simoniac Simon Wright Godlike Moderator Location: Raleigh, NC Join Date: 10/19/2006 Age: Ancient Posts: 161 Rally Car: Rally Spec Focus |
Well now, using that point of view, we could argue that the accellerator is a bandaid too since the car isn't going fast enough sometimes. I think, used properly, the brake and the accellerator is as important as the steering wheel in getting around a corner. But please, let's keep this thread going - it's technically fascinating. Simon Wright Owner/Driver USUK Racing - Home of the USUK Racing LED Light Bars! North America Rally Map |
As far as the rear suspension goes, my gut feeling is that it's not as critical. If the front are gripping, it will clamp the rears down. In a corner, the rears are mostly there to follow the fronts, and when braking, hell those suspensions do the opposite of what you'd expect if you wanted to make grip back there.
Reamer Jeff Reamer Professional Moderator Location: Marlette, Michigan Join Date: 08/14/2010 Age: Midlife Crisis Posts: 489 Rally Car: Subaru |
In oval track cars the #1 thing every team adjust to help the car turn is done in the rear of the car. I say this meaning quick adjustments to dile in a ill handling car. I know you dont all watch Nascar but for you closet guys you always see teams on pit road doing 90% of there work in the rear of the car.
It may just follow? If that were the case then they wouldnt adjust and turn bolts or raise lower the panhard bar in EVERY single pit stop. It maybe #2?Air pressure is probably #1 adjustment. The point is at least the rear roll center of the car is crucial on making a car do what the driver wants. Getting the front and the rear to work together would be the ultimate goal. I think this maybe why the gc,gd work well. The strut tops are close to the same hieght. Where as the 08 up the rear spring susp mounts are at least a foot lower. This is so you can get your lugage in the trunk with out those pesky strut towers. First rally 2013 Rally car type AWD subaru Total rallies as driver 6 Total rally cars built 2 Total rally cars caged 3 Total rally cars repaired from offs 4 Total years racing exp other then rally 19 yrs Like 31motorsports on FB! Check out 31motor sales on ebay for used Subaru parts |
How do you get prodive in the lca and anti dive in the front strut geometry. Is this the reasoning for the strut mounting in front of the axle?
Hmm seems plosible. I just thought it was to have more travel in a tiny hole. I figure it still mounts at the ball joint. Didnt think how it got there made any differance. The rotational force makes sense . Smart guys those wrc engineers are!
samcaron sam caron Junior Moderator Location: vermont Join Date: 02/04/2014 Age: Midlife Crisis Posts: 1 Rally Car: none yet |
you can't have prodive and antidive on the same wheel. % anti/pro dive is based on the SVSA. the attaced image (not mine, found on google but good example) is for a double a-arm suspension. |
Sure you can, if you are feeding brake loads and thrust loads in separately. Wheel thrust only really feeds into the control arm and brake torque works on the upright as well. If it were RWD solid axle, it'd be like putting the brake caliper on a pivot with its own instant center, so you can get any amount of acceleration anti-squat you want without compromising traction under braking. Pete Remner Cleveland, Ohio 1984 RX-7 (rallycross thing) 1978 Silence is golden, but duct tape is silver. |
Now you're in for in.. nice piccie, but for those note experts in reality---or their Walter Mittyesque dreams, acronyms are not the best thing...not every body here speakka da enlgische. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Exactly, thanks for splaining it in better English than what I did. |
I think John is right, you need to start your own thread. You're going off way to far off topic and you're doing nothing but pondering and theorizing about things that don't even make sense, and on top of that you're begging to confuse what these features are for and in what axle they belong. Please stop this and lets keep this relevant to GEOMETRY AND DESIGN. |
OK the NASCAR rear adjustments are made because its the quickest they can make. Its something that can alter the fore/aft balance of the car and its easier than changing anything in the front suspension close to the flaming headers and brakes. One of my best friends, Joey Knuckles a multiple Daytona 500 winner as a crew chief back with Davie Allison has mentioned numerous times that the rear is only there to drive the car and keep the gas tank off the ground. They have gone as far and running rear coil bound and with 0 rebound shocks. And funny enough running on the bump stops in the front. NASCAR has loads more tech than people think. BUT its not relevant to rally suspensions. So back to talking about what can make a FWD or RWD car put the power down better. Some percentage of Anti Lift and 0 anti dive seems to be what engineers are aiming for in the FWD cars. |
