Looking to get an idea of how much interest there is in these, last time I sold 10-pairs.
Tired of always adjusting the rear wheel bearings on your VW? Rip the wheel off a time or two? Well I've got the solution for you! Adapter plates that will allow you to bolt on mk4 spindles, hubs, and brakes onto the rear beam of any mk1/2/3 US market VW. These parts can be found ANYWHERE in NorthAmerica, so no special ordering Polo parts from Europe. The plates are machined out of 3/4in thick 6061-t6 aluminum, and they set the rear wheel back about 1/4in. Yeah, it changes stuff, get over it. It is up to YOU to decide how you want to get to 4x100 spacing, or if you want to change over to 5x100. I've welded and drilled the hubs for 12mm ARP studs, but you can probably just drill and install 14mm studs (way easier). Each set includes 2 plates (R/L) and all the mounting hardware. You will need the 6 spindle stock spindle bolts though, and sometimes they need to be shortened 3mm or so. Price is $135 a pair, shipped in the US. So, who wants a pair? Edited 2 time(s). Last edit at 01/03/2016 08:40PM by Robert Culbertson. |
ElectroTech Steve Wheeler Super Moderator Location: Fork Lake, Alberta Join Date: 06/09/2015 Age: Midlife Crisis Posts: 336 Rally Car: 1992 Golf |
SideburnsSteve Stephen Hollema Mod Moderator Location: Alliston ONT CANADA Join Date: 01/18/2016 Age: Midlife Crisis Posts: 49 Rally Car: yes please |
Hey, Im interested in a set of these.
This is my first post on here. Ive read posts on this forum for years, finally decided to join proper so I could post. Im just wondering how hard it is to drill the hubs to 4X100. Ive never done anything like that, I'm guessing it has to be pretty precise. Also, what offset rims you use to counter the wider track? And should you switch to mk3 or b3 front control arms to widen the front track also? Thanks! |
I"ll let Culbertson answer the easy ones..He should be along as soon as he's done looking for my straight pull bellhousing he mislaid a while back. There's a number of ways to re-drill the hubs and one easy way for a guy without a big stable mill would be to make up a bushing the you'll want a lather to make it with (lathe being easier to scare up than a mill) you make a steel bushing that fits a wheel bolt hole on the OD very well, just one. Say its OD is 14,2mm----choose a nice easy ID for the bush, maybe 5/16 or 8mm...maybe be brave and take it to 3/8" Bang the bush into a hole on a wheel and then bolt in a couple of other holes the wheel to the hub. Now drill the pilit---whatever the sleeve ID was...Move the wheel/sleeve progressively around.. You're piloted. Next get off Flea bay a "core drill" which looks like this: No tip or point..It only can follow an existing hole...and you used the wheel/sleeve to bang those holes thru nice and square. Chase them thru to size. I am already thinking you'll be going to studs to this is the chance.. Why not go good studs? Google "Bugpack 2.2" studs"...they're 14mm x 1.4 studs with a nice ball nose..super fast starting escpecially when the stud register is down a counterbored hole You use VW bus nuts with them.. (Used these studs on everything I own since sometime last century...since I sat the the "industry standard" on serious rally cars was 14 x 1.5...--why would I think of using anything else?) So you have a Golf or sumpin? What you gonna do with it? John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Hey John,
THanks for the info. Ive read it three times (slower each time) and I do believe I understand what you mean. I have a family friend that has a small machine shop and Im sure he has a lathe, maybe better. He takes off eh for the winter, so I know he can help me come spring time. Golf...no, unfortunately I havent found a clean enough shell. I live in Onterrible after all, and the salt and brine they dump so generously is brutal. I do have 2 clean mk2 jettas. One is just a shell awaiting its day of glory. The other is my bastard that i abuse thoroughly (rally cross lapping etc). It has a full drivetrain swap from a mk3 2.slow with cam chip zaust blah blah close ratio gear thingy and its fun. Fresh(er) engine with built big valve head awaiting install for a bit more go power. I haven't torn a wheel off...but i could see it happening as I get more agressive with it. Im planning ahead i guess... I gotta say, this forum is soooooo much better then vwvortex!! |
John, I found the bell a while back (thought I told you), just need a way to get it to you.
The method of using the wheel as a pilot will work. Or yo can hit up your friends machine shop, or you can use a transfer punch and the wheel as a guide for the punch. The stock mk4 hubs are a 14mm stud-bolt thing, which makes it much easier to install the 14mm studs that John mentioned. On my car I stuck with 12mm studs because I had just replaced the front wheel bearings and punched in studs at the same time. So I ended up welding the hole closed and then drilling it for the 12mm studs I already had, since drilling the fronts for 14mm studs would require new wheel bearings again. |
William Marenich William Marenich Mega Moderator Location: Auburn, MI Join Date: 01/26/2006 Age: Midlife Crisis Posts: 42 Rally Car: 91' VW Golf GTI |
I completely missed this earlier. You can use stock offset wheels, there were no clearance issues with 14in rally tires, or 14in x 8in wheels on my car. I swapped to the Passat arms a little while later because a set fell into my lap, but it's not necessary. |
Ok, cool. Having the wheel back a wee bit would be nice too.
Any idea the shipping to Canadia? Our peso is doing rather poorly at the moment. I bet with exchange and shipping and possible duty crap it'd be double. I just bought a 55usd part that came to 120 shipped :-( |
If you're not in a huge hurry, they might be able to make it across the boarder and shipped from Canada. |
Robert, I saw on FB that you think that the mk4 spindles result in less offset than the mk2 spindles and this makes up for at least part of the 3/4" spacing. Do you have any photos showing the difference in the wheel mounting face with the mk2 vs mk4 setup? A spindle & bearing assembly with rotor flat on the ground would give you the measurement.
I have held them both in my hands and don't remember seeing much difference in assembled height/depth. but never checked. ____________________________________________________________- One. Class -- 2WD www.quantumrallysport.com http://www.facebook.com/home.php?#/pages/Quantum-Rally-Sport/281129179600?ref=nf |
