Buy, Sell & Trade
VW mk1/2/3 Spindle Adapters... UPGRADE inside! (tm)
Posted by Robert Culbertson
Robert Culbertson
Out of this dumpster fire
Re: VW mk1/2/3 Spindle Adapters... UPGRADE inside! (tm)
February 03, 2016 11:27AM
Josh Wimpey
Robert, I saw on FB that you think that the mk4 spindles result in less offset than the mk2 spindles and this makes up for at least part of the 3/4" spacing. Do you have any photos showing the difference in the wheel mounting face with the mk2 vs mk4 setup? A spindle & bearing assembly with rotor flat on the ground would give you the measurement.
I have held them both in my hands and don't remember seeing much difference in assembled height/depth. but never checked.
That comment was made from memory, but I can get a flange to flange measurement this weekend (possibly) to verify.
I'll check my photogs and see what I can dig up as well.
Robert Culbertson
July 29, 2016 04:36PM
So I still haven't gotten around to measuring the track difference....
But! I did find a list on Summit of 12 and 14mm studs that have a knurl diameter over 14mm. This will make it easier for those that want to use a 4X100 pattern.
-Drill out one of the threaded 14mm holes (I'd use the one opposite the small threaded hole that's used to hold the disk on) with the correct size drill for the knurl on the stud.
-Bolt the hub to a 4x100 wheel, using the one new stud location.
-Use a transfer punch or a drill guide to mark the other 3 hole locations. The small threaded hole should also be the center of one, FYI.
-Drill the 3 remaining holes with a drill press.
12mm Studs @ Summit
14mm Studs @ Summit
14mm EMPI Studs @ JBugs @ Amazon
Robert Culbertson
May 01, 2017 04:33PM
New order placed at the machine shop. I'll have another 10-sets for sale in about 6 weeks.
DexterVW
David Baker
95 GTI TDI
May 04, 2017 02:14PM
Just in time for NEFR. I'd like a set please!
CPB
Carl B
MK3 Jetta GT
CPB
May 09, 2017 12:24PM
Please put me down for a set. I can send payment immediately.
CPB
Carl B
MK3 Jetta GT
CPB
July 12, 2017 02:04PM
Any updates? smiling bouncing smiley
Robert Culbertson
July 12, 2017 02:16PM
Machinist started on them this last weekend.
Robert Culbertson
July 23, 2017 06:19PM
I picked up the new batch of adapters this weekend.
I'll be ordering hardware on Monday, and I'll be able to ship them as soon as the hardware shows up.
Robert Culbertson
August 01, 2017 02:33PM
8 sets left and ready to ship!
Josh Wimpey
Josh Wimpey
Sneak the Golf
August 03, 2017 08:34AM
Robert, What is the part number for the 4x100 Caddy hubs that fit the mk4 rear spindles?
And, where do we send money?
One. Class -- 2WD
www.quantumrallysport.com
Robert Culbertson
August 03, 2017 09:47AM
I guess that would make it a bit easier smiling smiley
From William Marenichs wonderful reasesrch : vw 6K9 501 477
Send money to mr.robert.culbertson at gmail dot com.
culberro
Ronald Culberbone III
June 14, 2019 06:28PM
Bump. I still have at least 6 sets to sell.
DanielSL
Daniel
2005 VW Mk. 4 Golf GTI 1.8T
August 23, 2019 08:29PM
Robert, if you have any left, I'd be up for a set or two. I'm building a Mk. II next year, and since my other two cars are Mk. IV's, this would allow for much less spares.
Would these allow for a 5x100 disc brake conversion on the rear?
culberro
August 25, 2019 12:55AM
DanielSL
I could ship them out next week.
And yes, it allows a standard mk4 rear brake/hub/stub to be bolted onto a mk1/2/3 rear beam .
RALLYRS
Mike Ball
Nope...I wish...RWD 2 Door Jeep XJ 4.0 5-spd Dirt-o-cross car(we have no grass!)2.3 ZX3 rallyx car(sold)
September 27, 2019 01:10PM
Pay no mind bumping the Spammer threads down
Support your Local North American Rally Forum!!
While they are still around-and get the hell off Farsebook!!
We still have Specialstage & RallyAnarchy.
Post up Here:
https://rallyanarchy.com/phorum/posting.php
and here:
https://www.specialstage.com/forums/forum.php
