What did you do to the rallycar today II
Posted by JohnLane
JohnLane
John Lane
The Fire Breathing Monster
November 13, 2007 10:26AM
OK so that is enough scrolling down in the previous thread.
The Volvo got it's 9" pumpkin removed for gear ratio change surgery.
The Turbo got pulled to redo the plumbing from what will be different exhaust manifolds to it. The manifolds I'll be using will be a nice improvement over the really fugly Volvo manifolds.
Kudos to Dave Clark for choosing the right fasteners and materials when assembling this stuff eight years ago. Not a one fastener broke upon disassembly.
Note to self: Clay mud makes a dandy ceramic coating on the exhaust parts in the area of the turbo. No rust or scaling on all that mild steel material.
JohnLane
MRWmotorsports
Martin Walter
Nissan 240SX
Re: What did you do to the rallycar today II
November 13, 2007 01:07PM
Built a new 3" SS exhaust that goes up and over the rear subframe, and around the fuel cell. It's going to clatter like a SOB but if we crush this one there's bigger problems.
Found and fixed grouning issue with auxillary lights.
Installed 14" rear springs... hopefully won't coil bind now.
-Martin.
DR1665
Brian Driggs
Keyboard. Deal with it.
November 13, 2007 01:53PM
Well, last night, I blew a water line on the turbo and had to replace it. Of course that involves removing half the intake system. (I can't wait to strip this turd down and simplify things!)
Half-ass installed a water temp gauge so I can keep better tabs on coolant temps while I'm driving it than the stock gauge allows.
This weekend, I'll be adjusting the shifter to get 5th and reverse back, then properly wiring up my gauges.
JohnLane
John Lane
November 15, 2007 12:28AM
I will be eliminating the water to my turbo. The motor always has fresh synthetic oil. Not too much worry about coking up the bearings.
The 9" rear will also lose 25lbs via replacing the nodular iron pumpkin with an Al-yoo-Min-ee-um part. Less unsprung weight. Woo-hoo.
JohnLane
JohnLane
John Lane
November 18, 2007 10:51AM
Today I have cleaned up the T-4 flange so that it is ready to accept bigger tubes from the much better exhaust manifolds to feed it.
The turbo will now deliver exhaust to the passenger side so that it need not cross under the transmission.
This will improve placement of the air filter and servicability.
Oh.... Prolly a better pressure ratio for the turbo too.
Yum!!
Now I gots to scare up some 2" .120 wall DOM steel tube.
JohnLane
low impedance
Alex M. Staidle
1987 Mazda Rx7
November 18, 2007 11:51AM
got the front suspension half assed together to be able to roll the car around
~A.M.S.
"Some people are afraid of heights, not me. I'm afraid of widths"
November 19, 2007 01:27PM
I read the rally cars for sale web site.
mothra
Matt Smith
xr4ti
November 19, 2007 02:04PM
I finally managed to get the rally car back to square one so that I can begin installing a full set of new suspension bushings. I managed to blow out the exhaust manifold gasket, ruin a set of spark plug wires, and create a leak in the gas tank all in a matter of a few miles. I can't wait until sandblast 2008.
Matt Smith
November 19, 2007 02:27PM
I put in Cossie headlights, on a cossie grill, finished the front skidplate mount, new mounting tabs for VW bumper and a few more Dzuz fasteners. Found out that it sounds like I have a sick cam at idle and that I have pissed antilag when revving it up when it's only firing on three cylinders.
November 19, 2007 02:37PM
Come on Derek you know you want this one...at least Topi wants you to have it.
http://cgi.ebay.com/ebaymotors/BMW-MOTORSPORT-E-46-M3-GRP-N-CHASSIS_W0QQitemZ120183153438QQihZ002QQcategoryZ98064QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
> See me go at:
> www.11tenths.com
> In the long run Reality always wins.
November 19, 2007 02:40PM
Which language?
Lots of killer 240s in the old Country.
"07-09-21 Volvo 242 Grp H
Motor: B23 med Prospark sprut och tändning. Bromsad 240 hk hos Poutanen.
Låda: M45 Quaife, tätstegad med hög etta.
Bakaxel: 5.13 med lamelldiff (cirka 10 race sedan ny).
Väghållning: justerbara ben fram med Svantedämpare. Förstärkta bärarmar. Sänkta bärarmar bak med uppflyttade Svantedämpare.
Kaross: Sliten men fullt fungerande.
Övrigt: Kort styrservo. 3 tums avgas med kat. Fräscha stolar (glasfiber) och 6 p-bälten. A-bes och startklar.
Nytt elsystem 2006 (Conny Nyström) Nytt bränsle 2006 med catchtank, V8-pump + högtryck.
Körd tre tävlingar i år av Martin Eliasson. 3:a totalt i Gävlesladden, 8:a av 21 A-förare i Gestrikekannan, 11:a av 21 A-förare i Gränsrallyt.
Bilder finns på www.teameliasson.se + reportage Motorsport4sale.com
Pris: Pris: 99 000:- BVSA
Kurt Eliasson, Skutskär, 026-708 57, 070-303 08 57"
Or
07-09-19 Volvo 242 supernat 2400cc
Evo motor med mikuni förgasare, SF låda 2:30, SF diff , 5:43 utv,
50mm sellholm ben fram , nyren sellholm bak, justerbara krängare runtom , ombyggd framvagn, rörbärarmar , etc etc, en väldigt välbyggd volvo som är lätt ca 1000 kg oviktad utan förare, bilen är startsnabb å stabil, 2 i back RM 06, motorn är uppdaterad inför 07 endast gått RC RM i år men bilen har gått RC å behöver lite omsorg som sparklådor (finns) å bakre plåten vid stötfångarn etc. Bilen är idag helt startklar men inte fin. För mer info ring. Pris som den står start klar, Från 168 000Kr.
Daniel Bååth 070-600 45 69 dbhb@spray.se
or
Motorsport4sale.com
More terror here:
http://www.motorsport4sale.com/sv_bilder_2007_071027_mnatta_1e_97105.asp
> See me go at:
> www.11tenths.com
November 19, 2007 02:57PM
I bent up a main hoop yesterday...
November 19, 2007 03:25PM
Friends around the shop were working on a FIA Custom Cages install into a GC8 Impreza, cage into a Audi 90 coupe, seam welding a STI, and final gussets into a Golf. That was all slightly before the fireworks and police raid. See Specialstage if you want to hear that story. It was quite the rally car party. There are: A G2 Focus, G2 Rabbit, four Open GC8 Imprezas, Gubelman's N8 Impreza, my G5 Merkur, a G2 Golf, a Open STI, a PGT Audi 90, and a G2 Celica currently at the shop. That's 12 rally cars.
November 20, 2007 12:05AM
Replaced the Audi front struts yesterday, they've been out since Olympus. Car has been on jackstands since May 1st. Pathetic...shame on me. Brent hit the key today and it fired first time and idled. Now to decide how to add some more power..lot's of old 5000 turbo donors around or maybe 20 valve NA. Leaning towards turbo due to cheapness of parts. C'mon DooWops !!
Gene
JohnLane
John Lane
November 20, 2007 10:32AM
The Steel is due to arrive today.
I'll be ordering up a bunch of goodies from Burns Stainless.
This will be amusing.
The Volvo is on stands.
It will have mostly fresh exhaust from the exhaust manifolds to the rear of the car.
JohnLane
