Steering quickeners
Posted by Dazed_Driver
Steering quickeners
October 05, 2007 04:14PM
So... I've been contemplating getting wanna those Howie steering quickeners for the corolla... Can that be installed on the stock steering column? Or, do I need to fabricate a new column?
mack73
Jason Wine
Re: Steering quickeners
October 05, 2007 06:20PM
The quickeners end up being about 7 or so inches long. You've got to loose some length from somewhere... and your going to be removing the steering lock anyways right?
Here's what I did for my golf: I dismantled the column. Cut the shaft the appropriate length. Welded the couplers to the shaft (drilled through the couplers and shaft to install steel pins). Then cut the outer tube. welded support brackets to them. Then bolted it all together with a nice piece of flat stock. Note I had to increase the thickness of the plate in the picture (1/8 to 3/16) as there was some twist in it - there's a suprising amount of force there.
-Jason
Edited 1 time(s). Last edit at 10/05/2007 06:23PM by mack73.
