Buy, Sell & Trade
john vanvurpa needs this
Posted by fiasco
October 10, 2014 07:07PM
http://portland.craigslist.org/clk/cto/4699615133.html
Re: john vanvurpa needs this
October 10, 2014 07:39PM
You know I know 2 strokes a lot better than those gawddam things that twirl around doing nobody knows what for a full 360 degrees and that need all those crutches like "valves" and "camshafts' and "followers" and chains or rubber belts and turbochargers and stuff just to make a simple 100 hp/liter when superior engines were doing 15 or even 25 hp/liter for TRAIL BIKES 40 yeras ago, and excellent torque becuase they fire every time the piston goes up---instead of every once in a while, when ever they feel like it..
But I need sills/rockers in my ol darlin Saab before I need something like this....
Wait, either Dave Gronbeck or Randy Nelson, JVAB customers No1 and No2 ow me a good 2 stroke motor. hmmmmmm
October 10, 2014 07:47PM
Heck ya, two of those POS' sitting in the driveway rotting will save rally.
Clayto
Clayton McCrary
XRatty purchased. Now build it!!
October 10, 2014 08:26PM
Hahaaaa! Hilarious!
That is a score! Just gotta drive a little over the Cascades have a refill of shitty coffee and head home!
Two stroke is all you need right! Oh and some 44mm carbs!??
October 10, 2014 09:46PM
Clayto
Hahaaaa! Hilarious!
I think stock is 3 x 40mm.....
The hot ticket would me to call my ol' buddy from way back in '85 Bengt-Erik Ström just outside of Trollhättan who worked in Saab rally depeartement as engine development guy from 1959 thru end of 1980 season when Saab closed down SSR (Saab Sort and Rally) and went full time on his own..
and ask for the porting specs he did---then compare them to what I know...
See they were pioneers in hi-po 2 stroke tuning...The 1st serious reasearch apaper on exhaust tuning had only been published just in late 1958 or '59 by a filthy Commie East German named Dr Walter Kaaden---and Sweden being Socialists they had good contacts with the DDR.
Problem was that Bengt ported based on measurments from top of the block down to the ports..
And the ports is what gives you your "event timing"....
By time I was fawkin wif serious ring ding shit we were using a degree wheel for accuracy and repeatability....but by then Saab had long since moved to the mighty Ford V4...
Additionally in the moto-cross world the late 60s onward was flat intesive the amount of work on exhaust tuning--and by '74 the use of reed valve...
Reed valve are the shit..You can go nuts on intake duration but the reed valves make the intake side essentially demand sensitive....and keep the intake charge velocity high....no more "flame outs" if you dive deep into a corner and in all the mad braking in waist high bumps you flub a downshift and whack open the gas---if there's siddenly a wide open throttle the reed valves don't snap full open--since there low vacuum, they just kinda wheeeze open--and bang you have high velocity--and there's you low pressure--and you motor out of the corner..
All this was 7-8 years after Saab stopped with the mighty 850 3.
That's 283cc per hole. by 1974 my KTM was doing 33 hp at the back wheel for 250cc--and pulled like a truck...
The cylinders on the Saab can easily be bored +3mm and make the thing a whopping 940cc or 313cc/hole just choosing the old ancient 1974 spec that would be a easy approx 41.3 hp/cylinder or 124 rip snorting horses....
Those things are barely 1800 lbs , come stock with 5.43 final drive and you can see where this is going...
Adam Crane did pretty Ok with his Toiletta Commodah making under 100 hp and weighing in at over 2450lbs---pretty good in large part to the Volvo axle with Dana 30 and a 5.35 final drive.
More powerz and 25% less weight....and vastly better areodynamics for the high speeed stuff..
And a stock 2.2 turns rack, and big discs..
All this depends on one critical item: connecting rods and crank pins and fortunately there are rods and pins and bearings available again after 30 years of being GONE...
Everything else is easy.
October 10, 2014 11:04PM
Did those burn oil like a Wankle? If so was it injected or tank mixed?
Seems like a deal really even if it was just a donor for body parts.
Clayto
Clayton McCrary
October 11, 2014 12:14AM
Probably injected.... but I bet you could do either with a little mod
October 11, 2014 01:47AM
Some of the later ones had a oil pump but never paid much attention to that part...
I have enough fenders and doors and that kind of thing, just need some sills bent up. Need a brake that's good for things longer than 4 feet.
And a plasma cutter.
I wouldn't want to part a solid car
