unfast Chris Clark Senior Moderator Location: Selah Wa Join Date: 01/29/2014 Age: Midlife Crisis Posts: 4 Rally Car: Yeah right |
Paddy1337 Tim Patrick Professional Moderator Location: Raleigh, NC Join Date: 01/26/2011 Age: Settling Down Posts: 175 Rally Car: Galant VR-4 |
mekilljoydammit Junior Moderator Join Date: 09/22/2010 Age: Midlife Crisis Posts: 336 Rally Car: No rally car yet |
Funny thing about the Ford stuff is that I've seen it for sale at various UK places. Apparently they're slightly special injectors to be able to run without fuel cooling them. Cool setup IMNSHO. May be fundamentally better ideas nowadays.
It sorta seems like cams for restrictor use are on the "lotsa lift for as little duration as possible" vein, from looking at what info I could find for Subaru crap for restrictor use. Kelford TX258, GSC S1... Cat Cams has an interesting looking one but rotsa ruck finding folks running Cat Cams over here. No direct experience, just food for thought. |
RileySteenFRT Riley steen Godlike Moderator Location: Fargo ND Join Date: 07/10/2014 Posts: 67 Rally Car: Focus ZX3 |
DR1665 Brian Driggs Super Moderator Location: Glendale Join Date: 06/08/2006 Age: Midlife Crisis Posts: 832 Rally Car: Keyboard. Deal with it. |
First... I just now noticed this thread and this picture in particular stood out. Makes me smile.
Second...
Once upon a time, JVL, you and I had a chat on the phone. Years ago. We talked about the old days, of rally clubs, bartering, and events which began when teams left their garages and drove across continents to the starting line. Of liberté, égalité, fraternité, though not necessarily in a sense of Franco-envy. It was a good call; reminded me I wasn't insane, or the only dreamer who still believes in the simple nobility of the everyman and his trusty machine. Many airplanes took off and landed in the background, no doubt to the chagrin of some cats, whilst I suspect we both smoked several cigarettes. And I was sitting in the driver's seat of this car. Funny how things turn out, isn't it? Brian Driggs | KG7KCA | PHX, AZ | 89 Pajero alterius non sit qui suus esse potest Edited 1 time(s). Last edit at 07/16/2014 04:35PM by DR1665. |
have not forgot about the Gay-lant! even if it is the "side piece" right now in my racing life.
anyway, after not a lot of info in the restrictor realm, i found that there are a million weber venturi/choke makers out there. Ended up ordering a 34mm venturi today. Hoping I can make it work, at about $20 shipped it's well worth it to me. i've seen the off-the-shelf suby restrictos sell in the hundreds, lol wish me luck... |
Also, with the concept of get on stage first, then make changes I'm going to try and get my Evo's stock Bilsteins on to the Galant. Supposedly it's a pretty darn simple modification to make them fit.
I still don't get the OEM concept of gigantic springs up front, and normal looking in the rear. But, simple install, MUCH newer, and with the fancy Bilstein name I figure it should be enough to get me on stage (at the low low price of free). Get the seat time, learn the car, then when I go to a builder, like JVAB, I'll have some input on what the car does, and what I'd like it to do differently. Not to mention, with a usable suspension on the car, fabrication delays can't hold me up. |
Nice idea for inspiration but the dimensions will not meet the rules... The rules state distance from compressor wheel and that the 34mm bit must be a straight section 3mm long... Now enforcement is lackadaisical to say the least so who knows, maybe you can get away with it. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Travel is waaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaay short---I have some of those fronts and it isn't even 150mm travel.. The fronts are also valve softer than peeeee so you really can't up the spring rates or you'll be waaaaaay underdamped.. Rears probably same thing... And worse news is that new policy means if a unit is an OEM type thing---like the ones I have (that I bought thinking to swap out the roda for a 190mm travel rod and revalve for gravel spec, and be able to offer them to broke ass guys needing a lower priced alternative----they will not mod or revalve them... I do have a plan up the sleeve but not sure I can swing it.... Unasked for advice: Galant is a good car, the motor is fine, needs minimal fiddling to make it a good 34mm restrictor motor...So low cost there. Trans has the same crap ratios as Eclipsed/Talhoons---no easy fix without $pending beaucoup dollar$... Suspension there is no real substitute for at least: right travel and right valving. It is a central and key thing that makes a car a gravel car, and not a road car (like that stuff you have) or a tarmac car.. You said you have lots of sponsors for engine work etc. That means you don't have to lay out cash there. That means you have cash for those things there is no substitute for.. Suspension and ratios... Then that leaves just the other critical things: Brakes to slow the damn thing down.. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Believe it or not, I read the rules before i clicked buy. but I didn't ask the seller for exact dimensions due to the low price. For what it's worth, my plan is chop off the bottom/skinny section where the slot is machined. Then machine my compressor cover inlet to the OD of this venturi, until the venturi is close enough to the compressor fins. I think it was 15mm or less. Am I still off-base in my thinking it will work when adapted that way? |
First, I honestly hoped you'd chime in. but I didn't want to be needy, especially considering my proposed interim solution means not buying your product yet travel was main concern, for sure. They essentially ride on bump stops from the factory, before being compressed. I planned to try and up the spring rate, and ride height a little. [and really beef up under-car protection, lol] You're 110% right on trans ratios. My current proposed solution (on a budget) is using the lowest 1,2,3rd gears that'll drop in- while also keeping tires as short as reasonably possible. Without messing with final drives I save a TON of work in matching diffs to the new final drive. downfalls are abundant still, but better than nothing. the 3-4shift will be a big drop. The brakes are better than what came on the same era DSMs. Sufficient I don't know, but I'm hoping yes. I do agree, my sponsorship is a big plus. Cheaper parts, and free/cheap labor on mechanical and tuning. Can't argue it, no reason to make defense to the contrary. |
