Justin;
I am planning on using either the 185/70 or the 195/65 DMG2 tires on my 2005 Golf Mk. 4 build.
I will be using them on the stock golf/jetta 5 spoke rims which are 15x6.
Both of these sizes call for 6" minimum... Do you see a problem with mounting them?
I see you have an 02 Golf, so am looking for some insight.
Also, does DMack allow ordering only one for fitting and suspension set up, as I am still in process of the build?
Would you recommend one over the other as their overall is identical?
Which would you recommend for sugar sand in Florida; the Hard or Medium?
Thank you for any insight/advice.
Daniel.
