Not Trolling Keith Morison Professional Moderator Location: Calgary, AB Join Date: 09/15/2015 Age: Ancient Posts: 340 |
Scrutineers are not there to give an opinion on the safety of a design, merely to say that the build meets the rules (which include FIA as an option) and that the build appears to have been done properly. (no-one is about to start x-raying the welds)
First Rally attended (2000), First Rally competed in (2001) Cars Built (1), Engines Built (0) Cages Built (0) Driver (8), Co-Driver (47), Drivers (19) Clerk (29), Steward (1), Official (17), Volunteer (5) WRC Spectator (1), WRC Photographer (6), WRC Observer (4) Rallies attended (120) Countries attended rallies in (11) Last Updated, May30, 2022 |
Thomas Kimsey Thomas Kimsey Mod Moderator Location: Rochester, New Hampshire Join Date: 10/05/2013 Age: Settling Down Posts: 271 Rally Car: 1988 XRatty |
Would this be the rule which makes this design illegal?
4.1.3 Reinforcement plates These are plates welded to the bodyshell used for attachment of the cage, either by direct welding or via mounting feet. Reinforcement plates must be a minimum of 1/8” thick, and have an area of 12 to 100 square inches, with a minimum dimension on any side of 2.5” and a maximum dimension on any side of 12”. It is highly recommended that these plates be formed to attach in more than one plane. |
Anders Green Anders Green Godlike Moderator Location: Raleigh, NC Join Date: 03/30/2006 Age: Possibly Wise Posts: 1,478 Rally Car: Parked |
That design appears to send a load into the side of a tube. My guess is that's the core of the issue. Anyone can do a full FIA cage under NRS, and ignore all the rest of the entire roll cage appendix. It explicitly says so in the rules. Very simple. It's been this way for more than a decade. Anders Grassroots rally. It's what I think about. |
MarkHille Mark Hille Godlike Moderator Location: The hills of CT Join Date: 10/04/2011 Age: Midlife Crisis Posts: 135 Rally Car: I have two crap boxes |
I don't know what you say when you say "tube" anders. Do you mean the shock tower?
I don't see how skye's car isn't meeting the fia regulation. The only way I see it not meeting the NRS specification is if the reinforcement plate is smaller than 2.5" x 5". Is that the argument? It doesn't say it can't be bent. It actually encourages it to be more than 1 plane. There is no mention in the rules of shear or compression. I can understand that someone might not think it is the best design but I don't see how it doesn't meet the rule. At what angle does compression become shear? It looks as if the backstay is in compression going into the shock tower and it is the tower that is in shear. Is that the real issue? According to Rally America they would prefer this. How is anyone to build a cage they can race both series in without issues if it always comes down to the individual scrutineer's opinion of safety? |
Such a silly thing.. so much fappery.... John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
What has the sanctioning body said about this?
If you are building to the rules, and it sounds like you are, and a scrutineer is blocking your car because of an unsubstantiated personal preference, the sanctioning body needs to step-in and remind the scrutineer of their responsibility and scope of powers. Quite frankly, the position where scrutineers are 'approving designs' is one they really don't want to be in unless they are professional engineers with an active stamp and run the design through the calculations/FEA analysis to back-up their assessment. First Rally attended (2000), First Rally competed in (2001) Cars Built (1), Engines Built (0) Cages Built (0) Driver (8), Co-Driver (47), Drivers (19) Clerk (29), Steward (1), Official (17), Volunteer (5) WRC Spectator (1), WRC Photographer (6), WRC Observer (4) Rallies attended (120) Countries attended rallies in (11) Last Updated, May30, 2022 |
DexterVW David Baker Ultra Moderator Location: Rhode my Island Join Date: 11/20/2008 Age: Midlife Crisis Posts: 290 Rally Car: 95 GTI TDI |
i wouldn't be surprised with this one |
I do have a solidworks model of the cage. Wouldn't be terrible to add in some sheet metal for the attachment points and run some FEA on it. Still don't thing that will help. I will probably just end up building to what the scrutineer wants as explanations of the design don't seem to help. |
Mad Matt F Matt Follett Elite Moderator Location: La Belle Province, Montreal Join Date: 03/13/2006 Age: Midlife Crisis Posts: 645 Rally Car: Don't Laugh, the Justy is Fun! |
As active lurker of this thread... That's "fAWked" and your scrutineer should be drawn in (that's not drawn and quartered, merely reigned in).... No need to add the FEA, just a bit of calm-in sense.... Maybe just good beer and a chat? And say, well, I'd like the force of a big blow to the front of the cage to through the supporting dic (member) of the rear of the car, rather then resolved into the gas (atmosphere) that makes up the 22 gauge metal of my rear tire's mud guard... |
Anyone can make pretty color plots with FEA. By changing element type and size you could make a bad design actually pass. |
Yes, any tool can be misused if you do not know how to use it, whats your point? Also there is no way a cage design would be allowed on FEA designs alone in the US. I was just pointing out that an engineering tool that could be used to help prove that this design is legitimate would not be helpful in this case. I will ask the scrutineer more blatantly tomorrow "Does this not meet the NASA rules". |
Precedent evidently means nothing..maybe phrase it "what is it specifically in Fords design used for years in WRC that they did in error and that you will not approve? Of course I would love to ask "when you encountered these specific set ups in the past what did you make them do to get approval" John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
No real point to be made, and I'm certainly not trying to ruffly any feathers here. I'm just not sure of your experience with FEA or FEA within Solidworks. (hence my comment about changing element type and size, which are only 2-variables of the many that you could change). It could be useful in comparing the two designs side by side, but looking at absolute strain values of a complex structure without an FEA study and validation is not very accurate, in my opinion. |
