buerckner Andrew Buerckner Professional Moderator Location: Canberra, Australia Join Date: 10/22/2011 Posts: 120 Rally Car: Daihatsu Charade GTti DOHC Turbo, and Mazda MX-5(miata) Turbo(bent) |
Yeah but I'm flat our remembering what I had for breakfast, let alone that stuff! But I'll have a go,(rough figures which are probably worse than none) it had 190mm travel fr, ~250mm rear. 840kg total. Didn't ever get that one on the cornerweights but the old similar car was ligher at 790kg and 59:41, againg that's pretty meaningless as it was 3 door 3-cyl turbo, as opposed to 4 door, 4 cyl. So who knows. Also anyone that takes our blabbering on the net as more than a rough guide would have to have rocks in their head. |
Creech Scott Creech Ultra Moderator Location: Jane, MO Join Date: 12/02/2012 Age: Possibly Wise Posts: 415 Rally Car: Audi 90 Quattro (WIP) |
Dammit John! I just threw my neck out! Parfois, on fait pas semblant! I am: I know: I am from: Nobody. Nothing. Nowhere. |
That looks weak as hell IMO. Note that the guys who ARE doing this kind of setup don't seem to be using ears, they've got something that looks like a big fat clamp holding the strut tube on. On the other hand if you started out with something like what Ford started doing in 1977... then you'd only be stuck with a ball joint position that is way too high up on the upright at a minimum, and an easily bent spindle if you use stuff from before 1994... And the rest of the suspension sucked as well for lots of reasons (poor steering geometry so the inside tire dragged through turns, crap suspension geometry, they put the spring on the control arm so everything was 3x heavier than it needed to be...) I was really considering Fox uprights for the RX-7 (I'd give it some caster, too, I think Ford was afraid of caster) but I could never get over how HIGH the ball joint is on the upright. It's almost at spindle height. That makes your roll center down in the weeds unless you also mount the control arms high up on the body and use tiny little tires. Pete Remner Cleveland, Ohio 1984 RX-7 (rallycross thing) 1978 Silence is golden, but duct tape is silver. Edited 1 time(s). Last edit at 02/06/2014 06:52PM by Pete. |
teee heee maybe try this. http://textmechanic.com/Reverse-Text-Generator.html John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Reamer Jeff Reamer Junior Moderator Location: Marlette, Michigan Join Date: 08/14/2010 Age: Midlife Crisis Posts: 489 Rally Car: Subaru |
Looks like my dislexia works good in these cases!
So more rebound in a bike helps smooth the big bumps but more rebound in a car will put you on your roof. Or is it the stiff rear springs will put you on your roof? Thats the set up I would try for MOST faward bite in a FWD. Also when I say tons I mean lots more then compression stroke. So say 140lb compression and maybe 700lb rebound. Also my oval car is more in the 1600 lb rebound range. Thats why I threw it out there to see what guys thought. First rally 2013 Rally car type AWD subaru Total rallies as driver 6 Total rally cars built 2 Total rally cars caged 3 Total rally cars repaired from offs 4 Total years racing exp other then rally 19 yrs Like 31motorsports on FB! Check out 31motor sales on ebay for used Subaru parts |
Is there really an optimum geometry? I don't think so. Only a best compromise depending on a multitude of constantly varying factors.
In my experience most FWD production shopping cars are designed to inherently under steer for safety. Lift off the throttle when it starts to slide in a corner and generally grip returns. That is a fine way of keeping the weekly shopping of eggs, ketchup and beer safely in the bags in the trunk instead of it being thrown all over the interior when the car lands on it's roof in a ditch if the car were to have more "edgy" or "nervous" handling characteristics. Exception being some French stuff with torsion beam rear axles that can suffer from lift off over steer. But the froggies only eat bread and cheese so no great clean up problem for them if the car rolls. So I guess depending on driver preference (which is also a huge factor) of how you wish the car to handle, you could tweak the geometry to move away from the OEM original designed in tendencies, and induce a characteristic of what you want, whatever that may be. I understand that depending on their construction, radial tyres can also cope with a fair amount of camber change and still keep their footprint. So how radical does the geometry really need to be? Presumably it must keep the tyres within their operating window. Every time I go to watch the cars in the woods, I see mk2 Escorts humping most things. Live rear axle and very short TCAs on the front. Modern off-road bikes have amazingly capable suspension with multiple adjustments, it is incredible what they can do if set up correctly, but that can involve subtle spring rate changes and re-valving the forks / shock to fine tune for rider weight and whatever discipline they are used for, motocross and woods riding are very different. So I guess that confirms my suspicions that a best compromise is going to be as good as it gets.... Well until Honda come out with Vtec geometry with moving pivots points. Disappointingly not yet a Jackass |
Danny. I lurv you. best post by far--and best connected to reality. Ta. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Yes thats a good post for real world rally. And im sure we all agree.
Then again we also are gear heads who like to learn how and why things are the way they are. A good handling car makes the driver look good. The same goes for an ill handling car makes a driver look bad. I still would like to know what to throw at the rear of my car to get the feel im looking for. It needs to feel more confortable to push harder. First rally 2013 Rally car type AWD subaru Total rallies as driver 6 Total rally cars built 2 Total rally cars caged 3 Total rally cars repaired from offs 4 Total years racing exp other then rally 19 yrs Like 31motorsports on FB! Check out 31motor sales on ebay for used Subaru parts |
Pfft, It was a risky post tbh. Ya know that posting anything near reality on t'internet can always backfire when one gets shredded by the hypothetical, theorizing, computer aided design engineers, with a bazillion hours of online philosophising, backed up with little practical experience whatsoever to know what the feck they are trying to accomplish. Did you know the shear volume of bullshit posted on the internet actually has a measurable effect on our vehicle's handling? Well, in an ironic twist of fate, our metallic cars are now susceptible to the magnetic forces caused by the electro-magnetic fields emitted from the excessive abundance of servers required to store the terabytes of all the utter gibberish wafflings on how to improve car handling... Think about it, why else would the top teams be using composites..... NB> The above is to be taken in a humorous fashion. But bench racing will only get you so far. Disappointingly not yet a Jackass |
Have you had your vehicle put through a full 4 wheel alignment geometry check to see what is actually happening? Springs removed and checking from full droop to full compression. If you had the baseline figures for your car, and also what a standard car has, it may be interesting to see the comparison and see whether something stand out or odd is occurring. Disappointingly not yet a Jackass |
Jus a weee bit of emphasis. Compare and contrast is what I call that.. Do the both and stare at it for a ciggie or two before THINKING. Like this: Empty the mind and look at the 2 columns... John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
MattP Matt Pullen Senior Moderator Location: Calgary Join Date: 10/22/2013 Age: Possibly Wise Posts: 282 Rally Car: 2002 Ford StRanger |
I'll contribute my 2 cents:
Its not really advanced design, in fact its about as simple as possible. As I are caveman, my tastes are biased towards the trusty volvo 240. Longish wheelbase, solid rear axle and generous suspension travel make for a , predictable, forgiving, easy to drive rally car. definitly agree with Matt above, wheelbase is going to play a primary role in handling. When I have driven shorter cars close to the limit I have found myself frowning more than smiling. As for specific changes to geometery, while redoing to front strut to knuckle clamps on my 240, Tim bumped the negative camber to about 2.5 degrees. This was added at the same time as changing to the 50mm struts with huge increase in rebound damping and structural stiffness,so one can't isolate the results, but compared to the stock car there is a world of difference in cornering. tendency to understeer in all conditions is greatly reduced, and the front end generally feels more stable and gripped up. There is a feeling of pivotting around the inside front wheel in very sharp corners that I find especially nice. Sean has mentioned building A-arms for the volvo that could dial in more castor as well in order to add a bit more to the bite of the front wheels. This would certainly be fun to play with. |
Ive done begginer test. Ive had springs out and traveled many times. Thats how I found the front issues. At 7" ride hieght I had 1 3/4" up travel before the strut was fully compressed. I raised the strut tower so the strut at 7" ride is mid travel. 6 degrees caster.
I have not yet put the bump steer guage on the rear to check to see what toe is doing with bump. I didnt change upper or lower control arm angles to change rear roll center. I changed the forward mounting arm and the tierod. There maybe some unwanted toe change with travel causing problems. a quick measure shows 1/16" toe in fully compressed per side so 1/8" total toe in. iT may go crazy mid travel I didnt measure threw travel just ride hieght and compressed. I think I may try to raise rear roll center if it isnt to complicated.Was thinking about adding forester spacers to rear cradle then lower it back down to ride hieght and try it. This will add a few degrees angle to all the rear susp control arms. Seems most pics I find of 08 up sp cars are way lower in the rear then the front. First rally 2013 Rally car type AWD subaru Total rallies as driver 6 Total rally cars built 2 Total rally cars caged 3 Total rally cars repaired from offs 4 Total years racing exp other then rally 19 yrs Like 31motorsports on FB! Check out 31motor sales on ebay for used Subaru parts |
Do It Sidewayz Chris Martin Ultra Moderator Location: Toronto, Ontario Join Date: 01/15/2006 Age: Midlife Crisis Posts: 567 Rally Car: E-85 powered Impreza |
I like where this thread is going.
I will admit to playing with some of the concepts mentioned here, with some success on my impreza, and what most of you are saying here agrees with the theories I followed. Currently racking my brain trying to figure out how to get more straight line grip on Ice with my Ice Racer Impreza. It's bone stock with regards to suspension, except removed sway bars. The car turns and sets ok, but lacks serious forward bite. It will get roasted off the corners by RWD and FWD cars! Chris |
