars built 2
Total rally cars caged 3
Like 31motorsports on FB!
October 25, 2013 10:43PM
You would want a regulator from the gas supply shop for this. You can get them in two stage styles. The first regulates it down to 175 psi or something, then the second part is adjustable. I don't remember the cost.
October 26, 2013 07:26PM
Reamer
Or run oxygen AND acetlyene through your impact gun with an ignitor. Bam, now your IR231 has antilag.
Creech
Scott Creech
October 28, 2013 12:47PM
Reamer
Run the Acetylene higher than 15psi working-pressure, you don't even need the Ignitor....
I am:
I know:
I am from:
Nobody.
Nothing.
Nowhere.
Reamer
Jeff Reamer
Subaru
October 29, 2013 03:15PM
Yeah the prefered way is probably the Anders way but mine truly works fine for the cheap guy. Not sure the acetlyene would be worth adding for rally. Im sure that would need a restrictor to slow down the air speed of the impactgun.
First rally 2013
