Grant you are so caught up in your rah rah Bee Em Dubya bullshit you can't even see I'm just making STOOPID prices as an examples of STOOOOPID prices.. I've looked at the various STUPIDLY expensive shit but since the stuff is STUPIDLY expensive and onluy an STUPID person would ask Daddy to buy him shit like that there's no point remembering the exact STUPID price because it is STUPID expensive.. !7,000 or 10,000 Euro or Dollars who gives a shit---it uis stupid.. That misses the point that the STOCK gearing is BACKWARDS and about as good as the T5 from a T-Bird... It is STUPID for our purposes--hardly a selling point... The best an HONEST person would say is.."Well if you get the 240hp/225 ft/lb 3.0 with the tricky variable cams the gear ratios are just barely adequate--if its flatish....and there's no other cars with similar engine output but better gears.." It is very likely that you do not understand what good gear is due to your limited experience with cars--or other vehicles---with alternate box and final drive ratios. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Why? I talked with Drenth about using their MPG or DG400 gearbox in the Merkur. There are STOOPID prices for everything. I went to the u-pull junkyard on BOGO day. $65 and I had a 4.1 final drive and clutch pack LSD from a BMW. I'll probably get $10-20 back from scrap on the unused case and final drive also. I'm gonna chock the LSD case up in the mill and machine a few mils out of that. A few hundred on some new plates and I have a nice tight LSD that I can tune the breakaway torque to what I want it to. Oh yeah, I can also machine the ramp angles to get less lockup on decel since that was the one thing I didn't like in RWD with a welded diff. Or if I'm feeling lazy I can pay a few different places $1500 for a 4.27 final drive repacked diff. That's about the price of a 4.56 final drive for the Euro Ford 7.5" differential. Anyhow, enough crazy talk. I have a few minutes since daughter is napping at home and not lab and I'm actually on a computer... Here's my rear brake setup. This is a pretty decent setup. 0.81" X 10.75" rotor on 4 piston Wilwood NDL calipers. The carrier is the only thing that isn't off the shelf. The rear hub needed a little bit of diameter turned out of it but it allows use of an off the shelf brake hat and rotor. I think I paid around $900 for the rear setup a few years ago. I do still have some of the knurled press fit 7/16-20 fittings that the adapter uses. The adapter is a machined plate that sits between the STA and bearing carrier so pretty simple and similar to other kits out there. I coupled that with a dual master setup from the UK and the JVAB from kit. Hydraulic handbrake similar to the one I sell: http://rally.build/automotive-plumbing-solutions-vertical-hydraulic-handbrake/ I used all braided lines in the car as that was the easier solution for me at the time. It is more expensive but I found it easier to get a non-leak fitting with DIY reuseable AN fittings than a crappy tube flaring tool. All in I think my brake setup ran around $3300. Since I can't look back through pages of John's drivel but from memory you are not afraid to get your fabrication on. I'd look through Sean's build and find where he modified the stock pedal box to modify that to use dual masters. Much cleaner packaging than the crappy overseas kit I got. I seem to recall people talking about radiators. One thing I've determined, you can't spend too much on a radiator, but too little cooling can sure cost a shit ton. Some of the ebay and such ones are more comparable to an intercooler radiator than anything decent. I haven't figured out a solution other than low boost but it's on my list. Of course on that list is also, build a BMW cage, build a BMW, build a Subaru cage, swap a BMW engine, build another BMW cage, swap another BMW engine... Grant Hughes |
MarkHille Mark Hille Ultra Moderator Location: The hills of CT Join Date: 10/04/2011 Age: Midlife Crisis Posts: 135 Rally Car: I have two crap boxes |
I have a merkur depot shorty radiator and a mike olyer (sp) aftermarket 2wd intercooler. Anything above 15psi and it will get HOT after a few stage minutes. I suggest oil cooling if your going to try more boost. I've run a similar cooler to this Chinese oil cooler on stage above 18psi sustainably (with proper engine management): http://www.ebay.com/itm/aluminum-oil-cooler-mazda-RX2-RX3-RX4-RX7-oilcooler-HIGH-PERFORMANCE-/331261506350?pt=Motors_Car_Truck_Parts_Accessories&hash=item4d20b9732e&vxp=mtr I'm guessing you could do 20psi + and never have to worry about overheating. FEI, if you ever run a stage that doesn't have a cool down drive after it, I.E. one that has a turn around and runs backwards, open your hood and let things cool down. Your coolant lines, boost control lines, and turbo will thank you. |
Thomas Kimsey Thomas Kimsey Junior Moderator Location: Rochester, New Hampshire Join Date: 10/05/2013 Age: Settling Down Posts: 271 Rally Car: 1988 XRatty |
I started with something like this:
http://www.summitracing.com/parts/hda-459/overview/ Tried it in front of and behind the radiator. While its better than nothing, having the rx7 oil cooler sitting down low but high enough it won't get taken out unless I hit something pretty good was key. It fits in there pretty good. Not sure what the Setrab or MB 240b look like. The intercooler, radiator, and oil cooler all get pretty even flow. Is my set up ideal? I'm sure its not but it seems to be possible to throw some boost at it and not get scary hot. Oh, and I guess I should explain that I was monitoring the oil temp coming out of the pump, the block coolant temp, and the coolant temp coming out of the head. I don't think we ever saw temps above 230 which wasn't possible with the summit cooler. With the summit cooler, the longer the stage the hotter it got until the coolant temp would rise and we would have to back off a bit. |
Any chance you still have the water cooling hooked up to the turbo? |
Nope. I've removed all unnecessary coolant lines to help simplify things and remove points of failure. I've blocked off the manifold and no longer have coolant running through that either. Ditch the stock "oil cooler". It puts more heat in than it takes out. I do still have lines to the heater core and have rigged up some fans by it to circulate air for the windscreen. I would say that is a necessary thing to have for defrost purposes. There are people that will say you should water cool the t3 but most people will say it isn't necessary and the only thing you will have to do is allow a short cool down idle to prevent coking. I've read that having the coolant lines to the turbo can tend to add exhaust heat to your cooling system. It makes sense but I'm not sure if it is true or not. I've changed the turbo on the side of the road during a rally and was happy I didn't have coolant lines running to it. Only missed one stage. You could argue that the turbo went because I didn't have coolant running to it but I would say it was probably because it was 25 years old and had 150,000 miles +. |
Yeah I am not running the coolant lines to the turbo either. Did you slot the 3 holes in the exhaust housing for quick change? |
No. I have other things that needed/need to get done before that. I'm also a little leery of doing so. I've seen competent people loose turbos off their manifolds on stage. I've personally experienced exhaust temp heating and cooling that loosened bolts rather quickly. I use stainless studs for most of my exhaust stuff. I can't remember if I use them there. Maybe someday I'll do it. |
modernbeat Jason McDaniel Junior Moderator Location: Dallas, TX Join Date: 12/14/2007 Age: Possibly Wise Posts: 401 Rally Car: 1963 SAAB Historic, 1995 Impreza Open Light totaled at WRC Mexico, 2005 STi Pikes Peak winner |
Having worked with both Martynas and Tony at Samsonas/VAC and with Dave at PPG, I'd go the PPG route every time. The price gouging and delays that occured by having to go through VAC were intollerable. If you want a Samsonas box, fly over, buy it in the UK and bring it over by hand. It's much cheaper that way. Jason McDaniel |
Cosworth Paulinho Ferreira Senior Moderator Location: Charlotte, NC Join Date: 03/15/2007 Age: Midlife Crisis Posts: 721 Rally Car: Honda Civic |
Price gouging? You mean the cost of shipping, duties and taxes? And buying in the UK will VAT free in your mind! And what delays are you talking about if you didnt even buy anything? The fact that you were arrogant about it to the point where Martynas Samsonas himself refused to sell you anything might be something worth mentioning before bad mouthing 2 good standing companies. |
No, I mean that after I was quoted a "delivered" price at PRI, Tony quintipuled or more the cost of shipping ($250), duties ($34) and taxes. We committed to buy it and were promised a one month delivery date. Five months later, three days before we leave for Pikes Peak, we were informed that the transmisison finally arrived.
Martynas did not refuse to sell us the box. And was quite happy to speak to me at PRI earlier this month. And who are you? Jason McDaniel |
Eric Ewert Eric Ewert Elite Moderator Location: Calgary, Ab Join Date: 05/13/2013 Age: Settling Down Posts: 366 Rally Car: volvo 240 |
Hey Thomas did you find any instruction/ how to on installing the diff shim kit? I can't find a whole lot on it and am planning on stabbing away at this project asap so if you got something to offer I would very much appreciate it. Edit: just walked over and actually had a better look at the kit. Failed to realize the first time that it has instructions. Im going to bed. Edited 1 time(s). Last edit at 01/11/2015 12:42AM by Eric Ewert. |
Yeah the clutch shims are easy. If you are going to replace any bearings while you are in there it gets a bit more complicated. |
