Great shape. Clean. Newly Painted interior. Rally America log book. No major damage. Only entered three Rally America national events with the FRAXA Rally Team and all events were completed successfully.
Spent over $30K building and modifying this rally car and will provide receipts for the original build and more recent modifications. If I was planning to rally again in 2WD, I wouldn't sell.
Here is a youtube video captured during competition at STPR:
Key Features
• Rally America Logbook (3 Rallies)
• Ford Focus SVT Engine (2.0L; 170hp)
• Aftermarket Roof & Seam Welded and Reinforced Shell
• Reconstructed Strut Towers
• Full 10 Point FIA Roll Cage
• Roll Bar Padding - SFI Rated BS48001
• Limited Slip Differential - Ford Torsion LSD
• Hotbits DT2 Rally Suspension with top mounts and camber plates
• Wilwood Brakes - DD Focus Rally (Radial Calipers with 11 inch rotors)
• SPEC Stage 3 Clutch and Aluminum Flywheel
• 6 Speed Manual SVT Gearbox
• Throttle Body - CFM 67mm
• Engine Mounts - VF Engineering
• Hood Vent
• Fuel Sample Port
• Stilo WRC03 Intercom SAB0200
• Sabelt Titan FIA Seats
• G-Force FIA Six Point Belts (Need to be replaced for 2017 per Rally America rules)
• Control Panel (heater/fan; pod lights; battery cut-off switch; washer)
• Terratrip Co-Driver Light
• Battery Relocated to back of vehicle
• Sparco Steering Wheel
• Shift Knob Gear Shifter Lever Selector Short
• Sump Guard and Frame
• Aluminum Skid Plate DDSPM
• Underbody Poly Protection DDUBM
• Gas Tank Poly Protection DDGTP
• Urethane Rally Mud Flaps MFBK
• Hood Pins - Sparco
• Door Panel Covers
• Strut Tower Reinforcement plates
• Rear Hatch Struts
• Tow Points DDtps
• 15" Arcasting Rally Wheels (Gold X 4 Used)
• 215 R15 Pirelli Gravel Tires (X 4 Used)
• Spare Tire Hold Down Strap
• Jack Mount
• Interior Paint - White
• Exterior Paint - Blue
Extra parts/accessories
• Terratrip 202 Computer
• Fiberglass Light Pod
• KC Halogen HiLites 7" Pod Lights
• 215 R15 Pirelli Gravel Tire (X 1 Used)
• 15" OZ Rally Wheel (White X 1 Used)
• Dash Cover
• Floor Mats - Lloyd Mats RubberTite Rubber Floor Mats
• 2 Fire Extinguishers (need to be re-certified)
• Fist Aid Kit
• Spill Kit
• 2 Emergency Triangles
Defects
• Rear bumper has a crack in the back left side but functional and currently covered with sponsor stickers.
• Exterior paint has chips where small stones and other debris came in contact with car during competition. These are mostly located along the running boards and plastic around the lower part of the car.
• Some over-paint spray from white interior painting process.
Transportation
Located in Greenville, NC. Clear Title. Transportation is the buyers responsibility however if you are considering a commercial transportation company, I recommend Auto Transport Direct (usually under $1500 to deliver anywhere in the US).
Sale Price
$12K // $500 discount if purchased by 28MAR17 // Paypal deposit required to hold car.
Thanks,
Miguel Barbery
