acrane Wrote:
> I did a rally cross and finaly managed to break
> the car.
> I fabricated escort II style parallel rear axle
> stuff about 4 years ago, and made custom links out
> of 1" tubing and an insert for .5" hiem on one end
HALF INCH WHAT THE FUCK!!
> and polyurethane on the other.
> all 4 links are 24.5" long.
> the upper links both failed (will get pictures
> eventually). this caused the snout of the rear
> axle to point up to the transmission tunnel,
> loosing any "transmissive power" and bending the
> lower mounts of my bilstien dessert coilover
> shocks. 7100 series $150 bones, no biggie - to the
> spares bin they go.
Wait, didn't you mount thinks body up?
Is it the "extended eyelet" that's bent?
The one that screws into the shaft?
Is the shaft bent?
I have extra extended eyelets.
> I was able to drive the car home by getting a
> spare link into one of the uppers. now it is time
> to replace all 4 and the panhard.
> question time.
> the escorts all had a bushing at one end.
> my circle track spare (quite light, economical
> aluminum) has RH-LH hiems. great for
> adjustability.
> I want my car to rally like a bomber, whatever
> that means.
> I like adjustability without removing one of the
> bolts. thrust alignments are the JAM.
> I worry about lower links getting trashed by
> rocks.
Make them strong and protect them,, and maybe look at the occasionally you savage!
> I worry that the mounts will weaken if i remove
> the bushings.
Depends on the size.
You're such a smartie and want to figure everything yourself (HALF INCH HEIMS!!! DID I REAR RIGHT or ARE YOU SMOKIN da SPIFF-a-juana, Bra?)
> the car is heavier in the rear than the front
> (wierd huh, with a full tank;-)
> could i get away with carrying the aluminum spare,
> making lower links like last time, and getting
> aluminum uppers w/o bushings? would only having
> bushings on the uppers or lowers make sense?
I'm cornfused, call on phone.
I say thick wall steel top and bottom, minimun 5/8 heim, maybe 3/4 sleeved down to 12mm or 1/2 for the bolts, and as for the bush there are bushed "rod ends" I have the bushes here, use them in the trannie mounts and on lower control arm for the Saab V4, 99 and 900.
> thanks?
> (where is that crazy toyota build again.)
> "I put the hurt on dirt"
> ex. madmann28
> adam crane
> bellingham wa
> corolla gts
> bs. from VRI @ WWU
